    Height Map - 500mmx500mmx4mm aluminium build plate
    2.1k
    • vistalertundefined
      vistalert
      Spent the day trying to get my G32 and G29 running to level the bed on triple Z screws first, then get the height map from the bed mesh process.
      My height map seems to visually say that the bed is amazingly bad, but the numbers indicating +/- 0.25mm seem not so bad for a build plate of this dimension and only 4mm thick.
      What are your thoughts? Is this build plate rubbish, or how would you interpret the plot/numbers?
      • Vetiundefined
        Veti
        what sensor are you using?
        what build surface?
        4mm for a 500x500 seems low.
        comparable surfaces use 8mm or bigger for such a large surface. the height map would indicate that its sagging under its own weight.
          vistalert
          Thanks @Veti
          The BLTOUCH 3.1 is functioning now, and I think I have a sensible bed.g to probe near the three lead screws and autolevel the bed with G32.
          I'm pretty sure it is sagging as you say. It wouldn't surprise me. I do recall some comments around the time of ordering the Rat Rig kit, that they couldn't source thicker build plates.
          Do you think it's tolerable though? I'm interested to know how I should read the scale. The plot seems to say that the bed is sagging like a shopping bag 🙂 But the scale indicates it might only be a range of +/- 0.25mm which doesn't seem too bad.
          • Vetiundefined
            Veti
            @vistalert said in Height Map - 500mmx500mmx4mm aluminium build plate:
            hover over the points with the mouse it well tell you exact values.
            there is this shop that makes plates for voron2 printers.
            https://clever3d.de/epages/7a4290fc-7c7f-46cc-9b99-eadef22228e2.sf/en_US/?ObjectPath=/Shops/7a4290fc-7c7f-46cc-9b99-eadef22228e2/Products/c3d-DDP-PEI-natur
            they are coated with pei and they make custom plates
              vistalert
              @Veti German Engineering, hard to top that! Thanks for the heads up.
              Just had a post back from a colleague in the HevORT Facebook group that says his bed shows .5mm (as opposed to my .25mm) and reckons he gets good results. The issue being a total noob is not knowing what great, crap and functional looks like, I guess.
                vistalert
                Ok I've just placed a steel ruler all over the bed and I can't see anything visibly wrong (to the naked eye at least).
                I've run the ruler down all the linear rails too and don't see any warps/bending either.
                It's just disconcerting seeing such an exaggerated plot. So do we trust the numbers on the scale, and do they mean I have a variance of +/- 0.25mm and if that is correct, is that a big deal?
                • Vetiundefined
                  Veti @vistalert
                  did you do that while the bed was hot?
                    vistalert
                    @Veti yeah - but I did it with the PEI magnetic plate.
                    I just tried again with the plate off, and put the ruler on again and now I can actually see more of a ripple, at least two dips where I tested. I don't have feeler gauges though to measure the gaps. The question remains though if these are in the region of 0.25mm, is this significant enough to worry about?
                    I noted from the German site you mentioned that they have cast aluminium. I don't know if my bed was cast. I asked someone here in Perth who supplies aluminium sheet what they could offer but they said their sheet comes from a roll. So that's a none starter.
                    • Chrissundefined
                      Chriss
                      I guess that the ded is to heavy. It bends over its own weight. You need a thicker sheet of metal.
                      I had the same problem with my corexy, the simulation showed that I needed a 6mm plate with 420x420.
                      vistalertundefined 1 Reply Last reply Reply Quote 0
                        vistalert @Chriss
                        @Veti yeah I think you're spot on there.
                        I can see the light of the BLT shining through, around the middle, and the front third of the bed.
                        Chrissundefined 1 Reply Last reply Reply Quote 0
                        • Vetiundefined
                          Veti @vistalert
                          these guys? https://cncroutersaustralia.com.au/cutting-service/cnc-aluminium-cutting-and-routing-service-perth/
                          • Chrissundefined
                            Chriss @vistalert
                            @vistalert
                            I got the simulation from a German company:
                            Here a 500x500 plate with 5mm so it bends on it's own weight by 0,06969mm:
                            And here with extra 500g: (0,7985 mm)
                            So they recommended to use at least a 6mm plate and I think that they are right.
                            Cheers, Chriss
                            vistalertundefined 1 Reply Last reply Reply Quote 1
                              vistalert @Chriss
                              @Chriss any chance you can run that with 4mm for me?
                              Clearly it's an issue having such a big plate, only 4mm thick.
                              I have an idea that I'm trying out. I have a piece of square aluminium profile I can put under and across the middle of the bed, being careful not to sit on the wires for the bed, or thermistor.
                              I have to do some more tests tomorrow. Tonight I was just making sure I could reset the BL Touch Z offset, do a G32, and G29 to completion. I'll see what the results are like tomorrow.
                              This might just add enough support to prevent sagging, but I have to carefully balance the pressure on the corner levelling bolts/springs so as to not make it bow in the opposite direction or permanently bend the plate. Worth a shot though I think.
                              Many thanks for this post @Chriss it's good to have some supporting data.
                              achrnundefined 1 Reply Last reply Reply Quote 0
                              • achrnundefined
                                achrn @vistalert
                                No need.
                                It will be a linear elastic analysis (you're not working the plate hard enough to worry about any plasticity) so the deflection will be proportional to applied load per unit area, and inversely proportional to the section modulus per unit width. Section modulus per unit width is proprtional to thickness cubed.
