    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.5k
    • OwenDundefined
      OwenD
      Should this be working with RRF 3.2b3?
      I got an error saying the plugin couldn't be installed because DWC version wasn't correct
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • Sindariusundefined
        Sindarius @OwenD
        @OwenD this depends on DWC 3.2 beta 3 which I do not believe is released at this point. You have to pull it down and build it then install it.
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @Sindarius
          @Sindarius
          This is the bundle I used.
          https://forum.duet3d.com/topic/19623/firmware-bundle-3-2beta3-now-available
          Bugger,
          Just noticed there's a DWC package further down the list.... I thought it was all in teh bundle.
          Will try that tonight.
          • Thaliosundefined
            Thalios
            Make sure you update the DWC to 3.2b3 as well or it won't work. Not just the firmware.
            Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
            Heavily modified Ender 3 Pro (Duet 3 6HC)
            Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
            CR-10S Pro V2 (Duet 3 Mini 5+)
            and a bunch of SLA printers..
            • Exerqtorundefined
              Exerqtor
              Works like a charm!
              One thing i would love is a Zoom-slider or a +/- somewhere on the "viewport" to zoom in on the build area. For instance, i'm using a old AF laptop and the touchpad driver is long before win10 si i cant use the "pinch or open gesture" to zoom or heck even scroll.
              Other than that @chrishamm has some issues with the sorting on the release section of the git lol. I've installed an old version more than once just by downloading the top one lol.
                Sindarius @Exerqtor
                @Exerqtor You can actually use the arrow keys on the keyboard to move the camera.
                arrow keys will rotate around
                hold down control and you can pan
                hold down alt and up and down will zoom in and out
                I am looking at speeding up the camera movement with the keyboard when pan/zoom (it's a bit slow)
                Edit:
                Sped up the keyboard controls so you can avoid using the touchpad as much as possible.
                https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.8.4
                Exerqtorundefined A Former User? 2 Replies Last reply Reply Quote 0
                • Exerqtorundefined
                  Exerqtor @Sindarius
                  @Sindarius
                  Oh there you go haha!
                  Sindariusundefined 1 Reply Last reply Reply Quote 1
                    Sindarius @Exerqtor
                    @Exerqtor I'll play with it a bit more and see if I can get numbers that work reasonably well for the camera movement. But for now it should be usable to, at the very least, get you close.
                    • Thaliosundefined
                      Thalios
                      little typo error.
                      In the main window, where it says Show object selection, it is written Show object Selction.
                        Sindarius @Thalios
                        @Thalios sure enough, I’ll fix that in the morning.
                          A Former User @Sindarius
                          @Sindarius said in 3D GCode Viewer integrated with DWC:
                          Edit:
                          Cool 🙂
                          Maybe you could even in one of the 4 corners show permanent this hint for navigation with keyboard with an 50% alpha-val or so:
                          Use mouse or for keyboard:
                          UP/RIGHT/DOWN/LEFT for move
                          CTRL & UP/RIGHT/DOWN/LEFT for move
                          ALT & UP/ALT & DOWN for zoom in/out
                          or something like this put anywhere in one of the boxes...
                          Great work!
                            Sindarius @A Former User
                            @LB I'll probably look into putting Help/About button that will bring up a dialog. I'll make sure to include the keyboard control info in there. 👍 I have a couple things that I want to get to before I turn attention to that.
                            • Thaliosundefined
                              Thalios
                              was printing for the first time on my Tronxy big monster and noticed that the cursor is off the rendered printed part.
                              Don't know if that's a bug or a setting.
                              See picture.
                                Sindarius @Thalios
                                @Thalios Should be on the print. First I have seen of that. The cursor position is based on what the duet is reporting at the time.
                                • Thaliosundefined
                                  Thalios
                                  Notice the X position in both images. the rendered cursor is way off.
                                    Sindarius @Thalios
                                    @Thalios I wonder if there is a difference between the homed position and cursor location. I'll have to look into it
                                      Sindarius
                                      Added coloring by feed rate.
                                        Cool: Colours are adjustable e.g. green for slow and red for fast?
                                          @LB Not yet. It's on my list
                                            Sindarius
                                            Here you go 😉 Also it tells you the max feed rate that was detected in the file but that's usually a travel move so it is what it is.
