    Giant Delta printer Slow Homing issue.
    My Duet controlled machine
    8
    84
    3.4k
    • sozkanundefined
      sozkan @jay_s_uk
      @jay_s_uk said in Giant Delta printer Slow Homing issue.:
      @sozkan this is the same issue you had when you didn't use P5, 6, 7 and 8 as instructed.
      As you've indicated you've gone back to using the wrong numbers, of course your homing won't work correctly.
      Us the correct motor P numbers otherwise we're never going to be able to help you
      Thanks for your concern, but if you have seen above the P5, 6, 7 and 8 I have tried several times. It is in my mind always. The correct numbers P5, 6, 7 and 8. But I tried today as well. I did not work!
      After setting up this recommend number, horrible sound even after the home. and moves are not calibrated. I don`t know why G91 moves even did not work correctly. I can make a video tomorrow about what exactly the difference.
      The present setting is are accidentally working fine but after home smoothly. I am not fun of numbers. If the recommended numbers works, Why I wouldn't?
        Please post the exact M569 command you used with P5, P6, P7 and P8.
        The "horrible noise" you mentioned might be caused by the motors recognising the commands but trying to move too fast, because of an error in the steps/mm setting, or the microstepping setting you are using on the external driver.
        What switch settings are you using on those drivers?
        Have you tested the motors individually as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_and_endstops_individually ?
        sozkanundefined 1 Reply Last reply Reply Quote 0
        • sozkanundefined
          sozkan @dc42
          These are the present settings working smoothly after home.
          M569 P5 S0 R0 T3:3:5:0                                       ; Extruder drive 0 goes Forward
          M569 P2 S1 R0 T2.5:2.5:6:6  ; X:A drive 1 goes Forward
          M569 P3 S1 R0 T2.5:2.5:6:6  ; Y:B drive 2 goes Forward
          M569 P4 S1 R0 T2.5:2.5:6:6  ; Z:C physical drive 3 goes Forward
          M584 X6 Y7 Z8 E5                                  			 ; set drive mapping
          M350 X0 Y0 Z0 E0 I0                                ; configure microstepping without interpolation
          M92 X114.29 Y114.29 Z114.29 E274.00                   ; set steps per mm (400/140) * 40 = 114.2857 ;; 400 step per rev ;; 140 mm one rev pulley ;;1:40 ratio gearbox
          I have tested individual axis as well both with these settings and another (Correct) one as well.
          However, I will do another youtube video to show you how it behaves.
          Steps / mm value is no different than earlier. Because I have added a locked 1:40 gearbox to keep axis from freefall.
          Switch settings on driver 400 pulse/revolution.
          • sozkanundefined
            sozkan @sozkan
            @sozkan
            I have made a video on youtube to compare drive mapping the working accidental settings and recommended settings P values.
            https://www.youtube.com/watch?v=tJFbPPyj9F0
            By the way, I keep the Extruder value( P5) as recommended. However, the extruder doesn't sound like cracking, but not calibrated moves in both settings. Since I don't know if the manufacturer (Dyze) gives the right settings, I don`t worry about the extruder now.
            • sozkanundefined
              sozkan
              Here the individual axis trial video on Youtube,
              https://www.youtube.com/watch?v=5fNw1B7A73g
              Accidental or Illegal parameters on P values trial:
              M569 P5 S0 R0 T3:3:5:0; Extruder drive 0 goes Forward
              M569 P1 S1 R0 T2.5:2.5:6:6; X: A drive 1 goes Forward
              M569 P2 S1 R0 T2.5:2.5:6:6; Y: B drive 2 goes Forward
              M569 P3 S1 R0 T2.5:2.5:6:6; Z: C physical drive 3 goes Forward
              M584 X6 Y7 Z8 E5
              M350 X0 Y0 Z0 E0 I0; configure microstepping without interpolation
              As Summary:
              These setting working smooth, but before home, G1 command working smoothly on all axis like;
              G91                         ; relative positioning
              G1 H2 X-100 Y-100 Z-100 F1000; go down a few mm
              But when individual command sent, It does not work correctly, like these command;
              G91; relative positioning
              G1 H2 X-100 F1000; go down a few mm
              Recommended Parameters on P values trial :
              M569 P6 S1 R0 T2.5:2.5:6:6  ; X:A drive 1 goes Forward
              M569 P7 S1 R0 T2.5:2.5:6:6  ; Y:B drive 2 goes Forward
              M569 P8 S1 R0 T2.5:2.5:6:6  ; Z:C physical drive 3 goes Forward
              M584 X6 Y7 Z8 E5
              All the move commands work the same with the only problem, the horrible sound(sign for incorrect steps), and incorrect calibration distance. It is basically running a shorter distance than the previous parameter.
