    Triangular wave and print area
    1.7k
    • Leblondundefined
      Leblond @Phaedrux
      @Phaedrux ok I will try in the meantime I disassembled the x axis turned the bearings
      "just to give it a try while I was waiting for some advice from you" and now I've reassembled it and put it back to making a cold mesh to see if anything has changed, then I'll try to print to see if the mesh works or not, tomorrow I will post the results with and without mesh, for the moment thanks @Phaedrux.
      • Leblondundefined
        Leblond @Phaedrux
        @Phaedrux looking at the graphic mesh and checking the coordinates of X which are spaced by 20mm, in 60mm the wheel should make a full turn, I did a free test: I lowered the probe stem I raised the Z axis until it touches the flat, at this point I moved the X axis by 60mm and about 30mm it raised and then lowered in the remaining 30mm, you know you were right the bearings are gone
        • Vetiundefined
          Veti
          have you decided what to do about it?
          new bearings or linear rail conversion?
          Leblondundefined 2 Replies Last reply Reply Quote 0
          • Leblondundefined
            Leblond @Veti
            @Veti think about changing bearings? some idea?
            • Leblondundefined
              Leblond @Veti
              @Veti converting it would cost me time would i have to create the pieces and have them made
              • Vetiundefined
                Veti @Leblond
                @Leblond
                depends on where you live
                A good place to start are the original openparts store
                https://openbuildspartstore.com/metal-v-wheel-kit/
                https://openbuildspartstore.com/ball-bearing-625-2rs-5x16x5/
                (check that the size is the same as yours)
                alternative these are recommended for the voron 2 printer and are supposed to be high quality
                https://www.aliexpress.com/item/32991204773.html
                look for high quality bearings ABEC-7 or above ( ABEC-9)
                • Leblondundefined
                  Leblond @Veti
                  @Veti I live in Italy, ok I look at it thanks
                  • Vetiundefined
                    Veti @Leblond
                    @Leblond said in Triangular wave and print area:
                    the parts you can print yourself.
                    eg (there are many others for the troxy)
                    https://www.thingiverse.com/thing:3855641
                    the rails would need to be ordered
                    • Leblondundefined
                      Leblond @Veti
                      @Veti forgive me but it's not for the printer I have, my printer is a tronxy but the X5SA Pro
                      Leblondundefined 1 Reply Last reply Reply Quote 0
                      • Leblondundefined
                        Leblond @Leblond
                        @Leblond the one you mention is the X5S
                        • Vetiundefined
                          Veti
                          o god. the x5s pro is even worse than the original one.
                          and those wheels dont seem like the openbuilds ones.
                          what bearings do they have?
                          • Leblondundefined
                            Leblond @Veti
                            @Veti 😲 I assure you that you are wrong, the bearings are "u" groove, I have to disassemble them to see their dimensions
