Slow upload rates and connection errors
Duet Web Control
787
    WillGIam
    Hello!
    After being totally frustrated I´m trying to find some help in here.
    I have 3-4 printers with duet 2 or duet 3. All of them are working fine. Today I finished my newest build and updated everything on the duet. After getting a blank screen, I tried different DWC versions and when updating again I got it running.
    The whole file upload is very slow, often I´m getting connection errors and when starting heater auto tuning for example I´m just getting this error:
    Connection interrupted, attempting to reconnect...
    HTTP request timed out
    I tried nearly everything, restartet router, restartet board, scanned the wifis and changed to channel 1 with my router - nothing helped.
    Now I´m getting the blank screen again... connection via pronterface works fine...
    I hope you can help me.
    William
      WillGIam
      M122 says
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SD-6J1FA-3S86P-9BMMF
      Used output buffers: 1 of 24 (12 max)
      Static ram: 23996
      Dynamic ram: 100424 of which 56 recycled
      Never used RAM 5572, free system stack 174 words
      Tasks: NETWORK(ready,210) HEAT(blocked,306) MAIN(running,415) IDLE(ready,19)
      Owned mutexes: USB(MAIN)
      Last reset 00:04:21 ago, cause: power up
      Last software reset at 2020-11-11 19:05, reason: User, GCodes spinning, available RAM 6356, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0x00
      Error status: 0x00
      MCU temperature: min 33.2, current 33.6, max 33.9
      Supply voltage: min 22.9, current 22.9, max 23.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2020-11-11 20:03:12
      Cache data hit count 423162907
      Slowest loop: 3.53ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 2.2ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 4.01ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.24
        WiFi MAC address cc:50:e3:6a:87:e4
        WiFi Vcc 3.31, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25248
        WiFi IP address 192.168.0.173
        WiFi signal strength -58dBm, reconnections 1, sleep mode modem
        Clock register 00002002
      undefined 1 Reply Last reply 11 Nov 2020, 19:28 Reply Quote 0
        Phaedrux Moderator @WillGIam
        @WillGIam said in Slow upload rates and connection errors:
        Do you get the same problems when running 3.1.1?
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
        The wifi server version in 3.2beta2 is updated (1.24) and you don't mention any firmware versions.
        If you upload that complete zip file to the system tab in DWC it should flash everything back for testing.
          WillGIam
          Hey Phaedrux,
          Thanks for your reply.
          Server FW is 1.24, as you see in my comment. Also you can see, that I was using 3.2-beta3.
          Because I´m not able to upload anything on DWC, I have to change the files on SD.
          I changed the Duet2CombinedFirmware to the 3.1.1 and the DWC too. -- still blank.
          After a while I´m getting the DWC (instead of blank screen) and can do something, but not uploading.
          After putting 3.1.1 and DWC on SD I got no system drop down settings, but it seems as I´m now able to upload a firmware file without breakdown. - Lets see what happens.
            Can you place this wifi server bin file on the SD card in the /sys folder and then send M997 S1 to flash the module back to 1.23?
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
              WillGIam
              Hey Phaedrux,
              == Diagnostics ===
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
              Used output buffers: 1 of 24 (11 max)
              Static ram: 27980
              Dynamic ram: 93836 of which 84 recycled
              Exception stack ram used: 312
              Never used ram: 8860
              Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:01:15 ago, cause: software
              Last software reset details not available
              Error status: 0
              Error status: 0
              MCU temperature: min 32.2, current 32.8, max 33.1
              Date/time: 2020-11-11 20:53:38
              Cache data hit count 170296728
              Slowest loop: 7.05ms; fastest: 0.14ms
              === Storage ===
              SD card longest read time 2.8ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              === AuxDDARing ===
              Segments left: 0
              === Network ===
              Slowest loop: 1167.20ms; fastest: 0.00ms
              Responder states: HTTP(1) HTTP(1) HTTP(1) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                WiFi firmware version 1.23
                WiFi Vcc 3.32, reset reason Unknown
                WiFi flash size 4194304, free heap 24280
                WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                Socket states: 2 2 2 0 0 0 0 0
              I flashed everything back to 3.1.1 and Server to 1.23, but still the same problems.
              Could a board erase help?
              undefined undefined 2 Replies Last reply 11 Nov 2020, 20:00 Reply Quote 0
                WillGIam
                Thats what it looks like most of the time. After a while DWC appears, but very slow with connection breaks.
                  Doubtful, since we've already flashed the firmware again.
                  When you send M997 S1 does the flash process appear to proceed correctly with a percentage complete list?
                  When you lose connection, does the light on the module go out?
                  Can you create these macros and use them to clear the saved networks and reset the module with your SSID?
                  ; Clear all wifi networks
                  M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
                  M552 S0 ; Disable network module
                  G4 S5 ; wait 5 seconds
                  M588 S"*" ; Clear all saved wifi networls
                  M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
                  ; Add default wifi network
                  M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
                  M587 S"NETWORKNAME" P"PASSWORD" ; Add duet wifi SSID to remembered networks list
                  M552 S1 ; reenable wifi module
                  M291 R"duetwifi SSID added." P"Check console to verify IP address."
                  IT's easier to use the macros because you can execute them from command line more easily than retyping everything. Just send M98 P"macroname" to run them.
                  undefined 1 Reply Last reply 11 Nov 2020, 20:04 Reply Quote 0
                    Is this a brand new duet wifi? When and where was it purchased?
                    undefined 1 Reply Last reply 11 Nov 2020, 20:33 Reply Quote 0
                      WillGIam @Phaedrux
                      @Phaedrux said in Slow upload rates and connection errors:
                      Well...
                      Yes.
                      No. its still on.
                      will do that now.
                      thanks a lot.
                        dc42 administrators @WillGIam
                        @WillGIam, are you certain that there isn't another device using that IP address? Try pinging it. Then turn the Duet off and try pinging it again.
                          WillGIam @Phaedrux
                          Tried to clear all networks and added it again - same problem.
                          I dont really know when and where this duet was bought...
                          @dc42 said in Slow upload rates and connection errors:
                          Yes. When duet is turned off, there is a timeout.
                          undefined 1 Reply Last reply 11 Nov 2020, 21:45 Reply Quote 0
                            Does the Duet show up in the router interface?
                            That would make it difficult to ascertain it's warranty status. If it's within 6 months from an authorized reseller you would be covered.
                            undefined 1 Reply Last reply 16 Nov 2020, 19:09 Reply Quote 0
                              WillGIam @Phaedrux
                              @Phaedrux Yes, it shew up in the router interface.
                              Yes, I´m not covered I think. I dont think its a hardware issue - I tried nearly everything now.
                                Only other thing I can think of is to try a new SD card in case it's having problems reading the file system.
                                8 out of 15
