Powering Arduino Nano and LEDs from 5V rail
608
    taconite
    Hey guys,
    I want to power a Arduino Nano from the 5V Rail of a Duet 2 Wifi (v1.4) and controll LEDs with it (I don't have heater or fan outputs to spare).
    I will use one remaining fan output to control the state of the LEDs
    Is there enought power to drive the Arduino Nano and approx 30 LEDs of a (300 LED/5m WS2812b LED strip)?
    Best Regards
    Adrian
    Custom ANET A8
    Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
    All I do here is under this license: CC BY-NC-SA
    undefined undefined 2 Replies Last reply 21 Oct 2020, 14:22 Reply Quote 0
      peter247 @taconite
      @taconite
      I would say at a guess , NO , the best way is use a buck converter off the main psu.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        Veti
        see this on how to do the wiring
        https://www.blvprojects.com/blv-mgn-cube-3d-printer?pgid=k8hkwn62-f7fe97b7-2106-47ec-9a07-47b5b8c9a191
          dc42 administrators @taconite
          @taconite said in Powering Arduino Nano and LEDs from 5V rail:
          Hey guys,
          Best Regards
          Adrian
          Arduino Nano: yes (although Arduino Pro Micro is a better one to use if it will take inputs directly from the Duet)
          LED strip: 30 LEDs * up to 60mA per LED = up to 1.8A. That's more than we recommend drawing from the Duet's 5V supply; so no.
            taconite
            Thank you for your replies!
            Why using a buck converter when I could just bi-pass the buck on the Nano. My concern is more about the current draw from the Duet.
            As my fans are running on 24V I will use a optocoupler to convert it to 5V
            Custom ANET A8
              taconite
              Thank you @dc42
              What is the recommended max current draw from the 5V supply?
              Custom ANET A8
              undefined 1 Reply Last reply 21 Oct 2020, 14:38 Reply Quote 0
                Thank you @dc42
                2A total, less 200mA for the Duet and any current drawn by LCDs, endstops and Z probes.
                  taconite
                  So I guess I will do it like that:
                  Custom ANET A8
                  undefined 1 Reply Last reply 21 Oct 2020, 17:33 Reply Quote 0
                    peter247 @taconite
                    @taconite
                    Why the optocoupler ?
                    I can't see why you need one , if it is to switch the buck converter on you can find some buck converter which have a enabled pin.
                      taconite
                      @peter247 With the PWM output of the Fan I want to control the color of the LED. e.G. 10% dutycylce = green. My Fan Voltage is 24V but the Arduino can only take 5V
                      Custom ANET A8
                      undefined 1 Reply Last reply 21 Oct 2020, 18:08 Reply Quote 0
                        peter247 @taconite
                        @taconite
                        So if I have got this right you are going to power your arduino and looks like spi controlled leds from a fan with pwm ?.
                        your diagram makes not sense to me !!!!
                        Are you use spi controlled leds like dotstar ?
                          taconite
                          So I kind of made it work with this scematic
                          Simulation show good results:
                          The Problem with that is, even if i just put on the Fan_PWM at 10% (S0.1) I get already 2.5V. Does anyone has an explanation of that? Because of that I am limited to less colors ("just 6").
                          This is the PCB I put together with an optocoupler, an DC/DC converter and an Arduino Nano.
                          Custom ANET A8
                          8 out of 12
