    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • shattyundefined
      shatty
      M98 P"0:/macros/01-Test_IR_PD_Homing"
      Error: in file macro line 12 column 30: M906: array too long, max length = 1
      Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      • shattyundefined
        shatty
        The endstops are not telling the unit to stop moving. It hits the endstop switch and it still tries to move in that direction. But the endstops are functioning because I went to settings and machine specific and when i press them, the value changes
        • shattyundefined
          shatty
          This post is deleted!
          • Vetiundefined
            Veti @shatty
            @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
            11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
            this means that your homing files were created for an old version of the firmware.
            please generate new ones from the configurator.
            shattyundefined 1 Reply Last reply Reply Quote 0
            • shattyundefined
              shatty @Veti
              @Veti everything came from same zip. Every file except config.g and *.txt have same time stamps
              • Vetiundefined
                Veti @shatty
                @shatty
                post your homeall.g
                • shattyundefined
                  shatty
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
                  G91 ; relative positioning
                  G1 H1 X-355 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X5 Y5 F6000 ; go back a few mm
                  G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G90 ; absolute positioning
                  G1 X-1.3000000000000007 Y1 F6000 ; go to first bed probe point and home Z
                  ;G91 ; relative positioning
                  ;G90 ; absolute positioning
                  • Vetiundefined
                    Veti @shatty
                    @shatty
                    ok then the problem is in
                    post that.
                    where did you get that macro?
                    • shattyundefined
                      shatty
                      Recycling is tomorrow. Is the printer recyclable?
                      • shattyundefined
                        shatty @Veti
                        @Veti Dunno
                        E5Plus
                        Send code...
                        Status
                        Idle
                        Mode: FFF
                        Tool Position
                        X
                        0.0
                        Y
                        0.0
                        Z
                        0.00
                        Extruder Drives
                        Drive 0
                        0.0
                        Speeds
                        Requested Speed
                        0 mm/s
                        Top Speed
                        0 mm/s
                        Sensors
                        Vin
                        24.3 V
                        MCU Temperature
                        25.9 C
                        Z-Probe
                        0
                        Tools
                        Extra
                        Control All
                        Tool Heater Current Active Standby
                        Tool 0
                        T0 - Load Filament Heater 1
                        off 22.4 C
                        0
                        0
                        Bed Heater 0
                        off 21.9 C
                        0
                        0
                        Temperature Chart
                        Macros Directory
                        ; Test Routine for Duet WiFi and Ethernet June 2018 - Check IR Probe, PanelDue and endstops
                        ;Start logging
                        M929 P"test1log.txt" S1
                        M117 CHECK IR PROBE & PANELDUE THEN PRESS X ENDSTOP.
                        M577 X S2 ; wait for endstop to trigger
                        M577 X S0 ; wait for endstop release
                        ;----setup motors for test----
                        M906 X2000 Y2000 Z2000 E2000:2000 I100 ;set all motors to 2A with no idle current reduction
                        ;----homing line (tests endstops)----
                        M117 PRESS ALL THREE ENDSTOPS TO END HOMING
                        G91 ; use relative positioning
                        G1 S1 X3200 Y3200 Z3200 F9000 ; move XYZ motors, stopping when endstops are triggered
                        ;----end homing lines----
                        M117 GO ON TO TEST 02
                        • shattyundefined
                          shatty
                          The endless moving happens when I press home all and each axis independently
                          • Vetiundefined
                            Veti @shatty
                            @shatty
                            please dont use that macro, its not for your printer
                            • Vetiundefined
                              Veti
                              use M119
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                              to manually test your endstops.
                              if you can not get them to trigger, there is a problem with your wiring.
                              • shattyundefined
                                shatty @Veti
                                @Veti I tested endstops already under settings and machine specific. X and Y work
                                • Vetiundefined
                                  Veti
                                  replace that with
                                  G1 X50 Y50 F600
                                  when exactly does it try to move past the endstops?
                                  during the first move?
                                  • shattyundefined
                                    shatty @Veti
                                    @Veti Yes. I tried that setting and no good. Its random in which direction it goes to home and it just slams at the end of each axis.
                                    • shattyundefined
                                      shatty
                                      ; homeall.g
                                      G1 X50 Y50 F600 ; go to first bed probe point and home Z
                                      M550 P"E5Plus" ; set printer name
                                      M551 P"xxxx" ; set password
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P2 S0 ; physical drive 2 goes backwards
                                      M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
                                      M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X350 Y350 Z400 S0 ; set axis maxima
                                      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                      M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:190 Y15:190 S20 ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                      M143 H0 S110 ; set temperature limit for heater 0 to 110C
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                      M143 H1 S280 ; 280 deg max on hot end
                                      M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                                      • Vetiundefined
                                        Veti @shatty
                                        i have never heard of this happening.
                                        let me get this straight.
                                        you home your printer. it moves to the right?
                                        you restart the printer it moves to the left?
                                        post the output of M119 when no endstop is pressed.
                                        post the output of M119 when only the enstop for the x axis is pressed
                                        • shattyundefined
                                          shatty @Veti
                                          @Veti
                                          When I turn it on, nothing moves unless i press the home button. There is no telling which direction it will go if i center the extruder in the middle of the area. Where am I supposed to set the hotend before I turn on the printer?
                                          • Vetiundefined
                                            Veti @shatty
                                            @shatty
                                            please test the stepper motor direction using this
                                            https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                                            report for x y and z
