    Z trigger height
    869
    • FelixHundefined
      FelixH @Veti
      @Veti thanks for the confirmation. If I add it on the initial Gcode, I can adjust it more rapidly, without having to reboot the board.
      Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @FelixH
        @FelixH
        yes it takes effect without rebooting, but you need to do a new home
          Perhaps using baby stepping would be more appropriate, then you wouldn't need to rehome.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M290_Baby_stepping
          • fcwiltundefined
            fcwilt @FelixH
            @FelixH said in Z trigger height:
            I have a pair of macros (print_begin.g and print_end.g) that are called (using M98) by settings in the slicers I use.
            Two of the things that happen in print_begin.g are a call to a macro configprobe.g and then a call to a macro probez.g
            The Z trigger height setting happens in configprobe.g using G31.
            So if I need to change it, I just edit the file and then subsequent prints use the new settings.
            No need to re-boot, no need to home.
            • FelixHundefined
              FelixH
              Thank you all for your inputs.
              • FelixHundefined
                FelixH
                Is there any kind of trick on finding out the correct trigger height? Any time I have to re-calibrate is like a trip to hell. After following this guide:
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                I get, for example, a trigger height of 1.50mm. I set it on the config.g file and I do a test. The nozzle is way too far from the bed and I try to use Babystepping to get it closer. The Babystepping shows me a -0.15 (for example)... now what? Should I correct the config.g file and set the trigger height to 1.35 (1.5-0.15) ??
                Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @FelixH
                  If it's consistent, yes.
                  If you do the G30 S-1 test multiple times over does it give a consistent result? Are you also homing in that same spot?
                  FelixHundefined 1 Reply Last reply Reply Quote 0
                  • FelixHundefined
                    FelixH @Phaedrux
                    @Phaedrux yes it is consistent and also yes, it homes to the same spot.
                    • fcwiltundefined
                      fcwilt @FelixH
                      To get the nozzle to be closer to the bed you increase trigger height.
                      In your example you decreased it.
                      The trigger height determines how far the nozzle must move to reach Z=0. If the current value of the trigger height is leaving the nozzle above the bed then the nozzle did not move far enough. To get the nozzle to move more you increase the trigger height.
                      FelixHundefined 1 Reply Last reply Reply Quote 1
                      • FelixHundefined
                        FelixH @fcwilt
                        @fcwilt
                        This is exactly what puzzles me every time. The pop up on the Panel Due shows a minus value an yet, it’s the opposite...
                        • fcwiltundefined
                          fcwilt @FelixH
                          I know it can be confusing.
                          When the probe is triggered the trigger height setting (assume 2 mm) says to the firmware "hey the nozzle is now 2mm above the bed". The firmware says to itself "ok so to move the nozzle to Z=0 I must move closer to the bed by 2mm"
                          When you adjust baby stepping to a negative value you are saying to the firmware "hey you need to move closer to the bed".
                          And as you can see to move closer to the bed requires a larger trigger height.
