    Homing issues on a Delta with Duet 2
    Firmware installation
    556
    • Mekiundefined
      Meki
      Hi there!
      I've recently joined the duet fanclub as an owner, and I really do like the adventure that this board has taken me on!
      The patient is an FLSUN QQ-S Pro, and after getting the wiring done, work on the proper configuration has started, and of course, being a newbie, I've hit a roadblock I can't seem to get over...
      The basic problem is that when homing, the endstops don't stop the tower from pushing forward and tries to keep going. Here's the twist: according to M119, all the endstops are in their proper state and when I manually trigger each endstop and M119 again, the changes are reflected. According to M119 every endstop is in working order.
      I'm happy to post any and all config files if that helps!
      Blackfyre.ninja | Medium
        Post your config.g and homedelta.g
        • Mekiundefined
          Meki
          Thank you for looking into this 🙂
          The config came from the online configuration tool, delta parameters came from an "old" mks_robin config file for the QQ-S.
          Only the Z-probe switch has been inverted through manual editing.
          The M119 log:
          10/19/2020, 3:58:23 PM: m119: Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
          10/19/2020, 3:58:34 PM: m119: Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
          10/19/2020, 3:58:43 PM: m119: Endstops - X: at min stop, Y: not stopped, Z: not stopped, Z probe: not stopped
          10/19/2020, 3:58:52 PM: m119: Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
          10/19/2020, 3:59:13 PM: m119: Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: at min stop
          config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 19 2020 11:02:18 GMT+0200 (Central European Summer Time)
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Legionare"                                  ; set printer name
          M665 R130 L280 B130 H370                           ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0                                      ; put your endstop adjustments here, or let auto calibration find them
          M552 S1                                            ; enable network
          M586 P0 S1                                         ; enable HTTP
          M586 P1 S0                                         ; disable FTP
          M586 P2 S0                                         ; disable Telnet
          M569 P0 S0                                         ; physical drive 0 goes forwards
          M569 P1 S0                                         ; physical drive 1 goes forwards
          M569 P2 S0                                         ; physical drive 2 goes forwards
          M569 P3 S0                                         ; physical drive 3 goes forwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z100.00 E417.00                ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z12000.00 E12000.00       ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00           ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 Z0 S1                                         ; set minimum Z
          M574 X1 Y1 Z1 S1                                   ; set active low and disabled endstops
          M558 P4 I1 H5 F120 T6000                              ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z16.2                               ; set Z probe trigger value, offset and trigger height
          M557 R85 S20                                       ; define mesh grid
          M305 P0 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 0
          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
          M305 P1 T100000 B4138 R4700                        ; set thermistor + ADC parameters for heater 1
          M143 H1 S260                                       ; set temperature limit for heater 1 to 260C
          M106 P0 C"Effector" S0 I0 F500 H-1                 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 S"HotEnd" D0 H1 F0                         ; define tool 0
          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
          homedelta.g
          ; homedelta.g
          ; called to home all towers on a delta printer
          G91                        ; relative positioning
          G1 H1 X455 Y455 Z455 F1800 ; move all towers to the high end stopping at the endstops (first pass)
          G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
          G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
          G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
          G90                        ; absolute positioning
          G1 X0 Y0 F6000             ; move X+Y to the centre
            Phaedrux Moderator @Meki
            @Meki said in Homing issues on a Delta with Duet 2:
            ; Endstops M574 X1 Y1 Z1 S1 ; set active low and disabled endstops
            This should be M574 X2 Y2 Z2 S1 for high end endstops.
            If you're a new user to Duet and this is a new build, it might be a good time to jump to RRF v3.1.1 since you're getting a fresh config from the config tool anyway.
            Updating the firmware is easy as uploading two zip files.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
            First upload the 3.0 zip file as is without extracting. Then after it updates, do the same for 3.1.1 zip file.
            Then you can upload the config file set from the web tool for RRF3.
            Mekiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              your thermistor settings are wrong. look up the correct beta value in your thermistor documentation.
              • Mekiundefined
                Meki @Phaedrux
                @Phaedrux said in Homing issues on a Delta with Duet 2:
                M574 X2 Y2 Z2 S1
                Well, I've upgraded to RRF 3, had a little issue with the iap4e.bin file, bot solved it... I'm now running RRF 3.1.1, but still the grinding is there on the endstops and my z-probe has stopped producing any results... it's locked to at min stop... at least the endstops say at max stop when triggered manually...
                So, z-probe broke, and the towers still want to blow off... 😢
                I'm guessing that the z-probe pin now expects to be on the z-probe-in pin instead of e0_stp as in the RRF2...
                @Veti Thanks, but I've got no idea what type of thermistor is in place... FLSUN has been making changes and documentation is scarce to say the least... at least it's a cartridge type instead of the original bare glass bead version...
                  jay_s_uk
                  Can you post your updated config.g and homedelta.g please
                  • Vetiundefined
                    Veti
                    https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/delta/FLSUN/QQ-S/Configuration.h
                    marlin says its
                    1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
                    • Mekiundefined
                      Meki @jay_s_uk
                      @jay_s_uk
                      config.g
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 07:47:37 GMT+0200 (Central European Summer Time)
                      M569 P0 S0                                         ; physical drive 0 goes backwards
                      M569 P1 S0                                         ; physical drive 1 goes backwards
                      M569 P2 S0                                         ; physical drive 2 goes backwards
                      M569 P3 S0                                         ; physical drive 3 goes backwards
                      M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
                      M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
                      M558 P4 C"^zprobe.in" I1 H5 F120 T6000             ; set Z probe type to switch and the dive height + speeds
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                            ; map heated bed to heater 0
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 C"Effector" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
                      T0                                                 ; select first tool
                      homedelta.g
                      ; homedelta.g
                      @Veti Thanks! I mean it!
                        jay_s_uk
                        Nothing looks incorrect in your homing files so I don't see why the endstops aren't triggering correctly.
                        In the M558, P4 is no longer supported and P5 should be used instead.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_in_RepRapFirmware_Num_3
                        • Mekiundefined
                          Meki @jay_s_uk
                          @jay_s_uk Z-probe is fixed, thanks!
                          And believe my, I'm just as baffled... M119 reports that all the endstops are in the neutral state and when I'm going around, triggering them manually M119 reports that the endstops are triggered...
                          • Mekiundefined
                            Meki
                            @jay_s_uk, @Phaedrux, @Veti thanks for all the help!
                            After quadruple checking, it turns out that the endstops were mixed up.
                            Since then, everything is in working order!
