Yet more conditional gcode help required
Gcode meta commands
1.9k
    Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
    undefined 1 Reply Last reply 3 Nov 2020, 20:34 Reply Quote 0
      OwenD @dc42
      @dc42 Thanks for clarification.
      I might have locked up a few machines over the years with my clumsy work when using loops.
      I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) 😆
        deckingman
        Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
        G91; Set relative
        M400; wait for any moves to finish
        G1 F6000 ; set feedrate to 100mm/sec
        while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0
        if sensors.gpIn[5].value=0; joystick left
        if sensors.gpIn[7].value=0 ; joystick left and forwards
        M400
        G1 X-1 U-1 A-1 Y-1 V-1 B-1
        elif sensors.gpIn[8]; joystick left and backwards
        M400
        G1 X-1 U-1 A-1 Y1 V1 B1
        else ; joystick left only
        M400
        G1 X-1 U-1 A-1
        elif sensors.gpIn[6].value=0; joystick right
        if sensors.gpIn[7].value=0 ; joystick right and forwards
        M400
        G1 X1 U1 A1 Y-1 V-1 B-1
        elif sensors.gpIn[8]; joystick right and backward
        M400
        G1 X1 U1 A1 Y1 V1 B1
        else ; joystick right only
        M400
        G1 X1 U1 A1
        elif sensors.gpIn[7].value=0 ; joystick forwards only
        M400
        G1 Y-1 V-1 B-1
        elif sensors.gpIn[8].value=0 ; joystick backward only
        M400
        G1 Y1 V1 B1
        else break
        Is that about right?
          OwenD
          To clarify my comments.
          A "while" statement will loop if the condition test is true.
          In your case by testing all those inputs.
          If you put
          while true
          G1 X1
          Then you have an endless loop as true always equals true, so you're going to crash.
          Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.
          In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
            deckingman
            OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would 🙂 ).
            But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
            So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
            Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it 🙂 )
            G91; Set relative
            M118 S"Trigger 5 - Joystick"
            M400
            echo "Left and forward"
            elif sensors.gpIn[8].value=0; joystick left and backwards
            M400
            echo "Left and backwards"
            M400
            G1 X-1 U-1 A-1
            echo "Left"
            M400
            echo "Right and forward"
            elif sensors.gpIn[8].value=0; joystick right and backward
            M400
            echo "Right and backwards"
            M400
            G1 X1 U1 A1
            echo "Right"
            M400
            G1 Y-1 V-1 B-1
            echo "Forward"
            M400
            G1 Y1 V1 B1
            echo "Backwards"
            else break
              You could use the built-in 'iterations' variable to adjust the movement amount and/or speed.
              undefined 1 Reply Last reply 6 Nov 2020, 19:28 Reply Quote 0
                deckingman @dc42
                @dc42 said in Yet more conditional gcode help required:
                Thanks. Would I be right in assuming the "iterations" is a counter which increments by 1 every time the while loop runs?
                Scratch that - found it.
                  deckingman
                  That's all working now although the code is a bit "clunky".
                  I'm guessing that once variables are introduced, I ought to be able to do something like ....
                  MoveAmount= 0.5+(iterations/5)
                  G1 X MoveAmount..............
                  .......or some such. Anyway, this is what I've ended up with which may not be elegant but works.
                  G91; Set relative
                  G1 F3000 ; set feedrate to 100mm/sec
                  M400
                  if iterations<3
                  G1 X-0.5 U-0.5 A-0.5 Y-0.5 V-0.5 B-0.5
                  elif iterations<5
                  elif iterations<7
                  G1 X-2 U-2 A-2 Y-2 V-2 B-2
                  elif iterations<9
                  G1 X-5 U-5 A-5 Y-5 V-5 B-5
                  elif iterations<11
                  G1 X-10 U-10 A-10 Y-10 V-10 B-10
                  else
                  G1 X-20 U-20 A-20 Y-20 V-20 B-20
                  M400
                  if iterations<3
                  G1 X-0.5 U-0.5 A-0.5 Y0.5 V0.5 B0.5
                  elif iterations<5
                  elif iterations<7
                  G1 X-2 U-2 A-2 Y2 V2 B2
                  elif iterations<9
                  G1 X-5 U-5 A-5 Y5 V5 B5
                  elif iterations<11
                  G1 X-10 U-10 A-10 Y10 V10 B10
                  else
                  G1 X-20 U-20 A-20 Y20 V20 B20
                  M400
                  if iterations<3
                  elif iterations<5
                  G1 X-1 U-1 A-1
                  elif iterations<7
                  G1 X-2 U-2 A-2
                  elif iterations<9
                  G1 X-5 U-5 A-5
                  elif iterations<11
                  G1 X-10 U-10 A-10
                  else
                  G1 X-20 U-20 A-20
                  M400
                  if iterations<3
                  G1 X0.5 U0.5 A0.5 Y-0.5 V-0.5 B-0.5
                  elif iterations<5
                  elif iterations<7
                  G1 X2 U2 A2 Y-2 V-2 B-2
                  elif iterations<9
                  G1 X5 U5 A5 Y-5 V-5 B-5
                  elif iterations<11
                  G1 X10 U10 A10 Y-10 V-10 B-10
                  else
                  G1 X20 U20 A20 Y-20 V-20 B-20
                  M400
