    LED ON OFF Macro or Toogle
    Gcode meta commands
    9
    16
    1.9k
    • MacNiteundefined
      MacNite
      Hey guys,
      I want to turn on or off the LED in my printer. I've done this multiple times using a LED ON and a LED OFF macro.
      I am using a DUET2 Wifi with the most current built of RRF 3.1.1. (will upgrade to 3.2 after the beta-phase is over).
      Is it possible to use a single macro with an if-statement or something like that to turn on/off the LED?
      Thanks for your help,
      Max
      CorEssentials on GitHub | Instructables Profile | Thingiverse Profile
        jay_s_uk @MacNite
        @MacNite how do you have your LED set up?
        Can you post the relevant sections of the config and then we can help you with the conditional gcode required
        • MacNiteundefined
          MacNite
          Hey - thank you for your help. I am on a business trip right now - so I do not have access to my printer.
          But the code I use is something like that:
          config.g
          M950 P1 C"e1heat" Q500	;use heater 1 outupt for LED
          LED ON.g
          M42 P1 S1
          LED OFF.g
          M42 P1 S0
          Greets Max
          user M_123undefined 1 Reply Last reply Reply Quote 0
            jay_s_uk
            something along the lines of this should work
            if state.gpOut[1].pwm == 1
               M42 P1 S0
            else
               M42 P1 S1
            bubblevisorundefined 1 Reply Last reply Reply Quote 4
            • MacNiteundefined
              MacNite
              Sorry for the late response.
              I tested the code and it works absolutley flawless!
              Thank you for your help!
              • MauriceMundefined
                MauriceM
                hey, I would like to do exactly the same thing, I'm also on RRF3.1.1 but the gcode above doesn't work for me, it just turns the light on or off depending on what I enter, but I can't switch back and forth with one macro, do I need RRF3.2 or is it something else....
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @MauriceM
                  @MauriceM
                  You need to wire your LED to the same pin as shown in the code
                  EDIT:
                  When you say "back and forth", do you mean you want a single change or flashing ?
                  • MauriceMundefined
                    MauriceM
                    Yeah i changed the pin in the Command.
                    My target is it to press the button and the light will go on, and when i press the button again the light turns off.
                    But it does only one. depends on how i configure it.
                    BoAundefined 1 Reply Last reply Reply Quote 0
                    • BoAundefined
                      BoA @MauriceM
                      @MauriceM Configure trigger for the button, and put this gcode in trigger#.g
                      • Krohm Koalaundefined
                        Krohm Koala
                        I've done basically the same thing except, i've configured it as a fan, here's my code (include PSU Control)
                        if fans[3].actualValue == 0
                            M80
                            M106 P3 S1.0
                        else
                            M106 P3 S0
                            M81 S1
                        • MacNiteundefined
                          MacNite
                          I've got a new question....is there some kind of "list" of parameters I may refer to?
                          At the moment I want to built a calibration routine for a dual extruder printer.
                          For this I want to check wether filament is loaded. If filament is not loaded, I want to load PLA, if filament is loaded, the routine should continue.
                          See here for more Info on the calibration routine I want to built.
                          https://forum.duet3d.com/topic/21737/rrf3-dual-extruder-calibration-tool-and-nozzle-offset?_=1614175374759
                          Thanks
                          Max
                            In 3.2 there is a DWC plugin for browsing the object model, does that count as a list?
                            • user M_123undefined
                              user M_123 @MacNite
                              This post is deleted!
                                jay_s_uk @user M_123
                                @user-m_123 said in LED ON OFF Macro or Toogle:
                                @jay_s_uk hey
                                i want to on led when my print is stop so can i use this into stop.g????
                                Sure
                                  user M_123 @jay_s_uk
                                  • bubblevisorundefined
                                    bubblevisor @jay_s_uk
                                    @jay_s_uk said in LED ON OFF Macro or Toogle:
                                    if state.gpOut[1].pwm == 1 M42 P1 S0 else M42 P1 S1
                                    Just updated all 7 of my printers with this!!
