    Slow upload rates and connection errors
    Duet Web Control
    788
      Can you place this wifi server bin file on the SD card in the /sys folder and then send M997 S1 to flash the module back to 1.23?
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
      • WillGIamundefined
        WillGIam
        Hey Phaedrux,
        Thanks for your reply.
        == Diagnostics ===
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-9T6BU-FG3SD-6J1FA-3S86P-9BMMF
        Used output buffers: 1 of 24 (11 max)
        Static ram: 27980
        Dynamic ram: 93836 of which 84 recycled
        Exception stack ram used: 312
        Never used ram: 8860
        Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:01:15 ago, cause: software
        Last software reset details not available
        Error status: 0
        Error status: 0
        MCU temperature: min 32.2, current 32.8, max 33.1
        Supply voltage: min 22.9, current 22.9, max 23.0, under voltage events: 0, over voltage events: 0, power good: yes
        Date/time: 2020-11-11 20:53:38
        Cache data hit count 170296728
        Slowest loop: 7.05ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 2.8ms, write time 0.0ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
        === MainDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is ready with "M122" in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 1167.20ms; fastest: 0.00ms
        Responder states: HTTP(1) HTTP(1) HTTP(1) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address cc:50:e3:6a:87:e4
          WiFi Vcc 3.32, reset reason Unknown
          WiFi flash size 4194304, free heap 24280
          WiFi IP address 192.168.0.173
          WiFi signal strength -55dBm, reconnections 0, sleep mode modem
          Socket states: 2 2 2 0 0 0 0 0
        I flashed everything back to 3.1.1 and Server to 1.23, but still the same problems.
        Could a board erase help?
        Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • WillGIamundefined
          WillGIam
          Thats what it looks like most of the time. After a while DWC appears, but very slow with connection breaks.
            Phaedrux Moderator @WillGIam
            @WillGIam said in Slow upload rates and connection errors:
            Doubtful, since we've already flashed the firmware again.
            When you send M997 S1 does the flash process appear to proceed correctly with a percentage complete list?
            When you lose connection, does the light on the module go out?
            Can you create these macros and use them to clear the saved networks and reset the module with your SSID?
            ; Clear all wifi networks
            M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
            M552 S0			; Disable network module
            G4 S5			; wait 5 seconds
            M588 S"*"			; Clear all saved wifi networls
            M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
            ; Add default wifi network
            M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
            M587 S"NETWORKNAME" P"PASSWORD"			; Add duet wifi SSID to remembered networks list
            M552 S1			; reenable wifi module
            M291 R"duetwifi SSID added." P"Check console to verify IP address."
            IT's easier to use the macros because you can execute them from command line more easily than retyping everything. Just send M98 P"macroname" to run them.
            WillGIamundefined 1 Reply Last reply Reply Quote 0
              Is this a brand new duet wifi? When and where was it purchased?
              • WillGIamundefined
                WillGIam @Phaedrux
                @Phaedrux said in Slow upload rates and connection errors:
                Well...
                Yes.
                No. its still on.
                will do that now.
                thanks a lot.
                  dc42 administrators @WillGIam
                  @WillGIam, are you certain that there isn't another device using that IP address? Try pinging it. Then turn the Duet off and try pinging it again.
                  • WillGIamundefined
                    WillGIam @Phaedrux
                    Tried to clear all networks and added it again - same problem.
                    I dont really know when and where this duet was bought...
                    @dc42 said in Slow upload rates and connection errors:
                    Yes. When duet is turned off, there is a timeout.
                      Does the Duet show up in the router interface?
                      That would make it difficult to ascertain it's warranty status. If it's within 6 months from an authorized reseller you would be covered.
                      • WillGIamundefined
                        WillGIam @Phaedrux
                        @Phaedrux Yes, it shew up in the router interface.
                        Yes, I´m not covered I think. I dont think its a hardware issue - I tried nearly everything now.
                          Only other thing I can think of is to try a new SD card in case it's having problems reading the file system.
