    Back with opnpnp again
    540
    • qlfecvundefined
      qlfecv
      @dc42 Is posible read digital value? (4095)
        dc42 administrators @qlfecv
        You could set the range in M308 to 0 to 4096 instead of 0 to 100. Then if you don't want any decimals, use the floor( ) function in the echo command to convert the reading to integer. Or you can stay with 0 to 100 and multiply by 4096.0/100 first. See https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Expressions to see what expressions you can use within the echo command (and in lots of other places).
        • qlfecvundefined
          qlfecv
          Thanks again 👍 👍
          • qlfecvundefined
            qlfecv
            I don't understand that I'm doing wrong.
            I have this configuration
            M950 C"bedtemp" C"nil"
            M308 S2 P"bedtemp" Y"linear-analog" A"V_Sen_H2" F1 L0 H4095
            The pin is 0V I send this
            echo sensors.analog[2].lastReading
            0.0
            Now pin 3.3v
            100.0
              @qlfecv, the M308 documentation for Linear Analog sensors was wrong. The min and max reading parameters are B and C, not L and H. So use B0 C4095.
              qlfecvundefined 1 Reply Last reply Reply Quote 0
              • qlfecvundefined
                qlfecv
                Ok, so I try it.
                @dc42 what is the best option to add the sixth axis?
                I don't like using additional hardware, but with duet2wifi I have no other solution.
                When I can I will buy one " Duet 3 Main Board 6HC".
                  T3P3Tony administrators @qlfecv
                  @qlfecv where are you based?
                  • qlfecvundefined
                    qlfecv
                    In Barcelona, Spain
                      @qlfecv ah cool. I think @dc42 will be in contact.
                      • qlfecvundefined
                        qlfecv @dc42
                        @dc42 said in Back with opnpnp again:
                        Working fine 👍
