    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti @shatty
      @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
      11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
      this means that your homing files were created for an old version of the firmware.
      please generate new ones from the configurator.
      shattyundefined 1 Reply Last reply Reply Quote 0
      • shattyundefined
        shatty @Veti
        @Veti everything came from same zip. Every file except config.g and *.txt have same time stamps
        • Vetiundefined
          Veti @shatty
          @shatty
          post your homeall.g
          • shattyundefined
            shatty
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
            G91 ; relative positioning
            G1 H1 X-355 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X-1.3000000000000007 Y1 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
            • Vetiundefined
              Veti @shatty
              @shatty
              ok then the problem is in
              01-Test_IR_PD_Homing
              post that.
              where did you get that macro?
              • shattyundefined
                shatty
                Recycling is tomorrow. Is the printer recyclable?
                • shattyundefined
                  shatty @Veti
                  @Veti Dunno
                  E5Plus
                  Send code...
                  Status
                  Idle
                  Mode: FFF
                  Tool Position
                  X
                  0.0
                  Y
                  0.0
                  Z
                  0.00
                  Extruder Drives
                  Drive 0
                  0.0
                  Speeds
                  Requested Speed
                  0 mm/s
                  Top Speed
                  0 mm/s
                  Sensors
                  Vin
                  24.3 V
                  MCU Temperature
                  25.9 C
                  Z-Probe
                  0
                  Tools
                  Extra
                  Control All
                  Tool Heater Current Active Standby
                  Tool 0
                  T0 - Load Filament Heater 1
                  off 22.4 C
                  0
                  0
                  Bed Heater 0
                  off 21.9 C
                  0
                  0
                  Temperature Chart
                  Macros Directory
                  0:/macros/01-Test_IR_PD_Homing
                  ; Test Routine for Duet WiFi and Ethernet June 2018 - Check IR Probe, PanelDue and endstops
                  ;Start logging
                  M929 P"test1log.txt" S1
                  M117 CHECK IR PROBE & PANELDUE THEN PRESS X ENDSTOP.
                  M577 X S2 ; wait for endstop to trigger
                  M577 X S0 ; wait for endstop release
                  ;----setup motors for test----
                  M906 X2000 Y2000 Z2000 E2000:2000 I100 ;set all motors to 2A with no idle current reduction
                  ;----homing line (tests endstops)----
                  M117 PRESS ALL THREE ENDSTOPS TO END HOMING
                  G91 ; use relative positioning
                  G1 S1 X3200 Y3200 Z3200 F9000 ; move XYZ motors, stopping when endstops are triggered
                  ;----end homing lines----
                  M117 GO ON TO TEST 02
                  • shattyundefined
                    shatty
                    The endless moving happens when I press home all and each axis independently
                    • Vetiundefined
                      Veti @shatty
                      @shatty
                      please dont use that macro, its not for your printer
                      • Vetiundefined
                        Veti
                        use M119
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                        to manually test your endstops.
                        if you can not get them to trigger, there is a problem with your wiring.
                        • shattyundefined
                          shatty @Veti
                          @Veti I tested endstops already under settings and machine specific. X and Y work
                          • Vetiundefined
                            Veti
                            replace that with
                            G1 X50 Y50 F600
                            when exactly does it try to move past the endstops?
                            during the first move?
                            • shattyundefined
                              shatty @Veti
                              @Veti Yes. I tried that setting and no good. Its random in which direction it goes to home and it just slams at the end of each axis.
                              • shattyundefined
                                shatty
                                ; homeall.g
                                G1 X50 Y50 F600 ; go to first bed probe point and home Z
                                M550 P"E5Plus" ; set printer name
                                M551 P"xxxx" ; set password
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                M569 P2 S0 ; physical drive 2 goes backwards
                                M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
                                M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
                                M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
                                M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M208 X350 Y350 Z400 S0 ; set axis maxima
                                M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                                M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
                                M557 X15:190 Y15:190 S20 ; define mesh grid
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                                M143 H0 S110 ; set temperature limit for heater 0 to 110C
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                                M143 H1 S280 ; 280 deg max on hot end
                                M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
                                • Vetiundefined
                                  Veti @shatty
                                  i have never heard of this happening.
                                  let me get this straight.
                                  you home your printer. it moves to the right?
                                  you restart the printer it moves to the left?
                                  post the output of M119 when no endstop is pressed.
                                  post the output of M119 when only the enstop for the x axis is pressed
                                  • shattyundefined
                                    shatty @Veti
                                    @Veti
                                    When I turn it on, nothing moves unless i press the home button. There is no telling which direction it will go if i center the extruder in the middle of the area. Where am I supposed to set the hotend before I turn on the printer?
                                    • Vetiundefined
                                      Veti @shatty
                                      @shatty
                                      please test the stepper motor direction using this
                                      https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                                      report for x y and z
                                      • shattyundefined
                                        shatty
                                        Heres a video of what it does....
                                        https://drive.google.com/file/d/1IeBbFe_YLu9XSz0GbuNmigxwDfcq57Ay/view?usp=sharing
                                        • Vetiundefined
                                          Veti
                                          please do the testing from the webui to rule out a bad touch screen connection.
                                          • Vetiundefined
                                            Veti
                                            btw what is that strange sound at the start of the homing?
