    minimum extrusion amounts
    1.8k
      Phaedrux Moderator @janusofdoors
      @vishiano said in minimum extrusion amounts:
      m122 b20
      Diagnostics for board 20:
      Was this after printing?
      Want to know if there are any hiccups after printing
      Moves scheduled 890, completed 876, in progress 1, hiccups 0
      janusofdoorsundefined 1 Reply Last reply Reply Quote 0
      • janusofdoorsundefined
        janusofdoors @Phaedrux
        @Phaedrux For the above I sent m122 when it was on layer 3.
        I just sent it again when it was around 95% done with the print, got an error message I haven't seen before, could hear the print slow down when i sent it.
        10/20/2020, 8:43:56 PM m122 b20
        Board TOOL1LC firmware 3.2beta (2020-09-14b1)
        Never used RAM 2.2Kb, max stack 392b
        HEAT 321 CanAsync 358 CanRecv 352 TMC 52 MAIN 343 AIN 245
        Last reset 00:45:12 ago, cause: power up
        Last software reset data not available
        Driver 0: position 2066070, standstill, SG min/max 0/16, read errors 0, write errors 0, ifcount 12, reads 11200, writes 0, timeouts 0, DMA errors 0, failedOp 0xff
        Moves scheduled 40237, completed 40208, in progress 0, hiccups 0
        No step interrupt scheduled
        VIN: 24.2V
        MCU temperature: min 37.1C, current 49.0C, max 51.0C
        Ticks since heat task active 229, ADC conversions started 2701473, completed 2701473, timed out 0
        Last sensors broadcast 00000004 found 1 19 ticks ago
        Free CAN buffers: 3, messages lost 168, duplicates 0, oos 8689
        NVM user row b1d088a9 fffff8bb 20003818 0
        TSENS 001327 GAIN 015225 OFFS 00253b CAL 1f2b
        10/20/2020, 8:43:40 PM m122 b20
        Error: M122: Response timeout: CAN addr 20, req type 6024, RID=1528
          janusofdoors @janusofdoors
          and after completing the print
          m122 b20
          Last reset 00:49:22 ago, cause: power up
          Driver 0: position 2123290, standstill, SG min/max 0/16, read errors 0, write errors 0, ifcount 12, reads 48164, writes 0, timeouts 0, DMA errors 0, failedOp 0xff
          Moves scheduled 45124, completed 45124, in progress 0, hiccups 0
          VIN: 24.5V
          MCU temperature: min 37.1C, current 49.3C, max 51.0C
          Ticks since heat task active 40, ADC conversions started 2951037, completed 2951036, timed out 0
          Last sensors broadcast 00000004 found 1 43 ticks ago
          Free CAN buffers: 36, messages lost 0, duplicates 0, oos 8745
          TSENS 001345 GAIN 015225 OFFS 00253b CAL 1f2b
            Thanks. Not sure about that time out error, but no hiccups shown, so that's good I guess.
            Are you sure of your nozzle size?
            What are your print settings in the slicer? Layer height, extrusion width, print speed, etc.
            • JamesMundefined
              JamesM
              I think you need to increase your instantaneous speed setting for your extruder quite a bit...for my corexy printers with bondtech extruders I have them set at 2000 which for you using mm/sec would be 33. With it set so low it can affect your print especially if you try pressure advance. I would also up your acceleration on your extruder as well. I'm running mine happily at 2000.
              Your max extruder speed is also rather low and I could see that causing issues with retraction and un-retraction since you are limiting it to 20mm/s.
              Also, what's with the 1569 steps/mm for your Z? Usually they would be either 400 or 1600 for the common leadscrews.
                That's a good call. I noticed that too actually but forgot to mention it.
                Try M205 E50 and M201 E3000 and M203 E3000
                  janusofdoors
                  @Phaedrux said in minimum extrusion amounts:
                  I'm certain of the nozzle, it's a couple month old microswiss 0.6 nickel plated nozzle, and I've only printed PLA with it. I've also tried the standard e3d 0.4 brass nozzle and had the same issue with other prints.
                  From the beginning of the print sliced with prusaslicer
                  ; generated by PrusaSlicer 2.2.0+win64 on 2020-10-10 at 22:47:25 UTC
                  ; Prusaslicer does not like odd number lines!
                  ; external perimeters extrusion width = 0.68mm
                  ; perimeters extrusion width = 0.68mm
                  ; infill extrusion width = 0.68mm
                  ; solid infill extrusion width = 0.68mm
                  ; top infill extrusion width = 0.60mm
                  ; first layer extrusion width = 0.80mm
                  M107
                  M190 S55 ; set bed temperature and wait for it to be reached
                  M104 S225 ; set temperature
                  M98 P"0:/macros/startprint.g"
                  M109 S225 ; set temperature and wait for it to be reached
                  G21 ; set units to millimeters
                  G90 ; use absolute coordinates
                  M83 ; use relative distances for extrusion
                  ; Filament gcode
                  M702
                  M701 S"PLA_4043D"
                  M703
                  G10 ; retract
                  I'll try these but fair warning I had them around these levels previously with the same issue.
                  @JamesM said in minimum extrusion amounts:
                  Was 1600 I probably changed it trying to fix this issue, I'll switch it back.
                  janusofdoorsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    Ya just tried again, same issue. Could this be a stepper driver issue?