                  if iterations<3
                  G1 X0.5 U0.5 A0.5 Y0.5 V0.5 B0.5
                  elif iterations<5
                  elif iterations<7
                  G1 X2 U2 A2 Y2 V2 B2
                  elif iterations<9
                  G1 X5 U5 A5 Y5 V5 B5
                  elif iterations<11
                  G1 X10 U10 A10 Y10 V10 B10
                  else
                  G1 X20 U20 A20 Y20 V20 B20
                  M400
                  if iterations<3
                  G1 X0.5 U0.5 A0.5
                  elif iterations<5
                  G1 X1 U1 A1
                  elif iterations<7
                  G1 X2 U2 A2
                  elif iterations<9
                  G1 X5 U5 A5
                  elif iterations<11
                  G1 X10 U10 A10
                  else
                  G1 X20 U20 A20
                  M400
                  if iterations<3
                  G1 Y-0.5 V-0.5 B-0.5
                  elif iterations<5
                  G1 Y-1 V-1 B-1
                  elif iterations<7
                  G1 Y-2 V-2 B-2
                  elif iterations<9
                  G1 Y-5 V-5 B-5
                  elif iterations<11
                  G1 Y-10 V-10 B-10
                  else
                  G1 Y-20 V-20 B-20
                  M400
                  if iterations<3
                  G1 Y0.5 V0.5 B0.5
                  elif iterations<5
                  G1 Y1 V1 B1
                  elif iterations<7
                  G1 Y2 V2 B2
                  elif iterations<9
                  G1 Y5 V5 B5
                  elif iterations<11
                  G1 Y10 V10 B10
                  else
                  G1 Y20 V20 B20
                  else break
                    Another way is to use your original code but replace all the XYUVABC coordinates in the G1 commands by calculated values, something like this:
                    G1 X{0.5+0.1 * iterations} Y{-(0.5+0.1 * iterations)} ...
                    undefined 1 Reply Last reply 7 Nov 2020, 11:01 Reply Quote 0
                      deckingman @dc42
                      Ahhh - that looks good! I tried something similar but it didn't work - because I used plain braces rather than curly ones. I'll give that a go..............
                        deckingman
                        For the sake of completeness, here is the final code that I ended up using. After playing around with it, I ended up using just G1 X{0.5+interations}........etc, rather than using fraction's of "iterations".
                        G91; Set relative
                        M400
                        G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                        M400
                        G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                        M400
                        echo "Left"
                        M400
                        G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                        M400
                        G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                        M400
                        echo "Right"
                        M400
                        G1 Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                        echo "Forward"
                        M400
                        G1 Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                        echo "Backwards"
                        else break
                        Thanks for all the help guys.
                          deckingman
                          For further completeness, I've added a "turbo button". So instead of increasing the distance using "iterations", I simply press the button in conjunction with moving the joystick. What that does is move the gantries 20mm if the button is pressed or 0.5mm if it isn't. I prefer this method but either one works.
                          I've also wrapped the entire thing in a "if state.status != "processing"" statement (thanks for the suggestion @T3P3Tony). What that does is checks to make sure that a print is NOT in progress which will do what the M581 R2 parameter will do in the next firmware. Here is that version of the code
                          if state.status != "processing" ; make sure that a print is NOT running
                          G91; Set relative
                          M400
                          if sensors.gpIn[4].value=0 ; check for long move button press
                          else
                          M400
                          else
                          M400
                          echo "Left"
                          G1 X-20 U-20 A-20
                          else
                          G1 X-0.5 U-0.5 A0.5
                          M400
                          else
                          M400
                          else
                          M400
                          echo "Right"
                          G1 X20 U20 A20
                          else
                          G1 X0.5 U0.5 A0.5
                          M400
                          echo "Forward"
                          G1 Y-20 V-20 B-20
                          else
                          M400
                          echo "Backwards"
                          G1 Y20 V20 B20
                          else
                          G1 Y0.5 V0.5 B0.5
                          else break
                          else break
                          undefined 1 Reply Last reply 9 Nov 2020, 15:13 Reply Quote 2
                            appjaws @deckingman
                            @deckingman I have followed this with interest but then I thought what was the actual problem? When I use the XY buttons in DWC my main XY and UV carriages move together and in sync. Have I not understood the problem?
