WiFi (Rant Alert)
@CaLviNx:
Is there any Ethernet modules that could be retrofitted to the footprint left by removing the ESP8266 ?
That's how the Duet Ethernet is constructed. But we are still waiting for the pre-production PCBs to arrive. So the only option at present involves stripboard and soldering.
HI
It's not going to help much.
I initially tried to associate and connect my duet wifi to my old cisco aironet 1130 access point, it never worked while It was working with my android phone acting as an hotspot.
Luckily it was possible for me to upgrade the access point to a newer one (a 1140) and It worked straight away
Looks like the ESP8266 can be fussy. -
@CaLviNx:
Thank you for the constructive input.
I was thinking about using a ENC28J60 Ethernet module if it's possible, is there any firmware considerations seeing as the WiFi module keeps its own firmware onboard
The prototype Duet Ethernet is using a Wiz850io module.
If you are certain that a static IP address would solve the problem, I could do you a special build of DuetWiFiServer with a fixed IP address, if you tell me which one.
Why dont you list the router you are using?
He already has. Why don't you read the post?
@CaLviNx:
TL/DR What model router do you have? Just because you can't do something doesn't mean it cant be done.
Thank you for confirming my initial assertion
Derp.
The router is a Huawei 4g with a custom firmware on it that is stripped down so far as to only allow internet connectivity nothing else
Uh….
Late to the party, but if you have an Android phone you can use the Fing app to find out the address of all the devices on your network
Alternatively, you could install Fing on your phone.
That does a very good job of analyzing the network and finds all the IP addresses on your network including the ports available.
@CaLviNx:
@CaLviNx
Can you navigate to it with http://duetwifi.local? That works on my network without having to assign a static IP.
^ if your router supports mDNS the above should work.
Thanks for all the suggestions,
I tried http://duetwifi.local address with NO success.
The router is a Huawei 4g with a custom firmware on it that is stripped down so far as to only allow internet connectivity nothing else, and Its a term and condition of service that I use their router, I have tried the sim card in another 4g router but the sim card is pin locked and the end user doesn't get a copy of it, I have asked, even to the point of hard resetting the router and asking for it to be fixed, in that event they send an engineer who does it, i think the company wants to control usage via hardware.
Im looking at Airfiber technology as an alternative.
I will just have to plod on with it until such time as a static IP is able to be assigned or the wired version becomes available.
try dropping the .local for my network it worked as:
http://printername -
I have not tried this but if i follow your issue correctly, no worries on the POS router, this can be done locally (on each machine you want to have access from)you can edit your local "hosts" file to map a net name to the mac address of the wifi board. from that point you can connect via net name instead of ip and your dns will resolve for you.
Try dropping the .local just http://printername
I do not have apple on my conouter either. Also editing your hosts file with mac address and printer name as the other poster stated would work too.
There is no need to add another router into the mix
In your situation, to fix things for other network realted problems I would disable or just not use the WIFI signals your 4G provider is using. Just feed the internet into the WAN port of proper router that you have control over and take things from there. Then you can assign MAC adress to IP and problem is solved. I also had big issues before this was done at my place.
I also got a 4G Huawei modem (CPE) that I'm using. It's fiddly to find the MAC adress but if I go to Home->Product information it shows in a list down there. I then enter LAN under DHCP settings and input mac/ip I noted from the earlier menu. Not having this feature would be a pain in the ass as I have a lot of devices and I want some of the assigned to static addresses so I can manage routes and map things in my network for easier access.
Either one of the above recommendations should work but as an add on, if you truly want to get rid of the crappy ISP router there is a way to do it
Plug that spare routers internet port to one of the available ports on the ISP router and configure it to be a firewall/router.
Next configure the ISP modem/router for passthrough bridging… On Frontier routers its under advanced and connection inside one of the dropdown menus... this will disable the router features of the modem and allow your personal router to be the primary router without creating double nat network issues.
Then on your personal router you can assign an IP from the DHCP lease configuration page.
You will bo longer plug devices into the isp router but instead plug them into your personal router, as well as only connect to the personal routers wifi
