    Yet more conditional gcode help required
    Gcode meta commands
    2.0k
    • OwenDundefined
      OwenD @deckingman
      @deckingman You'll probably need to move the dual input directions in front of the uni-input directions.
      Otherwise they won't execute using elif because each combination move will have previously equated to true in the single input section.
        deckingman @OwenD
        @OwenD said in Yet more conditional gcode help required:
        Ahh - good point. Does the rest of it look reasonable?
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @deckingman
          @deckingman said in Yet more conditional gcode help required:
          Looks reasonably sane.
          You may need an M400 in each elif.
          I'm not sure what the cycle time will be so you might experience an accumulation of moves by the time you take your hand off the joystick
            deckingman @OwenD
            That's unusual for me - I spend most of my time doing crazy stuff 🙂
            Good point - I'll plaster a few more M400s around
            Yes I had considered that - hence the 1mm "nudge move" length to start with. Guess I could either shorten that to (say) 0.1mm and/or scatter a few G4 commands around.
            • taconiteundefined
              taconite
              One suggestion: At the first 4 if statements I would add an "AND" with the negated statements of the last 4 if statements. Otherwise when you push the joystick to left forward the ifs "left", "forward" and "left forward" will be executed.
              Or wait I think what I just read is only the case if using if instead of elif ...
              Custom ANET A8
              Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
              All I do here is under this license: CC BY-NC-SA
                dc42 administrators @deckingman
                That's the right approach, however the if..elif statements are not right. Try something like this:
                    if sensors.gpIn[5].value=0           ; if left button down
                        if sensors.gpIn[7].value=0       ; if joystick left and forward
                	    G1 ...
                	elif sensors.gpIn[8].value=0     ; if joystick left and backwards
                	    G1 ...
                        else                             ; just left
                	    G1 ...
                    elif sensors.gpIn[6].value=0         ; right button down
                	if sensors.gpIn[7].value=0       ; joystick right and forwards
                	    G1 ...
                        elif sensors.gpIn[8].value=0     ; joystick right and backwards
                	    G1 ...
                        else                             ; just right
                	    G1 X1 U1 A1
                    elif sensors.gpIn[7].value=0         ; if just forwards
                	G1 ...
                    elif sensors.gpIn[8].value=0         ; if just backwards
                	G1 ...
                You could also add an "else break" at the end, then you wouldn't need to test all the buttons in the while-part.
                deckingmanundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                  deckingman @dc42
                  @dc42 Thanks. That looks good. From my very limited knowledge, I can see that would be "conflict free" compared to what I had.
                  @all. Thanks for the input everyone - much appreciated. It'll be a couple of days or so before I get time to get the hardware and wiring sorted. Then I'll either report back with a successful outcome, or I'll be asking for more help........
                  • OwenDundefined
                    OwenD @dc42
                    @dc42 said in Yet more conditional gcode help required:
                    If he removes the while test of all pins, wouldn't the macro only trigger once (when a switch signal rose/fell)
                    Or do you just mean use "while true" instead (hence the break statement )
                    I'm always reluctant to use potentially infinite loops.
                      Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
                      • OwenDundefined
                        OwenD @dc42
                        @dc42 Thanks for clarification.
                        I might have locked up a few machines over the years with my clumsy work when using loops.
                        I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) 😆
                          deckingman
                          Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
                          G91; Set relative
                          M400; wait for any moves to finish
                          G1 F6000 ; set feedrate to 100mm/sec
                          while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0
                          	if sensors.gpIn[5].value=0; joystick left
                          		if sensors.gpIn[7].value=0 ; joystick left and forwards
                          			M400
                          			G1 X-1 U-1 A-1 Y-1 V-1 B-1
                          		elif sensors.gpIn[8]; joystick left and backwards
                          			M400
                          			G1 X-1 U-1 A-1 Y1 V1 B1
                          		else ; joystick left only
                          			M400
                          			G1 X-1 U-1 A-1
                          	elif sensors.gpIn[6].value=0; joystick right
                          			M400
                          			G1 X1 U1 A1 Y-1 V-1 B-1
                          		elif sensors.gpIn[8]; joystick right and backward
                          			M400
                          			G1 X1 U1 A1 Y1 V1 B1
                          		else ; joystick right only
                          			M400
                          			G1 X1 U1 A1
                          	elif sensors.gpIn[7].value=0 ; joystick forwards only
                          		M400
                          		G1 Y-1 V-1 B-1
                          	elif sensors.gpIn[8].value=0 ; joystick backward only
                          		M400
                          		G1 Y1 V1 B1
                          	else break
                          Is that about right?