                            appjaws - Core XYUV Duet Ethernet Duex5
                            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                            Ormerod 1-converted to laser engraver, Duet wifi
                            OpenSCAD version 2024.03.18
                            Simplify3D 5.1.2
                            undefined 1 Reply Last reply 9 Nov 2020, 16:12 Reply Quote 0
                              deckingman @appjaws
                              @appjaws said in Yet more conditional gcode help required:
                              Hiya. I've changed things around a bit so that I no longer combine the axes after homing. So the DWC buttons only work for individual axes. i.e. XY moves will only move the hot end - not the hot end and extruder gantry (as they used to do when the axes were combined)
                              The reason being that I've exploited the fact that, because the extruders are connected to the hot end via short Bowden tubes, that extruder gantry doesn't have to exactly follow the hot end gantry. It doesn't have to replicate every tiny move that the hot end does - it only has to follow it within an allowable tolerance. So if there are small features (say a hole or a cylinder) then I can "park" the extruder gantry in the centre of that feature and let it sit there while the hot end does all those short moves which make that feature. The same applies to other short zig-zag type moves where the extruder gantry sits still while the hot end does the short zig-zags.
                              I made a couple of YouTube videos which explain it in a bit more detail
                              https://www.youtube.com/watch?v=rOP9QYAlhZU
                              and
                              https://www.youtube.com/watch?v=mTPV3Ss1D-4
                              So that's the reason why the axis button on DWC are no longer much use to me. A fuller explanation of what I wanted the joystick to do, and how that works in practice is here
                              https://www.youtube.com/watch?v=wCR5Ao0iH-c
                                appjaws
                                Hi again,
                                Very impressive videos @deckingman . Is it possible to have a copy of your python script that generates the movement please.
                                My machine really vibrates during short movements so your solution should solve it for me.
                                Simplify3D 5.1.2
                                undefined 1 Reply Last reply 9 Nov 2020, 18:44 Reply Quote 0
                                  deckingman @appjaws
                                  @appjaws Sure. It's been a few years since we last communicated. Is your email address still the one ending ......ve.co.uk? If not, pm me with the address to use.
                                  Be aware, that it's quite a lot of work to run the machine in "true" CoreXYUV mode. You need to change all you homing files so that they do not re-combine the axes, and change the "P" parameter in M581 so that the 5 axes are visible. Also any macros or gcode start and end scripts that have XY moves will need to be changed to incorporate XYUV moves.
                                  Also be aware that, although the python code gets the job done, I'm not a writer of code, so it ain't pretty.
                                    appjaws
                                    @deckingman Yes same email address.
                                    I was wondering if I could just change the XYUV to be individual just during a print similar to the way homeall.g works.
                                    M584 X0 U3 Y1 V4 Z7:8:9 E2:5:6 P5 ; temporarily separate and map drives to U and V axes
                                    complete the modified gcode part file using separate XYUV axes
                                    M584 X0:3 Y1:4 Z7:8:9 U10 V11 E2:5:6 P3 ; put motor mapping back to normal so that X uses drives 0 and 3 Y uses 1 and 4
                                    then once the printed part is removed from the bed run homeall.g
                                    can you see any problems with this?
                                    Thanks for your help
                                    Simplify3D 5.1.2
                                    undefined 2 Replies Last reply 10 Nov 2020, 14:20 Reply Quote 0
                                      deckingman @appjaws
                                      I can't think of a reason why that wouldn't work. That is to say, it'll allow you to use the DWC buttons to jog all the axes in sync before and after a print, and also run any macros that aren't run during a print.
                                      What I mean by that, is that I use macros to wipe and purge the nozzle, and these macros are called by the slicer gcode as part of the start and end scripts. As the axes are separated before the print starts, then these particular macros have to be modified. But of course, if you don't call any macros from the slicer gcode file that have G1 moves, then you won't need to worry about it.
                                        deckingman @appjaws
                                        @appjaws Email sent....
                                          appjaws
                                          @deckingman This is my simplify3D start and end scripts
                                          Starting script
                                          M98 P"0:/macros/extra/Set LED Red"
                                          if !move.axes[0].homed || !move.axes[1].homed
                                          G28
                                          G28 Z
                                          ;M98 P"0:/macros/Conditional/Auto_Bed_Levelling"
                                          M98 P"0:/macros/Auto Nozzle Cleaning"
                                          M98 P"0:/macros/Move to Print Position"
                                          M98 P"0:/macros/extra/Set LED Blue"
                                          M98 P"0:/macros/MapDrivesXYUV"
                                          T0
                                          Ending script
                                          M98 P"0:/macros/End of Print"
                                          M98 P"0:/macros/CombineDrivest"
                                          M291 P"Print Completed " ; Display message
                                          These are untouched by the the generator
                                          Will be running the whole system later today, have sent you an email, requesting some advice.
                                          Paul
                                          Simplify3D 5.1.2
                                          undefined 1 Reply Last reply 11 Nov 2020, 11:12 Reply Quote 0
                                          25 out of 36
