Worng homing on a CoreXY and totally wrong step/mm
have you read? this explains movements problems
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter?are you on firmware 3.1.1? check with m115
M350 X32 Y32 I0 ; configure microstepping without interpolation
M350 Z16 E16 I1 ; configure microstepping with interpolationunless there is a special reason you should got with X16 with interpolation on all axis
M92 X160.00 Y160.00 Z8000.00 E420.00 ; set steps per mm
z8000 that seems wrong.
B4138 is incorrect. look up the correct value in your thermistor documentation.
@the_dragonlord said in Worng homing on a CoreXY and totally wrong step/mm:
Good morning, I was making my new printer take her first steps but I'm already in trouble:
- The Y homing direction is correct, the X direction is inverted. As X and Y endstops (wich works correctly) I have two endstops, the Y is placed in front of the bed, the X is placed on the left side so X=0, Y=0 shold be the front left corner...what am I missing?
- The steps/mm are totaly out of sense, I have three 1,8° steppers for X,Y,Z, X and Y drivers uses 32 microsteps, Z uses 16...if Y send G1 Y10 wich should move only 10mm "back", the Y goes over them maximum Y (330)...here again what am I missing?
Here's my config.g:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Oct 25 2020 07:40:35 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"DragonCore" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes backwards
M906 X900 Y900 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
M575 P1 S1 B57600 ; enable support for PanelDueThanks!
Solved the XY direction, thanks!
Yes. I'm on 3.1.1I use 8000 because I have a single stepper for the Z and both the Z rods are syncronized with bigger pulleys wich leads to a 1/3 ratio
For the thermistor now I check it
For now Thanks!
that would mean a leadscrew of 2666. which is unusual as well.
@Veti said in Worng homing on a CoreXY and totally wrong step/mm:
No way to make it work....now the G1 H2 X10 F3000 moves the diagonal correctly but now both X and Y homing are in the wrong directions
I've corrected the thermistor but now it appearsa the following error after a while:
And I can't test the extruder beacuse I see this error during startup:
the direction of homing is the the home[xyzall].g
what did you correct it with?
create the filament folder on the sd card on your computer
The thermistor I choose is:
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtempshould the filament folder be created empty?
that change would not cause the problem with the rise in temperature.
yes
yes
so what's the problem for the temperature? In console I see the bed temperature rises but after few seconds the error appears
@Veti excellent, all solved!!!
going back to the lead scew. what kind of leadscrew is it?
t8x2?
t8x2?
they are the original trapezoidal X5S lead screws I think they are T8 and I think the pitch is 2
The it should be 1600. There is a steps calculator at the Prusa website
so 1600 with a 3:1 ratio would be 4800
exactly but with this esteps it move much more mm
@the_dragonlord
with 8000 it would move even more
@the_dragonlord
of course....when I'll complete all the inital set ups I'll print the calibration cube and then I'll see....for now I'm struggling with the BLTouch
trapezoidal X5S
according to marlin its a t8x8 4 start
so 400x3 = 1200
try that
And Double check the Ratio of 1:3
