    3.2 beta 2 and 3 strange behaviour during movements
    Beta Firmware
    837
    • Touchthebitumundefined
      Touchthebitum @Veti
      @Veti said in Nema17 strange behaviour during movements:
      the offset is wrong. there is no way a bltouch can be this close to the nozzle.
      it has 3.5cm as offset so I think I have to convert in mm (35mm), right ?
      Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
      BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
        Touchthebitum @Veti
        can you put the motors into spreadcyle and test?
        I don't know how which value to change 😞
        • Vetiundefined
          Veti @Touchthebitum
          @Touchthebitum said in Nema17 strange behaviour during movements:
          yes.
          what carriage are you using?
          M569 P0 D2
          M569 P1 D2
          M569 P2 D2
          M569 P3 D2
          M569 P4 D2
          Touchthebitumundefined 1 Reply Last reply Reply Quote 0
            Touchthebitum @Veti
            yes.
            M569 P0 D2
            M569 P1 D2
            M569 P2 D2
            M569 P3 D2
            M569 P4 D2
            I use the BLV Hotend Mosquito NF-Crazy BLtouch version.
              Touchthebitum @Touchthebitum
              M569 P0 D2
              M569 P1 D2
              M569 P2 D2
              M569 P3 D2
              M569 P4 D2
              same results ... still present
              I have to try to turn back on 3.1.1 but it is not simple to turn back from the beta. It doesn't connect anymore
                In your video your belts look to be very loose which could lead to skipping on the idler teeth. I think that's your main problem.
                Touchthebitumundefined 2 Replies Last reply Reply Quote 0
                  Touchthebitum @Phaedrux
                  @Phaedrux said in Nema17 strange behaviour during movements:
                  Ok, I'll check that. Thanks 😉
                    I tried to tight the belts but it is the same. When I move the carriage (printer powered off) with my hand, the movements are smooth.
                      So the belts aren't flopping around loose anymore?
                      Can you post a video of the motion now?
                      It seems mechanical in nature. Check your belt paths closely.
                        When I thight too much, I hear mechanical noises. I have to tight a tensioner more than the other one to have a correct carriage symmetry.
                          I upgraded to the beta 3 and it seems better.
                          To be tested
                            To be tested
                            Unfotunately It was a short time success. It still loses steps.
                            I turned back to 3.1.1 and this time erverything disappeared. No lost steps anymore.
                              Thanks. I've moved to beta firmware forum for @chrishamm to see.
                              • chrishammundefined
                                chrishamm administrators
                                Try to install this experimental firmware build by uploading it on the Files -> System page and then confirm the update prompt. That should get you to RepRapFirmware 3.2-beta3+3-ch (check on the Settings -> Machine page).
                                Please let me know if that resolves your problem.
                                Duet software engineer
                                  @Phaedrux said in 3.2 beta 2 and 3 strange behaviour during movements:
                                  Thanks
