Yet more conditional gcode help required
@OwenD said in Yet more conditional gcode help required:
@deckingman You'll probably need to move the dual input directions in front of the uni-input directions.
Otherwise they won't execute using elif because each combination move will have previously equated to true in the single input section.Ahh - good point. Does the rest of it look reasonable?
@deckingman said in Yet more conditional gcode help required:
Looks reasonably sane.
You may need an M400 in each elif.
I'm not sure what the cycle time will be so you might experience an accumulation of moves by the time you take your hand off the joystick -
That's unusual for me - I spend most of my time doing crazy stuff
Good point - I'll plaster a few more M400s around
Yes I had considered that - hence the 1mm "nudge move" length to start with. Guess I could either shorten that to (say) 0.1mm and/or scatter a few G4 commands around.
One suggestion: At the first 4 if statements I would add an "AND" with the negated statements of the last 4 if statements. Otherwise when you push the joystick to left forward the ifs "left", "forward" and "left forward" will be executed.
Or wait I think what I just read is only the case if using if instead of elif ...
That's the right approach, however the if..elif statements are not right. Try something like this:
if sensors.gpIn[5].value=0 ; if left button down if sensors.gpIn[7].value=0 ; if joystick left and forward G1 ... elif sensors.gpIn[8].value=0 ; if joystick left and backwards G1 ... else ; just left G1 ... elif sensors.gpIn[6].value=0 ; right button down if sensors.gpIn[7].value=0 ; joystick right and forwards G1 ... elif sensors.gpIn[8].value=0 ; joystick right and backwards G1 ... else ; just right G1 X1 U1 A1 elif sensors.gpIn[7].value=0 ; if just forwards G1 ... elif sensors.gpIn[8].value=0 ; if just backwards G1 ...
You could also add an "else break" at the end, then you wouldn't need to test all the buttons in the while-part.
@dc42 Thanks. That looks good. From my very limited knowledge, I can see that would be "conflict free" compared to what I had.
@all. Thanks for the input everyone - much appreciated. It'll be a couple of days or so before I get time to get the hardware and wiring sorted. Then I'll either report back with a successful outcome, or I'll be asking for more help........
@dc42 said in Yet more conditional gcode help required:
If he removes the while test of all pins, wouldn't the macro only trigger once (when a switch signal rose/fell)
Or do you just mean use "while true" instead (hence the break statement )
I'm always reluctant to use potentially infinite loops. -
Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
@dc42 Thanks for clarification.
I might have locked up a few machines over the years with my clumsy work when using loops.
I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) -
Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 G1 X-1 U-1 A-1 Y-1 V-1 B-1 elif sensors.gpIn[8]; joystick left and backwards M400 G1 X-1 U-1 A-1 Y1 V1 B1 else ; joystick left only M400 G1 X-1 U-1 A-1 elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 G1 X1 U1 A1 Y-1 V-1 B-1 elif sensors.gpIn[8]; joystick right and backward M400 G1 X1 U1 A1 Y1 V1 B1 else ; joystick right only M400 G1 X1 U1 A1 elif sensors.gpIn[7].value=0 ; joystick forwards only M400 G1 Y-1 V-1 B-1 elif sensors.gpIn[8].value=0 ; joystick backward only M400 G1 Y1 V1 B1 else break
Is that about right?
To clarify my comments.
A "while" statement will loop if the condition test is true.
In your case by testing all those inputs.If you put
while true G1 X1
Then you have an endless loop as true always equals true, so you're going to crash.
Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would ).
But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it )
G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec M118 S"Trigger 5 - Joystick" while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 G1 X-1 U-1 A-1 Y-1 V-1 B-1 echo "Left and forward" elif sensors.gpIn[8].value=0; joystick left and backwards M400 G1 X-1 U-1 A-1 Y1 V1 B1 echo "Left and backwards" else ; joystick left only M400 G1 X-1 U-1 A-1 echo "Left" elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 G1 X1 U1 A1 Y-1 V-1 B-1 echo "Right and forward" elif sensors.gpIn[8].value=0; joystick right and backward M400 G1 X1 U1 A1 Y1 V1 B1 echo "Right and backwards" else ; joystick right only M400 G1 X1 U1 A1 echo "Right" elif sensors.gpIn[7].value=0 ; joystick forwards only M400 G1 Y-1 V-1 B-1 echo "Forward" elif sensors.gpIn[8].value=0 ; joystick backward only M400 G1 Y1 V1 B1 echo "Backwards" else break
You could use the built-in 'iterations' variable to adjust the movement amount and/or speed.
