    Slow upload rates and connection errors
    Duet Web Control
    788
    • WillGIamundefined
      WillGIam
      Hey Phaedrux,
      Thanks for your reply.
      Server FW is 1.24, as you see in my comment. Also you can see, that I was using 3.2-beta3.
      Because I´m not able to upload anything on DWC, I have to change the files on SD.
      I changed the Duet2CombinedFirmware to the 3.1.1 and the DWC too. -- still blank.
      After a while I´m getting the DWC (instead of blank screen) and can do something, but not uploading.
      After putting 3.1.1 and DWC on SD I got no system drop down settings, but it seems as I´m now able to upload a firmware file without breakdown. - Lets see what happens.
        Can you place this wifi server bin file on the SD card in the /sys folder and then send M997 S1 to flash the module back to 1.23?
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
        • WillGIamundefined
          WillGIam
          Hey Phaedrux,
          == Diagnostics ===
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-9T6BU-FG3SD-6J1FA-3S86P-9BMMF
          Used output buffers: 1 of 24 (11 max)
          Static ram: 27980
          Dynamic ram: 93836 of which 84 recycled
          Exception stack ram used: 312
          Never used ram: 8860
          Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:01:15 ago, cause: software
          Last software reset details not available
          Error status: 0
          Error status: 0
          MCU temperature: min 32.2, current 32.8, max 33.1
          Supply voltage: min 22.9, current 22.9, max 23.0, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-11-11 20:53:38
          Cache data hit count 170296728
          Slowest loop: 7.05ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 2.8ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "M122" in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 1167.20ms; fastest: 0.00ms
          Responder states: HTTP(1) HTTP(1) HTTP(1) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address cc:50:e3:6a:87:e4
            WiFi Vcc 3.32, reset reason Unknown
            WiFi flash size 4194304, free heap 24280
            WiFi IP address 192.168.0.173
            WiFi signal strength -55dBm, reconnections 0, sleep mode modem
            Socket states: 2 2 2 0 0 0 0 0
          I flashed everything back to 3.1.1 and Server to 1.23, but still the same problems.
          Could a board erase help?
          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • WillGIamundefined
            WillGIam
            Thats what it looks like most of the time. After a while DWC appears, but very slow with connection breaks.
              Phaedrux Moderator @WillGIam
              @WillGIam said in Slow upload rates and connection errors:
              Doubtful, since we've already flashed the firmware again.
              When you send M997 S1 does the flash process appear to proceed correctly with a percentage complete list?
              When you lose connection, does the light on the module go out?
              Can you create these macros and use them to clear the saved networks and reset the module with your SSID?
              ; Clear all wifi networks
              M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
              M552 S0			; Disable network module
              G4 S5			; wait 5 seconds
              M588 S"*"			; Clear all saved wifi networls
              M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
              ; Add default wifi network
              M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
              M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
              M552 S1			; reenable wifi module
              M291 R"duetwifi SSID added." P"Check console to verify IP address."
              IT's easier to use the macros because you can execute them from command line more easily than retyping everything. Just send M98 P"macroname" to run them.
              WillGIamundefined 1 Reply Last reply Reply Quote 0
                Is this a brand new duet wifi? When and where was it purchased?
                • WillGIamundefined
                  WillGIam @Phaedrux
                  @Phaedrux said in Slow upload rates and connection errors:
                  Well...
                  Yes.
                  No. its still on.
                  will do that now.
                  thanks a lot.
                    dc42 administrators @WillGIam
                    @WillGIam, are you certain that there isn't another device using that IP address? Try pinging it. Then turn the Duet off and try pinging it again.
                    • WillGIamundefined
                      WillGIam @Phaedrux
                      Tried to clear all networks and added it again - same problem.
                      I dont really know when and where this duet was bought...
                      @dc42 said in Slow upload rates and connection errors:
                      Yes. When duet is turned off, there is a timeout.
                        Does the Duet show up in the router interface?
                        That would make it difficult to ascertain it's warranty status. If it's within 6 months from an authorized reseller you would be covered.
                        • WillGIamundefined
                          WillGIam @Phaedrux
                          @Phaedrux Yes, it shew up in the router interface.
                          Yes, I´m not covered I think. I dont think its a hardware issue - I tried nearly everything now.
                            Only other thing I can think of is to try a new SD card in case it's having problems reading the file system.
