    2 Component Fans
    Firmware installation
    1.6k
    • Heartleander81undefined
      Heartleander81 @omni
      I have two 24V Fans.
      My question is for a friend and me.
      I have a duet 3 6 hc and my friend has a duet 2 wifi.
      Ok i try this.
      M950 F2 C "fan2" Q500
      M106 P2 S1 H-1
      Heartleander81undefined 1 Reply Last reply Reply Quote 0
        Heartleander81 @Heartleander81
        I have config the Firmware with the tool but the both fans not start with M106 S255.
        On the main can i start the Fan.
        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
        M106 P0 C"Hotend" S0 H0 T45 ; set fan 0 name and value. Thermostatic control is turned on
        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
        M106 P1 C"Bauteil1" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
        M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
        M106 P2 C"Bauteil2" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off
        M563 P0 S"Hotend" D0 H1 F1:2 ; define tool 0
          Phaedrux Moderator @Heartleander81
          @Heartleander81 said in 2 Component Fans:
          Try specifying the fan number with M106 P1:2 S1
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
          Are you sure both fans actually work?
          Do they work if you connect them to the always on fan ports?
          Are they wired to the right ports?
          Can you control them both independently?
          In the DWC do both fans turn on when using the Tool Fan slider?
            Heartleander81 @Phaedrux
            @Phaedrux yes both Fans work.
            Yes i Can control them both independently.
            In the DWC have i fan1 slider at 100% work fan1 and fan2 slider at 100% work fan2.
            With M106 P1 S255 work fan 1, with M106 P2 S255 work fan 2 but M106 P1:2 S255 work only fan 1
              M106 does not support a list of P parameters.
              To use two part cooling fans on one tool, the simplest approach is to connect them in parallel to a single fan output. However, an alternative is to map them in the M563 command, for example:
              M563 P0 D0 H1 F1:2
              Then when tool 0 is selected, M106 Sxx with no P parameter will control both of them.
                Heartleander81 @dc42
                @dc42 that have I make.
                But doun't work.
                M950 F1 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                M106 P1 C"Hotend" S1 H0 T45 ; set fan 0 name and value. Thermostatic control is turned on
                M950 F0 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                M106 P0 C"Bauteil1" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                M563 P0 S"Hotend" D0 H1 F F0: 1: 2 ; define tool 0
                There is my code i Config.g
                  dc42 administrators @Heartleander81
                  Should be: M563 P0 S"Hotend" D0 H1 F0:2
                  Remove the second F and do not include the thermostatic fan in the M563 command.
                  Heartleander81undefined 2 Replies Last reply Reply Quote 0
                    @dc42 i have change it. My finger was faster then my eyes 🙂
                    But fan 1 start fan 2 start not.
                      Ok i hope that is so ok now, but with M106 S255 start only Fan1. Fan2 can I only contol on DWC.
                      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
                      M106 P1 C"Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
                      M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                      M106 P0 C"Bauteil1" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
                      M563 P0 S"Hotend" D0 H1 F0:2 ; define tool 0
                        I think this is the expected behaviour. During a print do both fans work as expected?
                          @Phaedrux
                          Unfortunately not. I can only control Fan2 via the slider in the DWC. With M106 S255, only fan 1 starts, not fan 1 and fan 2 together
                            In DWC there should be a tool fan slider that controls both.
                              @Phaedrux
                              I only have one for Fan1 and one for Fan2, none for both
                                Can you post a screenshot of your DWC fan sliders?
                                    @Phaedrux need you more from the DWC ore is that so ok?
                                      Is that a screenshot from your phone? Can you connect to the DWC via a PC web browser?
                                        Heartleander81
                                        yes it was from my Phone. Now a screen from my Pc
                                          If you click on "Allgemein" What version of Duet Web Control is shown?
                                          If you look on the "status" page, you should see another fan control slider there that should have tool fan as well as the two part cooling fans. Tool fan should control both at the same time.
                                            Heartleander81
                                            i change the language to english, i think is better for you
