Not reading config.g on startup.
Welcome
What does the firmware report when you send M21?
Can you copy call the contents of the SD card into a temporary folder on your computer, then format the card, the copy everything back please.
If that does not work then if you have another <32GB uSD card you can use to test please try that.
SENDING:M21
Cannot initialise SD card 0: Card is unusableI'll try that and let you know how it goes.
What Format should I format it to?
FAT
Oh wait what size card do you have? if 4GB or> then FAT32
Ok I tried that. Still no luck. I tried a different SD card and still no luck. Its still giving me the same error.
Ok I think you have a faulty SD card slot. can you contact who you bought the board from and ask for a replacement under warranty referencing this forum thread.
ok. thanks. I will do that.
So I have board number 2 now, and so far it appears I have the same issue. Refusing to believe I have two boards with this issue, I'm trying to re-flash the firmware, but so far no luck. After I re-flash it and press reset it won't connect. I'm going to try somemore tonight, but is it possible I have two boards now that won't read from the SD card? This is getting frustrating.
Dumb question I know but your not accidentally pressing "erase" as well or instead of "reset" are you? The buttons are very close together. In any case, I don't think you need to press reset after re-flashing the firmware.
No the erase button is placed back a little on this version of the board, so it would be difficult to press the erase button accidentally. I was following the wiki about pressing reset, but I'll try it tonight without pressing reset.
If you have re-flashed with 1.18.1 firmware and you were previously using an older version, and you are using a Windows usb host computer, did you install the new device driver as described in the upgrade notes?
I think it previously already had 1.18.1 firmware, but I'm just trying anything at this point. I did install the device driver. I tried using the new Bossa on my Mac, and I've tried using the Sam-ba 2.16 on windows 10 virtual machine on my mac. On the windows machine I installed the device driver.
Ok. I've tried the 1.18.1 firmware and the new 1.19 beta, and either one will not connect after I refresh. I tried it without refreshing but it won't connect that way either. Any ideas? I'm afraid I'm going to have to return this board as well.
Are you able to connect via USB? If so, run M115 to confirm which firmware version you are running, because there have been big changes in the 1.19beta.
No I can't. The only way it lets me connect is if I erase and then reset. I can't get it to boot up with the firmware.
Have you checked the size of the Firmware download from github to make sure you have actually got the BIN File and not the webpage
Yeah I checked that. I'll look again tonight, but I did look at that.
Does any sort of port, or an unknown device, show up in Device Manager (if you are using Windows) when you connect the Duet via USB after flashing the new firmware?
Also check that you re-named the files mind that wont matter if your loading the FW By Bossac or Samba