                      What do you have in this macro?
                      M701 S"PLA_4043D"
                      What do you have in that filament load macro?
                        @Phaedrux
                        startprint.g
                        ;M98 P"homeall.g" ;home axes
                        ;G28 XYZ ;home xy
                        G32 ;adjust Z axis lead screws
                        ;G29 S1 ;load mesh height map
                        G90 ;relative positioning
                        G1 X20 Y25 Z0.2 F1500 ;move to the side of the printer
                        ;M109 S200
                        G1 H0 X200 Y25 Z0.2 E30 F600 ; move in a straight line extruding filament
                        G10 ;retract
                        G92 E0 ; Reset extruder distance
                        PLA_4043D
                        M291 P"Please wait while the nozzle is being heated up" R"Loading PLA_4043D" T5 ; Display message
                        G10 S215 ; Set current tool temperature to 210C
                        M116 ; Wait for the temperatures to be reached
                        M190 S55 ;Set the bed temperature to 55c
                        M291 P"Feeding filament..." R"Loading PLA_4043D" T5 ; Display new message
                        G1 E5 F600 ; Feed 10mm of filament at 600mm/min
                        G4 P1000 ; Wait one second
                        G1 E-1 F600 ; Retract 5mm of filament at 1800mm/min
                        M400 ; Wait for moves to complete
                        M292 ; Hide the message
                          What do you have in bed.g?
                            ; bed.g
                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Mon Jun 29 2020 01:54:12 GMT-0400 (Eastern Daylight Time)
                            ;G29 ; probe the bed and enable compensation
                            ;G28 ; home
                            M98 P"homeall.g"
                            G30 P0 X460 Y250 Z-99999 ; probe near a leadscrew, half way along Y axis
                            G30 P1 X20 Y250 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                              M98 P"homeall.g"
                              You know what I'm gonna ask for next, right?
                                @Phaedrux 😑
                                ; homeall.g
                                ; called to home all axes
                                M400
                                M98 P"homex.g"
                                M400
                                M98 P"homey.g"
                                M400
                                M98 P"homez.g"
                                M400
                                ; homex.g
                                ; called to home the X axis
                                ;M400 ; wait for any current moves to finish
                                ;M913 X30 Y30 ; drop motor current to 70%
                                ;M400 G91 ; relative positioning
                                G1 H2 Z10 F2000 ; lower Z relative to current position
                                G1 H1 X500 F5000 ; move quickly to X axis endstop and stop there (first pass)
                                G1 X-5 F200 ; go back a few mm
                                G1 H1 X500 F500 ; move slowly to X axis endstop once more (second pass)
                                G1 H2 Z-10 F2000 ; lift Z again
                                G90 ; absolute positioning
                                M400 ; wait for moves to finish
                                ; homey.g
                                ; called to home the Y axis
                                G1 H2 Z5 F2000 ; lift Z relative to current position
                                G1 H1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                G1 Y5 F6000 ; go back a few mm
                                G1 H1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass)
                                G1 H2 Z-5 F2000 ; lower Z again
                                ; homez.g
                                ; called to home the Z axis
                                G91
                                G1 H2 Z10 F1000 ;move the bed down a bit
                                G90 ; relative positioning
                                G1 X250 Y250 F2000 ;move probe to centre of bed
                                G30 ;probe bed
                                When I have extra time I'll have to write a script that dumps all this into a file for you 😜
                                  In the system tab of DWC you can click the check box to highlight all files and then right click and download as zip. Then you can extract the zip file and drag and drop those .g files onto the forum post window to upload them.
                                  Now that we've chased down all the gcode being executed when the print starts we're at least sure something weird isn't getting changed without realizing it.
                                    That's good to know.
                                    Whats the next step? Is it possible to set two motors as extruder for the same tool? If so I can at least see if that one exhibits the same issue hooked up to the mainboard.
                                      Yes you could map two extruders to a single tool and set a mixing ratio of 1:1
                                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M567_Set_tool_mix_ratios
                                      That should cause them both to extrude at the same time.
                                      Do you have any photos of previously "good" prints?
                                        Added these lines, a quick test extruding shows both motors seems to be moving at similar rates. Here is what I added to my config.g,
                                        M569 P0.4 S1
                                        M584 X0.0 Y0.1 Z0.2:0.3 E20.0:0.4
                                        M563 P0 D0:1 H1 F0 S"1LC" ; Define tool 0
                                        M567 P0 E1:1
                                        I was tuning pressure advance/acceleration resonance before this issue happened, here is a picture of one of my test prints.
                                        https://ibb.co/tzC3WkT
                                        About to run the print, I'll let you know if the 2nd motor seems to skip.
                                          Not definitive but the 2nd motor doesn't seem to exhibit the issue. The 2nd motor's motion also seems like it's smoother to me. I would think this narrows it down to either something on the toolboard, the hemera motor, or maybe something with the CAN connection.
                                          I had a suspicion this would be the case so I bought another hemera motor and another toolboard this morning. I'm hoping they get delivered by Saturday so I can do some testing over the weekend.
                                            Those prints definitely look better!!
                                            Please keep us posted on your progress.
