    Formbot Troodon RRF 3.1.1 Update
    Firmware installation
    22
    89
    8.8k
    • Robthide37undefined
      Robthide37 @pixelpieper
      @pixelpieper it def seems perfect it is more in line with duet 2 imo right ?
      • FlyByWireundefined
        FlyByWire
        Sorry for getting off-topic.
        I consider the Formbot Troodon to be my next 3D printer. I actually have some experience with the Snapmaker 2.0. I'm looking for a machine wit x/y core, large build volume, enclosure,..
        But I'm mainly looking for a machine, that is working without much tinkering.
        Is the Troodon that machine?
        I meanwhile found out, that there is no support concerning firmware from the company. I'm not afraid of doing some guided software updates, but that's it.
        Phaedruxundefined nomukaikiundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @FlyByWire
          @FlyByWire said in Formbot Troodon RRF 3.1.1 Update:
          Given that there is currently no working firmware beyond 3.0 I don't think the troodon would be a good choice.
          FlyByWireundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti
            the hardware nice. some thoughts on the printer.
            the voron team advises against a size bigger than 350x350 for corexy because of belt problem. so the smaller version will be the better choice.
            custom duet board. this could potentialy mean that you will need to replace it at some point with a duet 3 + toolboard. (or duet 3 mini 5 + addonboard). this will require a little bit of tinkering, mainly switching connector housing and re crimping a few ends.
              FlyByWire @Veti
              @Veti said in Formbot Troodon RRF 3.1.1 Update:
              Honestly I have limited knowledge of 3D printer hardware. I think I could manage some tinkering with a community in the background where there are "guides" on how-to. In case of the Troodon I have the feeling it's hard to find other users who could help a newbie. Why will I have to change the board? And, maybe silly question, but what's wrong in using FW 3.0? Is that one buggy?
                FlyByWire @Phaedrux
                @Phaedrux said in Formbot Troodon RRF 3.1.1 Update:
                What would be your choice for the given needs?
                Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • Vetiundefined
                  Veti @FlyByWire
                  i would email them and ask them if they are planning a version with a duet 3.
                  but limited 3d printer knowledge should not stop you.
                  i got a 3d printer kit specially so that i had to build it from the ground up and learn about it.
                  there are some 3d printer that are tinker free, but they cost a lot of money
                  like the Ultimaker S5 or the fusion3 F410
                    I think your best bet would be to create a new thread in the general discussion forum to ask your question on printer recommendations. List your budget and requirements. There are lots of good options in various price ranges.
                    I can't recommend the Formbot Troodon because it uses a non-standard duet implementation and doesn't offer any firmware updates. It's definitely out of our scope to offer support for it.
                    Robthide37undefined 1 Reply Last reply Reply Quote 0
                      Robthide37 @Phaedrux
                      @Phaedrux Do you know the safest way to install klipper ? i am wanting to go to genuine duet wifi and run klipper for input shaping . or will you be adding input shaping anytime soon to rrf?
                      • PCRundefined
                        PCR
                        @Robthide37 https://duet3d.dozuki.com/Wiki/Gcode#Section_M593_Configure_Dynamic_Acceleration_Adjustment
                          Robthide37 @PCR
                          @PCR Thanks i have been using it for a while but my klipper printer uses input shaping which is much more robust instead of limiting accel at certain frequency it can have multiple freq and also does not alter accel profile at all so no speed loss or issues with corner rounding etc.
                            Phaedrux Moderator @Robthide37
                            @Robthide37 said in Formbot Troodon RRF 3.1.1 Update:
                            That would be a better question for a Klipper centric forum. I don't have any direct experience with Klipper.
                            As for input shaping, it's an interesting concept and is under investigation, but will have to wait until after RRF3 implementation has matured a bit more.
                            • nomukaikiundefined
                              nomukaiki @FlyByWire
                              I have many years of 3d printer experience and built my own delta printers with duet boards. I was going to build a Voron because they seem (to me) they are possibly the best corexyz design. Because of the lockdown getting all the parts looked to be challenging so I decided to get a Formbot Troodon and would (again) adapt and improve whatever I needed.
