    Question: Endstop for Extruder (E1) to pause print
    • wieman01undefined
      wieman01
      I am building a clay printer and everything is working fine so far (with your help).
      Now I would like the printer to pause a print when the printer is running out of clay using an mechanical endstop.
      The endstop is connected and is working, the wiring is fine.
      When I start the extruder (E1) and trigger the endstop, it won't stop. I have used different configurations, but I am clearly missing something.
      Any idea what could be going on?
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"Clayster"                                                    ; set printer name
      M302 P1																; enable cold extrusion for clay printing
      M552 S1                                                             ; enable network
      M586 P0 S1                                                          ; enable HTTP
      M586 P1 S0                                                          ; disable FTP
      M586 P2 S0                                                          ; disable Telnet
      M569 P0 S1                                                          ; X1
      M569 P1 S0                                                          ; Y
      M569 P2 S0                                                          ; Z1
      M569 P3 S0                                                          ; E0 (Extruder)
      M569 P4 S1                                                          ; E1 (Ram, reversed)
      M569 P5 S0                                                          ; Z2
      M569 P6 S0                                                          ; Z3
      M569 P7 S0                                                          ; X2
      M569 P8 S0                                                          ; Z4
      M584 X0:7 Y1 Z2:5:6:8 E3:4                                          ; remap motors
      M350 X16 Y16 Z16 E16:16 I1			                       			; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z1600.00 E100.00:2000.00						; set steps per mm
      M566 X500.00 Y500.00 Z20.00 E500.00:500.00					   		; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z750.00 E5000.00:250.00					 	; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00 E500.00:500.00				        	; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1000:1400 I30  			          			; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                				; set idle timeout
      M208 X0:390 Y0:365 Z0:350 S1                                        ; 390mm x 365mm x 350mm
      ; Bed leveling geometry & leveling
      M671 X470:470:-70:-70 Y400:-40:400:-40 S5						    ; position leadscrews
      M574 X1 S1 P"!xstop+!duex.e4stop"                                   ; configure active-low endstop for 2 X-motors
      M574 Y1 S1 P"ystop"                                                 ; configure active-low endstop for low end on Y via pin ystop
      ; Filament sensor for Ram
      M591 P1 C"e1stop" S0 D1												; extruder (Ram) endstop
      M558 P5 C"^!zprobe.in" I1
      G31 P1000 X0 Y0 Z0.25                                               ; Z = offset (greater value = closer to bed)
      M575 P1 S1 B57600                                                   ; enable support for PanelDue
      ; Extruder I + II (parallel)
      M563 P0 D0:1 	 													; enable tool 0 and extruder E0 (D0) & E1 (D1)
      M567 P0 E1.00:0.00575 												; mixing ratio(!)
      G10 P0 S0 R0 X0 Y0 													; axis offsets for extruder
      G10 P0 R0 S0														; set extruders active and standby temperature to 0 Celsius
      peter247undefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        Your S value is wrong in the M591.
        From the wiki
        Sn 0 = disable filament monitoring (default), 1 = enable filament monitoring when printing from SD card. Supported for all filament sensor types in firmwares 1.21.1 and in 2.0 and later. In firmware 1.21 this parameter is not supported for sensor types 1 and 2. Filament monitors accumulate calibration data (where applicable) even when filament monitoring is disabled.
        It also is only active when printing.
        Triggering at any other time won't do anything
        • peter247undefined
          peter247 @wieman01
          @wieman01
          I did the same thing , e0 as a filament run sensor and e1 a pause print and resume print.
          But one thing I forgot about is the pause print adds a 10mm retraction , so you change the filament and push until to get filament out of the nozzle , clean than off and start the print you will get a 10mm blob on your print.
          So retract 10mm before starting your print .
          ; External Triggers
          M950 J0 C"!^e0stop"
          M950 J1 C"!^e1stop"
          M581 P0 T1 S1 R1 ;
          M581 P1 T3 S1 R0 ;
          trigger3.g
          M300 S300 P1000
          echo "state.status" , state.status
          if state.status = "paused"
          	M24
          elif state.status = "processing"
          	M25
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          • wieman01undefined
            wieman01
            Thank you, @jay_s_uk and @peter247!
            I had S0 set because I was probably confused by the comment concerning S1 which only works when printing from SD. Is that so? I only use the web interface.
            I will take a closer look at your script, @peter247. I am not 100% certain what it does exactly, but I'll a bit of reading on it.
            jay_s_ukundefined peter247undefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @wieman01
              @wieman01 printing from the SD means loading gcode via the web interface and printing from there. i.e. loading the file on to the duet itself
              Not printing via the SD card would involve streaming the gcode via the USB port using programs such as pronterface or octoprint.
              • peter247undefined
                peter247 @wieman01
                @wieman01
                M300 S300 P1000
                	M24
                	M25
                (1) beep 1 second 300hz
                (2) show me state.state , just used for testing
                (3) if state.status varable says "pause" resume printing
                (4) resume printing from paused
                (6) if state.status varable says "processing" you must be printing , so pause print
                (7) pause print
                • wieman01undefined
                  wieman01
                  Thank you, both. Now I got it.
                  I just tested this during a live print and it worked perfectly thanks to you. The print stopped when I triggered the endstop and paused until I hit "resume".
