    New Duet 2 extruder not working
    4.1k
    • GGundefined
      GG @GG
      @GG Reloaded firmware but paneldue still does not mimic dwc when homing, When I first put duet sd into computer , the pc tells me error on this card, ask windows to scan and fix, however it then opens to reveal contents ?? I tried to copy and paste the contents of the duet card and syst files but the pc tells me they are write protected and I cant copy and paste.
      • Vetiundefined
        Veti @GG
        @GG said in New Duet 2 extruder not working:
        SD card1 Card is unusable
        that is the card reader on the paneldue.
        it could be that the wire picks up interference.
          Do you have another SD card to try?
          Could the write protection on the SD card be from the adapter card you're using having the write protect switch flipped?
          GGundefined 1 Reply Last reply Reply Quote 0
          • GGundefined
            GG @Phaedrux
            @Phaedrux I tried the protect switch flip but same result, when I use dwc I can heat bed and nozzle and extrude via macros etc, but with panel due I cant even heat nozzle etc, or home properly. I have a new micro sd , may be I should start again with fresh firmware files and load new config etc and see what happens, any thoughts
              It would be helpful if you could make a video on your phone or something that showed what the behaviour of each is.
              It really makes no sense that the DWC homing buttons and the PanelDue buttons behave differently since they call the same macros.
              • GGundefined
                GG @Phaedrux
                @Phaedrux I made a video but it is way too large to send and will not send any suggestons ?
                  google drive or dropbox or vimeo or youtube
                  • GGundefined
                    GG
                    Im Still trying to send video, the paneldue even shows the current temps of bed and extruder so its obviously talking to the duet board but not reading the same config
                      Yes I'm very curious to see what's actually going on.
                      • GGundefined
                        GG @Phaedrux
                        @Phaedrux Ive got the video on gmail google drive but cant figure how to attach it to this box
                          There's a share menu in there some where that you can get a link to copy and paste here.
                          • GGundefined
                            GG @Phaedrux
                            @Phaedrux Cant see a share menu will have to try another system, should I try erasing paneldue and reinstalling firmware. ?
                              If you click on the video icon in google drive there is a bar along the top of the window that has what looks like a stylized paper clip or chain link icon. If you hover over it, it says get link. Clicking on it will bring up a window that should give you a web URL to copy.
                              You can also right click on the movie file in google drive and in the menu there is a "get link" item as well.
                                Phaedrux Moderator @GG
                                No, let's try and figure out where we are before we burn the map.
                                • GGundefined
                                  GG @Phaedrux
                                  @Phaedrux Yep got that far "get link" it says no one added yet, how do I put in this forum s link, sorry about my lack of savy
                                    Once you're in the Get Link pop up you should be able to just copy the link and paste it here.
                                    • GGundefined
                                      GG @GG
                                      @GG https://drive.google.com/file/d/1ZpLHyBXsJ4Dwc_gfxwHcxilEoOrmHD_C/view?usp=sharing hope this works, if video not good enough I can make another
                                        Almost. You'll be getting an email requesting access to your link. Then I should be able to see it.
                                        • GGundefined
                                          GG @Phaedrux
                                          @Phaedrux Havent recieved any email
                                            Maybe try getting a link again, but in the middle of the popup box make sure it says "anyone with a link" like it says in my screen shot.
