    BLTouch working
    266
    79.5k
      What version of RepRapFirmware are you running? It must be quite old if it doesn't support M280 or M401.
      • Sabagmnundefined
        Sabagmn
        I don't have access to my BW config file at work here, but one thing I would try, is to leave off the I1 (invert polarity) in the M280 command. When I used the BLTouch, it would not work with that parameter set.
        So basically just try this to deploy:
        M280 P3 S10
        @AaronGreen:
        Hi everyone.
        I've read through this entire thread 3 or 4 times now and I still can't get my DuetWiFi-BLTouch deploying, let alone retracting or bed levelling.
        I've followed the BLTouch Wiki through and have the exact wiring connections.
        What happens when I run a Home All, or even a Deploy Command, M401 or M280 P3 S10 I1, it homes X and Y successfully, then throws this error: INVALID M CODE: M401, or INVALID M CODE M280 P3 S10 I1, if I have changed all the deploy commands to the latter. I haven't been able to find this error code anywhere on the Duet forum or the internet.
        When I start the Tevo Black Widow printer, the BLTouch lights up and deploys and retracts twice, before defaulting to the constantly lit state with the pin up. I had been using it perfectly fine with the MKS board, before switching to the Duet. I also don't have any macros set up yet, so I don't know if that's an issue for testing the BLTouch or running a home command.
        I've been working on it for 4 days straight now and I have no idea what to do, please help.
        • AaronGreenundefined
          AaronGreen
          @dc42:
          I'm using RepRapFirmware: 1.15b (2016-08-25)
            AaronGreen
            @Sabagmn:
            M280 P3 S10
            I saw your post and tried this solution immediately, but it didn't fix the error.
              You will need the I1 parameter on the M280 command if you have the BLTouch connected to the Heater 3 pin on the expansion connector. If you have a DueX2 or DueX5 connected and you connect the BLTouch to one of the servo outputs on the DueX instead, then you don't need the I1 parameter.
              • tomasroundefined
                tomasro
                If there was a wiring diagram to show that the connections for the BLTouch was to the 4pin Z-probe input, and not the 3pin Z-endstop input, this would have been helpful 2 days ago. To the laymen and on other control boards, there is no differentiation between these items. It would not be conceivable to have an z endstop and a z probe existing at the same time.
                  AaronGreen
                  @dc42:
                  It's just the Duet WiFi by itself. I have tried the M280 command with the I1 parameter, and it doesn't work. It just says Invalid M Code still.
                  What do I do now?
                    T3P3Tony administrators
                    Start by upgrading to version. 1.18
                      @AaronGreen:
                      @T3P3Tony:
                      I can't figure out how to upgrade the firmware. I have the Arduino program, which I used to update the MKS board with Marlin. Pretty easy.
                      What's the latest process for doing this for RepRap?
                      It's all on the wiki, https://duet3d.com/wiki/Duet_Wiki#Updating_Duet_WiFi_firmware.
                        AaronGreen
                        @dc42:
                        @AaronGreen:
                        @T3P3Tony:
                        Thanks, I just happened to see it at the same time I received your response.
                        It's now homing X, Y, and Z.
                        The next issue I have to work through is that it's not stopping on Z, and rams the bed. I double-checked the config update I was using, and used my finger to test the BLT, but it still rams.
                        I'll go back through the thread, but you have an immediate fix then please let me know.
                        Thanks for your help.
                        • Jareryundefined
                          Jarery
                          Im using a BLTouch, a fairly new 'smart' version.
                          It seems to be working correctly, but i've never cut the trace to change it from 5v to 3.3v.
                          Since its hooked to the 5v output on the duet, whats correct?
                          A) - Cut it to work at 3.3v
                          B) - leave it at 5v
                          C) - if its working don't f$*k with it regardless of settings,
                          D) - Its gonna blow up, fry the duet, and burn down the house by running at 5v…..
                            It's safest to cut the trace.
                            • Nylkosundefined
                              Nylkos
                              Been trying to setup my BLTouch for a couple of days…
                              I can't seem to find out how to do it properly... I do not get the flashing red, the probe retract, deploys a few times and remain red.
                              I keep getting the Z-Probe field in red
                              I tried wired has the image below. I also tried with the White wired in the Probe In instead of the E1.
                              Since the field is red from connecting, I do not believe my issue to be from elsewhere then the Config.g
                              I am using the 1.19.2 version. On a Duet 0.8.5
                              I added the required code and .g files
                              • I moved all the requested codes to the bottom for convenience.
                              ; Configuration file for Duet 0.8.5 (firmware version 1.17)
                              ; generated by RepRapFirmware Configuration Tool on Fri Sep 01 2017 23:00:38 GMT-0400 (Eastern Standard Time)
                              M111 S0 ; Debugging off
                              G21 ; Work in millimetres
                              G90 ; Send absolute coordinates…
                              M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                              M667 S1 ; Select CoreXY mode
                              M208 X300 Y300 Z300 S0 ; Set axis maxima
                              M574 Z0 S0 ; Define active low and unused microswitches
                              M574 X2 Y2 S0 ; Define active high microswitches
                              G31 P600 X1.8 Y3 Z2.5 ; Set Z probe trigger value, offset and trigger height
                              M557 X15:285 Y15:285 S20 ; Define mesh grid
                              M92 X160 Y160 Z800 E100 ; Set steps per mm
                              M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                              M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                              M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M143 S300 ; Set maximum heater temperature to 300C
                              M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                              M563 P0 D0 H1 ; Define tool 0
                              M550 PMy printer ; Set machine name
                              M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
                              M552 P192.168.2.50 S1 ; Enable network and set IP address
                              M553 P255.255.255.0 ; Set netmask
                              M554 P192.168.2.254 ; Set gateway
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              ; Custom settings
                              M307 H1 A506.7 C200.3 D6.0 B0 ; Save hotend PID
                              M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
                              M558 P5 X0 Y0 Z1 H5 F100 T2000
                              G31 X3 Y-1.8 Z0 P25
                              T0
                              deployprobe.g
                              M280 P3 S10 I1
                              retractprobe.g
                              M280 P3 S90 I1
                              I am seriously stuck…
                              Thanks you for your help.
