3D printin issues on a core XY equiped with a duet wifi
@campeancalin said in 3D printin issues on a core XY equiped with a duet wifi:
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin
M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1tempyour thermistor setting is wrong. look up the correct beta value in your thermistor documentation.
because of it you are printing at the wrong temperature.what material is that you are printing?
@Veti ColorFab XTCF20
the printheads are 24V E3D V6
after changing the B values do I have to redo the PID tunning?
if they are genuine e3d then you need 2 values
B4725 C7.06e-8This will account for about 20 degrees difference at 200C
i would do a pid tune, but the pid value should not change by much.
btw what nozzle are you using? the carbon filament will destroy a normal brass nozzle and could also account for the blobs you are seeing
@Veti It's not a brass nozzle ; reinfoced steel. I plan on having a look at it after it's gone thru a spool of filament.
reinfoced steel.
that is ok for wear, but very bad for temperature transfer.
i would suggest that you print a temperature tower.
I have a little problem with the PID tunning. Once I've changed the values , it gives me the following error message:
M307 H1 S285
Error: M307: bad model parameters
M143 H0 S250 ; set temperature limit for heater 0 to 120C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit -
@campeancalin M303 is used to PID tune, not M307
@jay_s_uk Thank you
can you bed really reach 250C? the bed does not look like the special e3d high temperature bed. and those can reach 250, but should not be operated above 200C
@Veti No. I've PID tunned it for a max temp of 100 C
@campeancalin PID doesn't set a max temperature, the M143 does.
@campeancalin
Looking at the pictures, either you are over-extruding or your first layer is too low (which means you are trying to fit too much material in too little space). That causes material to push up higher than it should, and if the nozzle runs into those lumps it tends to cause layer shifts.And if you don't have one already, get a filament drier, CF filled filaments absorb moisture like crazy and need to be dried. If you look closely you might be able to see the filament bubbling as it comes out of the nozzle. Drying the filament for at least 24 hours will make a huge difference to both print quality and material strength.
How many walls are you using? Are you using concentric infill?
It's typical to use only a few walls and solid or rectilinear infill for the rest. Using too many walls can lead to over extrusion building up.