                jay_s_uk
                can you also post a picture of the switch settings on the drivers please
                  jay_s_uk
                  and using 0 in M350 is invalid.
                  A value of at least 1 should be used for all axis. e.g.
                  M350 X1 Y1 Z1 E1 I0
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
                  • sozkanundefined
                    sozkan @jay_s_uk
                    Default means 400 steps/Rev
                    WhatsApp Image 2020-11-12 at 11.42.47.jpeg WhatsApp Image 2020-11-12 at 11.42.47 (1).jpeg
                    • sozkanundefined
                      sozkan @jay_s_uk
                      M350 X1 Y1 Z1 E1 I0
                      It did not make difference. incorrect steps remain in this mode.
                        jay_s_uk
                        you've got the drivers set to 400 steps per mm, and i believe originally, you were looking at using 3200 steps per mm.
                        have you tried switching back to that?
                        That should reduce the amount of noise you are hearing
                        • sozkanundefined
                          sozkan @jay_s_uk
                          It was actually the previous setup. The sound and problem with the same setting remained at 3200 settings.
                          The reason 400 setting is on, I have added a 1:40 Gearbox. Therefore, 400 was an appropriate setting.
                          The new setup;
                          M92 X114.29 Y114.29 Z114.29 E274.00                   ; set steps per mm (400/140) * 40 = 114.2857 ; 400 step per rev ;; 140 mm one rev pulley ;1:40 ratio gearbox
                          However, It could be higher steps/mm with smoother settings variation, I would try. But Due to the high gearbox, it needs high-speed rotation to need on the motor. So, the lower step is lesser the signal density.
                          But the actual issue is not noise. Hearing noise is just a sign.
                          The actual issue is within the recommended P values noise into the signal output of the breakout board. I can connect an oscilloscope to prove it. Some missing steps cause less travel than the actual distance.
                          • sozkanundefined
                            sozkan
                            The Motor Control Problem resolved! ( interns of calibration and successful machine move ) ( But I still need your valuable help on bed calibration Should I open a new thread?)
                            Thank you very much for all your contribution.
                            Solution: I have just upgraded to the latest beta Firmware and DWC.
                            Conclusion:
                            But the configuration remains as (P 2-3-4) I was using. The recommended P 5-6-7-8 values causing problems. If it is not an issue with "Duet 2 Wifi r.104" It is something with the firmware I believe.
                            The Problem with recommended configuration P-values causing missing steps and noisy move. Each axis even the same amount moves command, they move different distances.
                            By the accidentally found settings and new Firmware update problem is over!
                            So this is the code that is working so far:
                            M569 P2 S1 R0 T2.5:2.5:6:6; X: A drive 1 goes Forward
                            M569 P3 S1 R0 T2.5:2.5:6:6; Y: B drive 2 goes Forward
                            M569 P4 S1 R0 T2.5:2.5:6:6; Z: C physical drive 3 goes Forward
                            M584 X6 Y7 Z8 E5; set drive mapping
                            M350 X1 Y1 Z1 E1 I1; configure microstepping without interpolation
                            • sozkanundefined sozkan referenced this topic