Would I be right in assuming the "iterations" is a counter which increments by 1 every time the while loop runs?Scratch that - found it.
That's all working now although the code is a bit "clunky".
I'm guessing that once variables are introduced, I ought to be able to do something like ....
MoveAmount= 0.5+(iterations/5) G1 X MoveAmount..............
.......or some such. Anyway, this is what I've ended up with which may not be elegant but works.
G91; Set relative M400; wait for any moves to finish G1 F3000 ; set feedrate to 100mm/sec M118 S"Trigger 5 - Joystick" while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 if iterations<3 G1 X-0.5 U-0.5 A-0.5 Y-0.5 V-0.5 B-0.5 elif iterations<5 G1 X-1 U-1 A-1 Y-1 V-1 B-1 elif iterations<7 G1 X-2 U-2 A-2 Y-2 V-2 B-2 elif iterations<9 G1 X-5 U-5 A-5 Y-5 V-5 B-5 elif iterations<11 G1 X-10 U-10 A-10 Y-10 V-10 B-10 else G1 X-20 U-20 A-20 Y-20 V-20 B-20 elif sensors.gpIn[8].value=0; joystick left and backwards M400 if iterations<3 G1 X-0.5 U-0.5 A-0.5 Y0.5 V0.5 B0.5 elif iterations<5 G1 X-1 U-1 A-1 Y1 V1 B1 elif iterations<7 G1 X-2 U-2 A-2 Y2 V2 B2 elif iterations<9 G1 X-5 U-5 A-5 Y5 V5 B5 elif iterations<11 G1 X-10 U-10 A-10 Y10 V10 B10 else G1 X-20 U-20 A-20 Y20 V20 B20 else ; joystick left only M400 if iterations<3 G1 X-0.5 U-0.5 A-0.5 elif iterations<5 G1 X-1 U-1 A-1 elif iterations<7 G1 X-2 U-2 A-2 elif iterations<9 G1 X-5 U-5 A-5 elif iterations<11 G1 X-10 U-10 A-10 else G1 X-20 U-20 A-20 elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 if iterations<3 G1 X0.5 U0.5 A0.5 Y-0.5 V-0.5 B-0.5 elif iterations<5 G1 X1 U1 A1 Y-1 V-1 B-1 elif iterations<7 G1 X2 U2 A2 Y-2 V-2 B-2 elif iterations<9 G1 X5 U5 A5 Y-5 V-5 B-5 elif iterations<11 G1 X10 U10 A10 Y-10 V-10 B-10 else G1 X20 U20 A20 Y-20 V-20 B-20 elif sensors.gpIn[8].value=0; joystick right and backward M400 if iterations<3 G1 X0.5 U0.5 A0.5 Y0.5 V0.5 B0.5 elif iterations<5 G1 X1 U1 A1 Y1 V1 B1 elif iterations<7 G1 X2 U2 A2 Y2 V2 B2 elif iterations<9 G1 X5 U5 A5 Y5 V5 B5 elif iterations<11 G1 X10 U10 A10 Y10 V10 B10 else G1 X20 U20 A20 Y20 V20 B20 else ; joystick right only M400 if iterations<3 G1 X0.5 U0.5 A0.5 elif iterations<5 G1 X1 U1 A1 elif iterations<7 G1 X2 U2 A2 elif iterations<9 G1 X5 U5 A5 elif iterations<11 G1 X10 U10 A10 else G1 X20 U20 A20 elif sensors.gpIn[7].value=0 ; joystick forwards only M400 if iterations<3 G1 Y-0.5 V-0.5 B-0.5 elif iterations<5 G1 Y-1 V-1 B-1 elif iterations<7 G1 Y-2 V-2 B-2 elif iterations<9 G1 Y-5 V-5 B-5 elif iterations<11 G1 Y-10 V-10 B-10 else G1 Y-20 V-20 B-20 elif sensors.gpIn[8].value=0 ; joystick backward only M400 if iterations<3 G1 Y0.5 V0.5 B0.5 elif iterations<5 G1 Y1 V1 B1 elif iterations<7 G1 Y2 V2 B2 elif iterations<9 G1 Y5 V5 B5 elif iterations<11 G1 Y10 V10 B10 else G1 Y20 V20 B20 else break
Another way is to use your original code but replace all the XYUVABC coordinates in the G1 commands by calculated values, something like this:
G1 X{0.5+0.1 * iterations} Y{-(0.5+0.1 * iterations)} ...