                          • OwenDundefined
                            OwenD
                            To clarify my comments.
                            A "while" statement will loop if the condition test is true.
                            In your case by testing all those inputs.
                            If you put
                            while true
                              G1 X1
                            Then you have an endless loop as true always equals true, so you're going to crash.
                            Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.
                            In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
                              deckingman
                              OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would 🙂 ).
                              But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
                              So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
                              Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it 🙂 )
                              G91; Set relative
                              M118 S"Trigger 5 - Joystick"
                              			M400
                              			echo "Left and forward"
                              		elif sensors.gpIn[8].value=0; joystick left and backwards
                              			M400
                              			echo "Left and backwards"
                              			M400
                              			G1 X-1 U-1 A-1
                              			echo "Left"
                              			M400
                              			echo "Right and forward"
                              		elif sensors.gpIn[8].value=0; joystick right and backward
                              			M400
                              			echo "Right and backwards"
                              			M400
                              			G1 X1 U1 A1
                              			echo "Right"
                              		M400
                              		G1 Y-1 V-1 B-1
                              		echo "Forward"
                              		M400
                              		G1 Y1 V1 B1
                              		echo "Backwards"
                              	else break
                                You could use the built-in 'iterations' variable to adjust the movement amount and/or speed.
                                  deckingman @dc42
                                  Thanks. Would I be right in assuming the "iterations" is a counter which increments by 1 every time the while loop runs?
                                  Scratch that - found it.
                                    deckingman
                                    That's all working now although the code is a bit "clunky".
                                    I'm guessing that once variables are introduced, I ought to be able to do something like ....
                                    MoveAmount= 0.5+(iterations/5)
                                    G1 X MoveAmount..............
                                    .......or some such. Anyway, this is what I've ended up with which may not be elegant but works.
                                    G91; Set relative
                                    G1 F3000 ; set feedrate to 100mm/sec
                                    			M400
                                    			if iterations<3
                                    				G1 X-0.5 U-0.5 A-0.5 Y-0.5 V-0.5 B-0.5
                                    			elif iterations<5
                                    			elif iterations<7
                                    				G1 X-2 U-2 A-2 Y-2 V-2 B-2
                                    			elif iterations<9
                                    				G1 X-5 U-5 A-5 Y-5 V-5 B-5
                                    			elif iterations<11
                                    				G1 X-10 U-10 A-10 Y-10 V-10 B-10
                                    			else
                                    				G1 X-20 U-20 A-20 Y-20 V-20 B-20
                                    			M400
                                    			if iterations<3
                                    				G1 X-0.5 U-0.5 A-0.5 Y0.5 V0.5 B0.5
                                    			elif iterations<5
                                    			elif iterations<7
                                    				G1 X-2 U-2 A-2 Y2 V2 B2
                                    			elif iterations<9
                                    				G1 X-5 U-5 A-5 Y5 V5 B5
                                    			elif iterations<11
                                    				G1 X-10 U-10 A-10 Y10 V10 B10
                                    			else
                                    				G1 X-20 U-20 A-20 Y20 V20 B20
                                    			M400
                                    			if iterations<3
                                    			elif iterations<5
                                    				G1 X-1 U-1 A-1
                                    			elif iterations<7
                                    				G1 X-2 U-2 A-2
                                    			elif iterations<9
                                    				G1 X-5 U-5 A-5
                                    			elif iterations<11
                                    				G1 X-10 U-10 A-10
                                    			else
                                    				G1 X-20 U-20 A-20
                                    			M400
                                    			if iterations<3
                                    				G1 X0.5 U0.5 A0.5 Y-0.5 V-0.5 B-0.5
                                    			elif iterations<5
                                    			elif iterations<7
                                    				G1 X2 U2 A2 Y-2 V-2 B-2
                                    			elif iterations<9
                                    				G1 X5 U5 A5 Y-5 V-5 B-5
                                    			elif iterations<11
                                    				G1 X10 U10 A10 Y-10 V-10 B-10
                                    			else
                                    				G1 X20 U20 A20 Y-20 V-20 B-20
                                    			M400
                                    			if iterations<3
                                    				G1 X0.5 U0.5 A0.5 Y0.5 V0.5 B0.5
                                    			elif iterations<5
                                    			elif iterations<7
                                    				G1 X2 U2 A2 Y2 V2 B2
                                    			elif iterations<9
                                    				G1 X5 U5 A5 Y5 V5 B5
                                    			elif iterations<11
                                    				G1 X10 U10 A10 Y10 V10 B10
                                    			else
                                    				G1 X20 U20 A20 Y20 V20 B20
                                    			M400
                                    			if iterations<3