                              To my surprise, it worked great out of the box and I don't get the need to change anything (yet). I did try to upgrade to the latest RRF 3+ but it was too much of a hassle with reduced value, since the machine was working beautifully well with the v2.
                              I will change some of the hardware eventually, like using a direct drive extrusion, and possibly the board, but only if there are clear benefits which I don't see it at the moment.
                              • Vetiundefined
                                Veti @nomukaiki
                                @nomukaiki
                                btw i just came across this on singles day
                                https://de.aliexpress.com/item/1005001515387922.html
                                nomukaikiundefined 1 Reply Last reply Reply Quote 0
                                  nomukaiki @Veti
                                  @nomukaiki
                                  We should start another topic to share info about Troodon/Voron printers!
                                  But thanks for sharing the link, great finding! I definitely need that upgrade!
                                    FlyByWire
                                    @nomukaiki: Thanks, meanwhile I did order an Troodon 300 too. I will upgrade to DDE, but good to hear that the machine is working nice out of the box!
                                      @Phaedrux k i installed klipper and had two things one is i found out that its reading the stallgaurd as short to ground on coil b so it is something with teh way the external steppers connect the diag pin or maybe diff sense resistor. so should be able disable the sg registers and then would work i think . And the other thing is do you knwo what pin the mcu temp is on cuase in rrf its predefined but i don't know if its spi bus or if its just a themistor on a internal pin ?
                                        @Robthide37 Probably best to start a new thread with your questions.
                                        • mikejr83undefined
                                          mikejr83
                                          Hi all! I just finished reading through the thread. I'd really like to pick up a Troodon. They're on sale at the moment! I had been looking to get a Voron or clone but want to order one "thing", be it a partial assembled printer or whole kit, and assemble it as opposed to ordering parts from vendor X and other stuff from vendor Y. I figured that the Troodon would be the closest I could get.
                                          Anyhow, I stumbled on this thread while attempting to perform some due diligence. As others have noted there is no firmware download located on their website. This concerned me and Googling for "Troodon Firmware" presents this thread as the first result.
                                          I thought I would add my voice in for wondering about where the current situation is with respect to newer firmware versions appearing on this machine. I obviously do not expect the Duet3D project and maintainers to be investing a large amount of time or effort supporting a cloned product, and I applaud the helpful questions and answers that are here. I am more wondering: Is there is any active work trying to debug it or the situation is more in Vivedino's court?
                                          One last thing, for those of you who have this printer, what is your perception on the level of difficulty in changing the current controller out to an official Duet setup? I had hoped that if the board with the Troodon was a clone that they would at least have used similar connectors to the point where it the only hassle would be mounting the required two Duet boards.
                                          One thing about these "cheaper" printers is that they use these clone parts. It keeps the price down and I don't mind it so much. However, as I get accustomed to the printer I almost always replace the cloned parts for the real deal. For instance, I'm not going to bother with their Mosquito clone. I'd much rather get the real one from Slice Engineering and support them. Suffice to say, I hope to do the same with the board regardless of the ability to get Vivedino firmware updates or make my own. My large concern is that I'm now seeing that the version of firmware on this printer is a major revision old. I'd like to at least be able to get to a later version before I introduced the change in hardware.
                                          Thanks again for everyone contributing to the conversation!
                                          • Vetiundefined
                                            Veti @mikejr83
                                            @mikejr83 said in Formbot Troodon RRF 3.1.1 Update:
                                            it depends which duet you are gonna get.
                                            obviously i cant say anything about mounting the board itself.
                                            assuming that you would want to get a duet 3 when upgrading, you will need to recrimpt the connectors for the motors, paneldue and hotend connectors. the fan connectors can stay the same, but you need to change the housing on the endstop probe connectors.
                                            the config you can take as a starting and need to change the pin names.
                                            i dont think it will be that much work.