Ahhh - that looks good! I tried something similar but it didn't work - because I used plain braces rather than curly ones. I'll give that a go..............
For the sake of completeness, here is the final code that I ended up using. After playing around with it, I ended up using just G1 X{0.5+interations}........etc, rather than using fraction's of "iterations".
G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec M118 S"Trigger 5 - Joystick" while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)} echo "Left and forward" elif sensors.gpIn[8].value=0; joystick left and backwards M400 G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations} echo "Left and backwards" else ; joystick left only M400 G1 X{-(0.5+iterations)} U{-(0.5+iterations)} A{-(0.5+iterations)} echo "Left" elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)} echo "Right and forward" elif sensors.gpIn[8].value=0; joystick right and backward M400 G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations} echo "Right and backwards" else ; joystick right only M400 G1 X{0.5+iterations} U{0.5+iterations} A{0.5+iterations} echo "Right" elif sensors.gpIn[7].value=0 ; joystick forwards only M400 G1 Y{-(0.5+iterations)} V{-(0.5+iterations)} B{-(0.5+iterations)} echo "Forward" elif sensors.gpIn[8].value=0 ; joystick backward only M400 G1 Y{0.5+iterations} V{0.5+iterations} B{0.5+iterations} echo "Backwards" else break
Thanks for all the help guys.
For further completeness, I've added a "turbo button". So instead of increasing the distance using "iterations", I simply press the button in conjunction with moving the joystick. What that does is move the gantries 20mm if the button is pressed or 0.5mm if it isn't. I prefer this method but either one works.
I've also wrapped the entire thing in a "if state.status != "processing"" statement (thanks for the suggestion @T3P3Tony). What that does is checks to make sure that a print is NOT in progress which will do what the M581 R2 parameter will do in the next firmware. Here is that version of the code
if state.status != "processing" ; make sure that a print is NOT running G91; Set relative M400; wait for any moves to finish G1 F3000 ; set feedrate to 100mm/sec M118 S"Trigger 5 - Joystick" while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 echo "Left and forward" if sensors.gpIn[4].value=0 ; check for long move button press G1 X-20 U-20 A-20 Y-20 V-20 B-20 else G1 X-0.5 U-0.5 A-0.5 Y-0.5 V-0.5 B-0.5 elif sensors.gpIn[8].value=0; joystick left and backwards M400 echo "Left and backwards" if sensors.gpIn[4].value=0 ; check for long move button press G1 X-20 U-20 A-20 Y20 V20 B20 else G1 X-0.5 U-0.5 A-0.5 Y0.5 V0.5 B0.5 else ; joystick left only M400 echo "Left" if sensors.gpIn[4].value=0 ; check for long move button press G1 X-20 U-20 A-20 else G1 X-0.5 U-0.5 A0.5 elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 echo "Right and forward" if sensors.gpIn[4].value=0 ; check for long move button press G1 X20 U20 A20 Y-20 V-20 B-20 else G1 X0.5 U0.5 A0.5 Y-0.5 V-0.5 B-0.5 elif sensors.gpIn[8].value=0; joystick right and backward M400 echo "Right and backwards" if sensors.gpIn[4].value=0 ; check for long move button press G1 X20 U20 A20 Y20 V20 B20 else G1 X0.5 U0.5 A0.5 Y0.5 V0.5 B0.5 else ; joystick right only M400 echo "Right" if sensors.gpIn[4].value=0 ; check for long move button press G1 X20 U20 A20 else G1 X0.5 U0.5 A0.5 elif sensors.gpIn[7].value=0 ; joystick forwards only M400 echo "Forward" if sensors.gpIn[4].value=0 ; check for long move button press G1 Y-20 V-20 B-20 else G1 Y-0.5 V-0.5 B-0.5 elif sensors.gpIn[8].value=0 ; joystick backward only M400 echo "Backwards" if sensors.gpIn[4].value=0 ; check for long move button press G1 Y20 V20 B20 else G1 Y0.5 V0.5 B0.5 else break else break
@deckingman I have followed this with interest but then I thought what was the actual problem? When I use the XY buttons in DWC my main XY and UV carriages move together and in sync. Have I not understood the problem?
