Configuring movements limits
Are you homing to the high end or low end?
Please post your complete config.g and homing files.
0,0 should either be the front left corner of the printable area (based on where tool0 can reach) or the center of the bed.
The M208 should be adjusted such that that is the case. Meaning that if the values are negative the nozzle would be able to go further outside of the printable area.
@Phaedrux This is my config.g:
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S0 ; disable network ; Drives M569 P0.0 S0 D2 ; physical drive 0.0 goes forwards X Se invirtieron los cables tambien. Se agrego D3 para stealhtchop3 M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards Y Ultimo cambio: de S0 a S1. Se agrego D3 para stealhtchop3 M569 P0.2 S1 D2 ; physical drive 0.2 goes forwards M569 P0.3 S1 D2 ; physical drive 0.3 goes reverse M569 P0.4 S0 D2 ; physical drive 0.4 goes forwards M569 P0.5 S0 D2 ; physical drive 0.5 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E0.4:0.5 ; set drive mapping M350 X16 Y16 Z32 E16:16 I1 ; configure microstepping with interpolation ; M92 X160.32 Y160.32 Z3200.00:3200.00 E827.22 set steps per mm M92 X80.16 Y80.16 Z3200.00 E428.25:428.25 ; set steps per mm M566 X900.00 Y900.00 Z300.00:300.00 E450:450 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z240.00:240.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z20.00:20.00 E500.00 ; set accelerations (mm/s^2) M906 X1500 Y1500 Z900:900 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X400 Y350 Z400 S0 ; set axis maxima ; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 Z2 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P5 C"^!io3.in" H5 F120 T18000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y28.5 Z0.245 ; set Z probe trigger value, offset and trigger height M557 X25:310 Y27:312 S57:57 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 ;M307 H0 B0 D30 S1.00 ; enable PID para camara, deadtime en 30 segundos M307 H0 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit ;M140 H0 ; map heated bed to heater 0 M141 H0 ; map chamber to heater 0 M143 H0 S130 ; set temperature limit for heater 0 to 130C M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"temp2" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 F-1 ; define tool 1 G10 P1 X-61 Y0 Z-2.3 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined M915 X Y S2 R0 F0 ; sensroless sensitivity ; movments without homing M564 H0 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M950 S0 C"0.out9" ; servo "0" in pin out9 M280 P0 S95 ; move servo to rest position M376 H30 ; cancell mesh levelling at 30 mm M143 S450 ; set max temp to 450 degrees for T0 M143 H2 S450 ; set max temp to 450 for T1 T0 ; select first tool
The homeall.g: ; Calibration of motor currents etc G91 G1 H2 Z0.02 F500 G4 P150 G1 H2 Z5 G1 H2 X0.02 F2000 G4 P150 G1 H2 Y0.02 F2000 G4 P150 G1 H2 Z-5 ; Uncomment the following lines to lift Z after probing G1 Z5 F100 ; lift Z relative to current position ; absolute positioning M400 M913 X60 Y60 ; drop motor current to 60% M400 ; HOME X/Y G1 H1 Y-400 X-400 F10000 ; G1 Y175 X175 F5000 ; M400 G1 H1 Y-400 F10000 G1 Y175 G1 H1 X-400 F10000 G1 X175 M400 G90 ; absolute positioning M400 M913 X100 Y100 ; drop motor current to 100% M400 ; Z HOMING G1 X175 Y175 F5000 ; go to first bed probe point and home Z G30
homex.g: ; Calibration of motor currents etc G91 G1 H2 Z0.02 F500 G4 P150 G1 H2 Z5 G1 H2 X0.02 F2000 G4 P150 G1 H2 Y0.02 F2000 G4 P150 G1 H1 X-400 F10000 ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 19 2020 03:46:47 GMT-0300 (Argentina Standard Time) M400 M913 X60 Y60 ; drop motor current to 45% M400 G91 ; relative positioning G1 H2 Z5 F1200 ; lift Z relative to current position G1 H1 Y-400 F10000 ; nueva G1 Y175 F5000 ; nueva M400 G1 H1 X-400 F10000 M400 G1 H2 Z-5 F1200 ; lower Z again G90 ; absolute positioning M400 M913 X100 Y100 ; drop motor current to 100% G1 X175 F4000 M400
homey.g: ; Calibration of motor currents etc G91 G1 H2 Z0.02 F500 G4 P150 G1 H2 Z5 G1 H2 X0.02 F2000 G4 P150 G1 H2 Y0.02 F2000 G1 H1 Y-400 F10000 G1 H2 Z-5 ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 19 2020 03:46:47 GMT-0300 (Argentina Standard Time) M400 M913 X60 Y60 ; drop motor current to 45% M400 G91 G1 H2 Z5 F1200 G1 H1 Y-400 F10000 G1 H2 Z-5 F1200 G90 M400 M913 X100 Y100 G1 Y175 F4000 M400
(any improvements suggestions over these files are of course very welcome)
My 0.0 is on the front left cornerThanks in advance
(edit: formatting)
@Tinchus said in Configuring movements limits:
; HOME X/Y
M400
G1 H1 Y-400 F10000
G1 Y175
G1 H1 X-400 F10000
G1 X175
M400Some of your homing sequences don't make a lot of sense in the context of sensorless homing. When using an endstop switch it's common to move fast to the switch, hit it, back off, and then slowly hit it again for better accuracy, but sensorless homing that doesn't really work. You need to move fast to trigger the stall, so a single pass is enough. And you've got it backing off to the center of the bed, which is too much.
M92 X80.16 Y80.16 Z3200.00 E428.25:428.25 ; set steps per mmHave you determined what the correct steps per mm is for your X Y?
@Phaedrux said in Configuring movements limits:
this suggest that you are using 0.9 steppers for the z and 1.8 for x and y.
this makes no sense.1.8 with 1600 steps will be more than enough
but you want the high resolution on x and y to achieve better results. -
@Phaedrux , yes, the corrects steps are those in the config: 80.16 for X and Y
@Veti , no, my motors are 1.8 degrees.
what kind of leadscrew are you using to get 3200 steps/mm ?
@Veti said in Configuring movements limits:
1mm lead would do it - that's what I used to have. (200 full steps per rev x 16 micro steps = 3200)
@Veti 1mm leadscrew from moons
ok. that must be slow tough?
@Veti It is not fast I guess, but it is not as slow as you could think. It is VERY precise and accurate though
