new duet 2 wifi not reading sd card
312
    knightwolf313
    I have a Duet 2 Wifi that I finally was able to update the firmware but I couldn't use the web page and come to find out (using the M122 command) that the SD 0 was connected but only reading at 0.2 MBs So it looks like it isn't actually reading the SD card. I tried 6 different micro SD cards of varying capacities, all formated to FAT32, and none of them worked.
    please help.
      Veti
      @knightwolf313 said in new duet 2 wifi not reading sd card:
      whats the error?
      undefined 1 Reply Last reply 28 Oct 2020, 23:29 Reply Quote 0
        Can you post the results of M122?
        Can you post a photo of the back of the SD card slot showing the solder tabs clearly?
        When and where did you purchase your board?
        undefined 1 Reply Last reply 29 Oct 2020, 05:21 Reply Quote 0
          knightwolf313 @Veti
          @Veti it says that the duet rejected the http request: page not found. It then says to check that the ad card is mounted and has the correct files in the /www folder.
          undefined 1 Reply Last reply 29 Oct 2020, 05:49 Reply Quote 0
            knightwolf313 @Phaedrux
            @Phaedrux ![alt text]122966663_385038212679956_4001985691097629999_n.jpg (image url)
            Sorry I thought I got a pic of the M122 but it didn't take. though today it said the sd card was reading at 30MBs as opposed to 0.2MBs as it did hte other day.
            I bought the card through Filastruder on April 16th. I know I held off using it for a while, but I needed to wait till I had all the components and the display took forever to get here. (then I had to move last month and it took awhile to get everything ready after the move.)
            ? undefined 2 Replies Last reply 29 Oct 2020, 07:23 Reply Quote 0
              Veti @knightwolf313
              check on your computer whats the content of the www folder on the sd card.
              undefined 1 Reply Last reply 29 Oct 2020, 05:54 Reply Quote 0
                knightwolf313 @Veti
                  A Former User @knightwolf313
                  better to copy/paste the text if possible.
                  now that you've confirmed the computer sees the files, try M20 S2 P"/www" to see if the duet sees the same, but odds are it won't otherwise it'd just-work(tm).
                    Yes please show the results of M122 and M20 S2 P"/www"
                    If it's unable to read the /www folder then the web interface won't work and you can't upload gcode files, so that's no good.
                    If you have confirmed the same results with a few different cards and it's (intermittently?) showing the read speeds as 0.2MB/s then there is likely an issue with the SD card slot and we will do a warranty exchange. In which case, contact Filastruder and initiate a warranty claim. Include a link to this thread as authorization.
                    undefined 1 Reply Last reply 30 Oct 2020, 23:48 Reply Quote 0
                      And I have tried with 6 different SD cards with no luck reading any of them.
                        Phaedrux Moderator @knightwolf313
                        Thanks for all the testing. Please contact Filastruder and initiate a warranty exchange. Please include a link to this thread as authorization.
                        undefined 1 Reply Last reply 30 Oct 2020, 23:55 Reply Quote 0
                          @Phaedrux Thanks for the help and working with me on this.
                          • undefined DavidLeigh referenced this topic 8 Sept 2022, 11:45
                          9 out of 12