                              • davidbittonundefined
                                davidbitton
                                @Jdn-za:
                                Seems I just had the wrong value in my retract macro… awkward 😛
                                What/which value and what/which macro?
                                • Biggsisundefined
                                  Biggsis
                                  Alright, I have a BLTouch mostly working with my Duet Wifi, G29 is working, map is created and used so far, but I somehow dont get the maths right.
                                  I am using the BLTouch as the Z-Min Endstop and it works so far, bed touches the pin, stops. etc.
                                  But how do I get the right value for the Z-Offset of the probe right?
                                  I have this line:
                                  G31 X40 Y5 Z1.00 P25
                                  the X and Y offset was measured by me, but the Z offset is not the right value, I was more or less just guessing and when I start printing the nozzle is far too close to the bed and I have to BabyStep lift the nozzle by 0.55 mm up in order to print usable on the bed.
                                  Now I am aware that I should change that offset value but where to? Add .55 to the G31 Z Value? Or subtract? I dont get it since I guess I did not completely understand, what the Z offset in the G31 line really is. The distance between the trigger height of the probe and the tip of the nozzle?
                                  Maybe someone can enlighten me about the correct procedure / maths.
                                  Thanks a lot.
                                  Hypercube Evolution User Group : https://www.facebook.com/groups/Hypercubeevolution/
                                  Kossel Delta XL / XXL User Group : [https://www.facebook.com/groups/KosselXXL/]
                                  • Sabagmnundefined
                                    Sabagmn
                                    Correct. The Z offset is the difference between the trigger height of the probe and the height of the nozzle tip. So in your case that would be around 0.45, which would be what you put as your Z value.
                                    It basically just means that when your probe triggers, it will know that the nozzle is still 0.45mm above the bed.
                                    Here are good instructions for finding the correct value:
                                    https://duet3d.com/wiki/Using_mesh_bed_compensation
                                    • Motalwundefined
                                      Motalw
                                      @claustro:
                                      @dc42:
                                      Have you read https://duet3d.com/wiki/Using_mesh_bed_compensation ?
                                      I have another problem , when I home the Z probe seems to work perfectly, the printer register the touch point and the home Z button become blue . The problem is the probe that after touching the bed with the pin it start flashing and I have to reset it manually https://www.youtube.com/watch?v=eq2wTy3-kxA
                                      this is my homing routine
                                      [c]G91 ; relative mode
                                      G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
                                      G90 ; back to absolute mode
                                      M98 Pdeployprobe.g
                                      G1 X150 Y150 F2000 ; put head over the centre of the bed, or wherever you want to probe
                                      G30 ; lower head, stop when probe triggered and set Z to trigger height[/c]
                                      Hope you'll be able to understand my very mad English 🙂
                                      I have the same problem when the pin drops after homing Z but it doesn't always happen. did anyone have this problem? and how did you fix it?
                                      Also, my homing only works with M558 P1 instead of P5. any idea why?
                                      all connections are correct as far as I know.
                                      • Nylkosundefined
                                        Nylkos
                                        No idea, but you seem to be in the same boat has I…
                                        What I had to do:
                                        Like in https://duet3d.com/wiki/Connecting_a_Z_probe
                                        but use P1 instead of P5 and change your P value in G31 (I used P200)
                                        M558 P1 X0 Y0 Z1 H5 F100 T2000
                                        G31 X0 Y0 Z0 P200
                                        use deployprobe.g (M280 P3 S10 I1)& retractprobe.g (M280 P3 S90 I1)
                                        Thread
                                        Source:https://www.duet3d.com/forum/thread.php?id=2539&p=2
                                        Can you post your homez.g file?
                                        I do not have access to my file from work but I might be able to help.
                                        • Motalwundefined
                                          Motalw
                                          I'm at work right now but I believe my Homez is:
                                          ; homez.g
                                          ; Lift Z relatively to current position
                                          G91
                                          G1 Z5 F6000
                                          ; Back to absolute positioning
                                          G90
                                          ; Go to first bed probe point and home the Z axis
                                          G1 X15 Y15 F6000
                                          G30
                                          ;G91
                                          ;G1 Z5 F100
                                          ;G90
                                          one thing came to my mind now… maybe I have used the 10k resistor instead of the 240 ohm. need to double check it when I get home.
                                          would it be a possible explanation?
                                          • Nylkosundefined
                                            Nylkos
                                            @Motalw:
                                            ; homez.g
                                            G91
                                            G1 Z5 F6000
                                            G90
                                            G1 X15 Y15 F6000
                                            G30
                                            ;G91
                                            ;G1 Z5 F100
                                            ;G90
                                            did you create deployprobe.g (M280 P3 S10 I1) & retractprobe.g (M280 P3 S90 I1)?
                                            If no, you need to create those files with the command ()
                                            Once you have them, add the Pdeployprobe.g & Pretractprobe.g command in your homez.g file:
                                            M98 Pdeployprobe.g
                                            G1 X15 Y15 F6000
                                            G30
                                            M98 Pretractprobe.g
                                            To test, click manually home X, Home Y, Home Z, do not click home all.
                                            Let me know how it goes
