    Duet 2 Wifi, DHCP / DNS questions
    527
      jay_s_uk
      You could configure them with a static IP address using M552.
      Make sure this is out of the range assigned by DHCP
      Ernst Blofeldundefined 1 Reply Last reply Reply Quote 0
      • Ernst Blofeldundefined
        Ernst Blofeld
        I'm going to try that as an interim solution so I can at least find them without jumping through hoops, but any idea what could have happened to their names?
        • Vetiundefined
          Veti
          @Ernst-Blofeld said in Duet 2 Wifi, DHCP / DNS questions:
          Orange France Flybox 4G router
          this seems to be a tp-link mr200.
          you can install openwrt on it and it becomes a powerful router.
          https://openwrt.org/toh/tp-link/archer-mr200
            Ernst Blofeld @Veti
            @Veti said in Duet 2 Wifi, DHCP / DNS questions:
            Unfortunately it's not mine to do that to.
              Ernst Blofeld @jay_s_uk
              @jay_s_uk said in Duet 2 Wifi, DHCP / DNS questions:
              I have now done this using M587 in a macro to set the IP address. I might not be able to refer to them by name, but at least I can find them.
              whosrdaddyundefined 1 Reply Last reply Reply Quote 0
              • whosrdaddyundefined
                whosrdaddy @Ernst Blofeld
                @Ernst-Blofeld You can always add the names to the hosts file of your local computer (assuming it's windows 10)
                  Ernst Blofeld @whosrdaddy
                  @whosrdaddy said in Duet 2 Wifi, DHCP / DNS questions:
                  Sure, but I'd prefer to know what I've done wrong - I must have done something wrong because every other device that is connected to this network works correctly.
                    whosrdaddy
                    well the Duet board supports mDns according to this page but it would be better if it would have DNS support built-in (ie register with an existing DNS server).
                    Did you try accessing the printer with it's mDNS name (ie <yourprintername>.local)?
                    Ernst Blofeldundefined A Former User? 2 Replies Last reply Reply Quote 0
                      mDNS isn't supported by my Android tablet or the Linux version I'm running at the moment, but both of those machines manage to tell the router what their names are, so either I really don't know what I'm talking about, or something is missing or broken.
                        whosrdaddy
                        The problem is that the Duet has no real DNS support other than mDNS.
                        Did you know that there's an app for Android to discover Duets on the network?
                          Is this a hardware limitation or something that could be fixed in a firmware update?
                            A Former User @whosrdaddy
                            That is usually the job of the DHCP server, not the DHCP client; but it does seem the Duets does not send the M550 name as part of the DHCP request, so that could be an improvement - however it would still be up to the DHCP server to register with a DNS server.