                                    				G1 X0.5 U0.5 A0.5
                                    			elif iterations<5
                                    				G1 X1 U1 A1
                                    			elif iterations<7
                                    				G1 X2 U2 A2
                                    			elif iterations<9
                                    				G1 X5 U5 A5
                                    			elif iterations<11
                                    				G1 X10 U10 A10
                                    			else
                                    				G1 X20 U20 A20
                                    		M400
                                    		if iterations<3
                                    				G1 Y-0.5 V-0.5 B-0.5
                                    			elif iterations<5
                                    				G1 Y-1 V-1 B-1
                                    			elif iterations<7
                                    				G1 Y-2 V-2 B-2
                                    			elif iterations<9
                                    				G1 Y-5 V-5 B-5
                                    			elif iterations<11
                                    				G1 Y-10 V-10 B-10
                                    			else
                                    				G1 Y-20 V-20 B-20
                                    		M400
                                    		if iterations<3
                                    				G1 Y0.5 V0.5 B0.5
                                    			elif iterations<5
                                    				G1 Y1 V1 B1
                                    			elif iterations<7
                                    				G1 Y2 V2 B2
                                    			elif iterations<9
                                    				G1 Y5 V5 B5
                                    			elif iterations<11
                                    				G1 Y10 V10 B10
                                    			else
                                    				G1 Y20 V20 B20
                                    	else break
                                      Another way is to use your original code but replace all the XYUVABC coordinates in the G1 commands by calculated values, something like this:
                                      G1 X{0.5+0.1 * iterations} Y{-(0.5+0.1 * iterations)} ...
                                        deckingman @dc42
                                        Ahhh - that looks good! I tried something similar but it didn't work - because I used plain braces rather than curly ones. I'll give that a go..............
                                          deckingman
                                          For the sake of completeness, here is the final code that I ended up using. After playing around with it, I ended up using just G1 X{0.5+interations}........etc, rather than using fraction's of "iterations".
                                          G91; Set relative
                                          			M400
                                          			G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                          			M400
                                          			G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                          			M400
                                          			echo "Left"
                                          			M400
                                          			G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                          			M400
                                          			G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                          			M400
                                          			echo "Right"
                                          		M400
                                          		G1 Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)}
                                          		echo "Forward"
                                          		M400
                                          		G1 Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations}
                                          		echo "Backwards"
                                          	else break
                                          Thanks for all the help guys.
                                            deckingman
                                            For further completeness, I've added a "turbo button". So instead of increasing the distance using "iterations", I simply press the button in conjunction with moving the joystick. What that does is move the gantries 20mm if the button is pressed or 0.5mm if it isn't. I prefer this method but either one works.
                                            I've also wrapped the entire thing in a "if state.status != "processing"" statement (thanks for the suggestion @T3P3Tony). What that does is checks to make sure that a print is NOT in progress which will do what the M581 R2 parameter will do in the next firmware. Here is that version of the code
                                            if state.status != "processing" ; make sure that a print is NOT running
                                            	G91; Set relative
                                            				M400
                                            				if sensors.gpIn[4].value=0 ; check for long move button press
                                            				else
                                            				M400
                                            				else
                                            				M400
                                            				echo "Left"
                                            					G1 X-20 U-20 A-20
                                            				else
                                            					G1 X-0.5 U-0.5 A0.5
                                            				M400
                                            				else
                                            				M400
                                            				else
                                            				M400
                                            				echo "Right"
                                            					G1 X20 U20 A20
                                            				else
                                            					G1 X0.5 U0.5 A0.5
                                            			M400
                                            			echo "Forward"
                                            				G1 Y-20 V-20 B-20
                                            			else
                                            			M400
                                            			echo "Backwards"
                                            				G1 Y20 V20 B20
                                            			else
                                            				G1 Y0.5 V0.5 B0.5
                                            		else break
                                            else break
                                            appjawsundefined 1 Reply Last reply Reply Quote 2