                                So an analysis for 5mm plate can be turned into an analysis for 4mm plate by multiplying by 4/5 to account for the self weight changing, and dividing by (4/5)^3 to account for the section modulus changing. (Note that the 5mm to 4mm change basically halves the stiffness of the plate - (4/5)^3 = 0.512)
                                Thus, a 0.06969mm deflection due to self weight for a 5mm plate would become a 0.10889mm deflection for a 4mm plate.
                                The additional 0.01016mm deflection due to additional 500g would just get the stiffness ratio modification (assuming you're still planning on adding 500g) so becomes 0.01984mm, giving a total of 0.08953 (c.f. 0.07985).
                                As a (really very rough) approximation, deflection remaining under half thickness ought to keep you in the elastic regime, so this is still valid.
                                HOWEVER, I have some pretty big quibbles with that analysis. I think what has been analysed is not appropriate to your case.
                                The contour key is illegible, but assuming that it runs to zero at the dark blue, it's clear that there are very large flat areas at the corners. This is not a plate resting on supports at the corners - it's clamped by something very stiff (in the analysis, probably infinitely stiff) across a relatively large part at each corner. So instead of a single sagging curve, you've got a reversing curve profile - the plate is hogging at the corners, then sagging through the middle of the span. This will result in much less deflection than a case where it's actually just resting at the corners (or clamped with something not very flexurally stiff - like a single smallish bolt).
                                If you look at your probed heightmap, you've got a shape with sharp pinnacles at each corner. This analysis doesn't have that - it has round-topped rolling crest, with a large, flat, (uniform blue) expanse.
                                I've done a an analysis of a 500x500 4mm thick plate from 5083 alu (actually, just from iostropic uniform material E=72GPa, poisson=0.33, which is pretty close to 5083 alu).
                                Alu is 2700 kg/m3, which is 27 kN/m3. Therefore 4mm thickness is 0.108 kN/m2 or 0.108kPa.
                                I get 0.401mm centre defelection, which is not far off your height map result.
                                If I generate a contour plot, with contours on the deformed shape, deflections being multiplied 700 times, I get something visually really not at all dissimilar from your height map:
                                A 6mm plate will be 3.4 times stiffer than the 4mm plate, will have 50% more load, but the combined effect will be under half the self weight deflection (all other things being equal), and the deflection under a given imposed load will be under a third (1/3.4).
                                I'd go for at least 6mm plate. Actually, my 300mm diameter delta bed (supported at 3 points) is 6mm plate.
                                achrnundefined 1 Reply Last reply Reply Quote 3
                                • achrnundefined
                                  achrn @achrn
                                  @achrn said in Height Map - 500mmx500mmx4mm aluminium build plate:
                                  Sorry, should be total of 0.12878 (i.e. 0.10889+0.01984) cf 0.07985.
                                    vistalert
                                    I'll close out on this discussion, and thank everybody for the detailed input.
                                    I've now got a 6mm glass plate so have been able to move on. Will start a new thread.
                                      vistalert @achrn
                                      @achrn I can only say wow, and express my gratitude for the level of detail here. Much of it is immediately understandable to an amateur, as you describe the process, and facts needed to get to the results.
                                      My aluminium play is indeed suspended on 4 springs/bolts at the corners. However, remember it also has a heater pad (~500x500) stuck to the back of it.
                                      When I put a straight edge on the plate, I actually see "ripples" which I understand is not unusual for plate due to the rolling process.
                                      Anyway, what is really interesting to me is that have placed a 500x500x6mm glass plate on top of the aluminium. I brought the plate up to 60, 70, then 80 degrees waiting around ten minutes each time to ensure the glass had time to come up to temperature too.
                                      I was surprised by what I saw, which was the glass actually rocked around on the plate. I could get feeler gauges under almost the entire left side, which further indicated that glass is sat on a "hump" in the middle of the plate. So clearly this 4mm plate is pretty unfit for any purpose regarding a build plate.
                                      Give your simulations and my observations, the plate appears to have issues arising from manufacturing process, and then deformations mostly due to self-weight then.
                                      Thanks again, I learned a great deal from your response.
                                      • mrehorstdmdundefined
                                        mrehorstdmd
                                        Have you considered getting a flat aluminum plate, specifically cast tooling plate, that comes milled flat? It is more likely to contact the glass everywhere and provide a uniform temperature over the surface of the glass.
                                        • achrnundefined
                                          achrn @vistalert
                                          No problem - part of my living is made is explaining these sort of matters to barristers (and potentially judges) so lots of practice trying to make them intelligible. Also, I have the tools that make analyising a flat plate trivial. Normally I don't get to play with them myself - someone working for me does it. It does me no harm to prove to myself that I can still work the tools (even if only on a trivial case)!
                                          vistalertundefined 1 Reply Last reply Reply Quote 2
                                            vistalert @achrn
                                            @achrn very interesting. I'm working on a platform in Australia and New Zealand for online dispute resolution. 3D printing is for my hobby / personal projects. The whole ADR space is very exciting at the moment.
                                            @mrehorstdmd I have considered that. It seems hard to source in Australia. I tried one supplier in Perth, but they told me their plate came off of a role, not cast. I will look into it, but it seems less critical if all it is doing is supporting the glass.
                                            I'm not likely to ever take the glass off (unless it breaks) so that's why I was wondering if bonding the aluminium to the glass is a sensible idea. I put the glass on my granite worktop, apply whatever adhesive is appropriate, lay the aluminium on top and then load it up with bricks to hold it down. Is that a crazy idea?
