    PanelDueFirmware 3.2.2 released
    PanelDue
    864
    • wilrikerundefined
      wilriker
      I am pleased to announce the release of PanelDueFirmware 3.2.2. Please excuse the inconvenience with broken 3.2.1.
      Version 3.2.2
      Upgrade Notes:
      • This release is compatible with RepRapFirmware 3.2-beta1 or later. It will partially work with RepRapFirmware 3.1.1 but not with any older version.
      • Flashing this release will reset the configuration to defaults
      Limitations
      • Due to the lack of RAM this build will not run on version 1 or early version 2 PanelDue boards that use the ATSAM3S2B chip.
        • Version 1.0, 1.1 and earlier v2 PanelDue: ATSAM3S2B processor (64MHz, 32kb RAM, 128kB flash) - these are the ones that the new firmware probably won't run on.
        • Version 2 PanelDue manufactured from August 2016: ATSAM3S4B processor (64MHz, 48kb RAM, 256kb flash). Will run the new firmware, but not as fast as version 3 will.
        • Version 3 PanelDue, including all 5i and 7i: ATSAM4S4B processor, 120MHz, 64kB RAM, 256kb flash. Will run the new firmware.
      • There will be no reliable status updates coming from RepRapFirmware while waiting for heaters to reach temperature (and some other cases) before RRF 3.2-beta4.
      New and changed features:
      • Babystep amount is configurable from preset values
      • When babystep buttons are pressed the value on the screen will be updated immediately and will be overwritten
        with the actual value on the next status update (usually these values should be equal anyway)
      • Feedrate for move buttons is configuratble from preset values
      • PanelDueFirmware does no longer distinguish between responses to M409 with and without K parameter. This prevents
        issues if values are moved from live to detail response or vice versa
      • Provide interface for RepRapFirmware to reset as well as erase and reset the PanelDue
      • Preparations to show more than one bed/one chamber
      Bug fixes:
      • Babystepping amount was not initialized
      Bug fixes since 3.2.1:
      • Setting babystep amount to the lowest value would invalidate stored settings on next start of PanelDue
      • A chamber could steal the second slot and status/temperatures would alternate between the tool and the chamber
      • A null pointer dereference could occur when RRF was restarted leading to a reset of PanelDueFirmware
      • State "Initializing" was replaced too early by "Idle"
      • Fetching the first bed/heater would not filter out invalidated entries
      • Under rare cicumstances it could happen that selectin a bed/chamber or setting temperatures for these could
        cause a restart of PanelDueFirmware
      Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.2.2
      Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      Manuel
      My Tool Collection
      Cavemanundefined Exerqtorundefined 2 Replies Last reply Reply Quote 3
      • Cavemanundefined
        Caveman @wilriker
        @wilriker I have a Paneldue 5i and when I try to update to 3.2.2 my screen just stuck @ connecting. Funny thing is that I can control the printer from screen. But there are absolutely no screen updates. Also the whole heater section is missing. When I flash 1.24 I have a normal working screen again. What could this be.
          Phaedrux Moderator @Caveman
          @Caveman What version of firmware are you running on the Duet?
          @wilriker said in PanelDueFirmware 3.2.2 released:
          • Cavemanundefined
            Caveman
            3.2 beta3
            • wilrikerundefined
              wilriker @Caveman
              @Caveman Can you please flash PanelDueFirmware again and see if this problem still exists?
              Also please make sure that the baud rate you configured on your Duet with M575 matches the baud rate set on your PanelDue. And of course that you enabled the Aux port via M575 in the first place.
              If that still does not work please connect a USB cable to your Duet, connect via serial terminal (if necessary see guide for initial Duet setup for instructions on how to do that) and issue
              M111 P3 S1
              You should see M409 commands coming in on channel Aux.
              Run
              M111 P3 S0
              before disconnecting USB.
              If you don't please return here and provide your config.g as well as the output of M122.
              Manuel
              My Tool Collection
              • Cavemanundefined
                Caveman
                Fixed with a reflash, strange tried that also yesterday but did not work. Fixed for now! thanks
                • Exerqtorundefined
                  Exerqtor @wilriker
                  Does this mean updating PanelDue firmware will be possible via DWC down the road? 😳 😬
                  • wilrikerundefined
                    wilriker @Exerqtor
                    @Exerqtor said in PanelDueFirmware 3.2.2 released:
                    I am working on that. But due to hardware limitations it will only work for v3 boards and 5i/7i. So much limitation I can already put forward.
                    Manuel
                    My Tool Collection
                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                    • Exerqtorundefined
                      Exerqtor @wilriker
                      @wilriker
                      Sweet! Given how cheap the V3 boards are it's not unobtainable for anyone atleast 🙂
                      • cgcaferundefined
                        cgcafer
                        I have a problem about on screen keyboard. I pressed any letter but no any visible feedback. When i close and re open keyboard all pressed letter can visible.
                        My board V3 and 7"
                        • wilrikerundefined
                          wilriker @cgcafer
                          @cgcafer Thanks for reporting. I can reproduce this issue. Actually that's a bug I already fixed in one of the 3.2.0 RCs but it seems to have returned.
                          Manuel
                          My Tool Collection
                          • cgcaferundefined
                            cgcafer
                            Thanks for your answer, i have also another problem that is about V2 board and 5"LCD.
                            it has no problem with V1.24 but not V3.2.2. It seems to like about lcd timing problem.
                            • wilrikerundefined
                              wilriker @cgcafer
                              @cgcafer I found the bug with the command input (actually a different problem to what I fixed in the RCs) and fixed it. I will release this probably later today.
                              Can you explain that with a bit more detail, please?
                              Manuel
                              My Tool Collection
                              • cgcaferundefined
                                cgcafer
                                https://drive.google.com/file/d/1JUmpmnN39RU9hgvowxu67gGC0sFneF2J/view?usp=sharing
                                https://drive.google.com/file/d/1BLFRYAHmChkUitGM5Tn8wXyLXaf9cAyy/view?usp=sharing
                                All V3 same result
                                • Exerqtorundefined
                                  Exerqtor
                                  I can also atest for the on screen keyboard acting up. If i write something it won't show up unless i hit backspace.
                                  • wilrikerundefined
                                    wilriker @Exerqtor
                                    @Exerqtor Thanks, I found and fixed that. I am right now working on improving overall update rate and will then release a new version.
                                    Manuel
                                    My Tool Collection
                                    • wilrikerundefined
                                      wilriker @cgcafer
                                      @cgcafer said in PanelDueFirmware 3.2.2 released:
                                      All V3 same result
                                      Thanks for reporting. I will analyze this issue but it may take a while. Sorry, I cannot give you a more short-term answer.
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker
                                        I have now released PanelDueFirmware 3.2.3. Please continue in this thread.
                                        Manuel
                                        My Tool Collection
                                        • wilrikerundefined
                                          wilriker
                                          @cgcafer Please check the latest release of PanelDueFirmware 3.2.4 if that fixes your issues on your V2 board.
                                          Manuel
                                          My Tool Collection
