    Help me get connected to my Duet2Wifi
    6.0k
      Phaedrux Moderator @Kwad3d
      @Kwad3d said in Help me get connected to my Duet2Wifi:
      How can I correct this issue?
      It's not a bug. It's the thermal runaway protection kicking in because it doesn't have an accurate model of your heater yet so it thinks something is wrong.
      The solution is to PID tune your heaters.
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
      Kwad3dundefined 3 Replies Last reply Reply Quote 0
      • Kwad3dundefined
        Kwad3d @Phaedrux
        @Phaedrux LOL.. total DUH moment. Guess I assumed that "Bang Bang" didn't require it
        • Kwad3dundefined
          Kwad3d @Phaedrux
          This post is deleted!
          • Kwad3dundefined
            Kwad3d @Phaedrux
            @Phaedrux Ok I have made some progress but having inconsistent results with senseless homing and not sure how to adjust the settings. This is on a CoreXY for reference so both motors have to move in tandem to home x and y. It will home some times and then sometimes it will move a little in the opposite diagonal direction ( one motor not turning with the other). Here is my HomeX code. My guess is its slightly too sensitive. Im gussing I need to increase the motor current a few percent but want to check
            M400
            M913 X70 Y70 ; drop motor current to 70%
            M400 G91; relative positioning
            G1 H2 Z10 F12000 ; lift Z relative to current position
            G1 H1 X-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X20 F12000 ; go back a few mm
            G1 H1 X-320.5 F7000 ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-10 F9000 ; lower Z again
            G90 ; absolute positioning
            M400
            M913 X100 Y100 ; return current to 100%
            M400
              What does your M915 command look like?
              https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Sensorless_Homing
              Have you calculated what your M915 H value should be and your minimum homing speed?
              https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Minimum_recommended_speed_for_stall_detection
              In your example, remove the entire second homing move. With stall detection you need a short sharp shock during a steady state move. Backing off and slowly approaching from close up isn't going to generate a stall reliably. Since you're stalling the motor to a full step anyway, backing off and rehoming for more accuracy doesn't make sense here like it does when using an endstop switch.
              So try this
              M400
              M400
              M400
              M400
              Start with as low a motor current as you can still reliably move with and set the sensitivity to default. Then slowly increase (or decrease) sensitivity from there.
              Kwad3dundefined 1 Reply Last reply Reply Quote 0
              • Kwad3dundefined
                Kwad3d @Phaedrux
                @Phaedrux So lower the full current setting that was set in the confit tool or the "drop motor" current in the M913 line? If im changing the full current that was set in the config (800) I can do that with a g code command in the console right? what is the code please if so
                  I mean lower the dropped current in the M913 command in your homing file.
                  M906 sets the full current in config.g. That one should be set at ~80% of your motors max current.
                  • Kwad3dundefined
                    Kwad3d @Phaedrux
                    @Phaedrux Ok currently my M913 line is set to %70 for x and Y. lower to %60-65 and retest?
                      You can send M913 in the console to lower the current in steps. Send your homing move command each time. When the move doesn't work anymore, you've found the lower limit.
                      Example
                      M913 X30
                      G1 H1 X-300 F10000
                      M913 X40
                      G1 H1 X-300 F10000
                      etc
                      If it still moves reliably sat 30% then maybe stick with that because I don't think you'd get much lower.
                      • Kwad3dundefined
                        Kwad3d @Phaedrux
                        @Phaedrux Today im getting zero movement on homing x. The bed drops then X is just set to 0 while the nozzle is in the center of the bed. I can manually move left and right after the failed homing move. Here is my code for home X at the moment. anything wrong with it? I repeated testing with M913 increments up to 100% I would occasionally get it to home but fails %90 of the time. How do I get it to grind the x axis into the home location? where I want to be is obviously somewhere between there and where Im at now.
                        M400
                        M913 X80 Y80 ; drop motor current to 80%
                        M400
                        M400
                        M400
                          I still haven't seen your m915 command. Can you post your config.g file?
                          • Kwad3dundefined
                            Kwad3d @Phaedrux
                            @Phaedrux
                            M550 P"SK GO" ; set printer name
                            M669 K1 ; select CoreXY mode
                            M551 P"SK GO" ; set password
                            M552 S1 ; enable network
                            M586 P0 S1 ; enable HTTP
                            M586 P1 S0 ; disable FTP
                            M586 P2 S0 ; disable Telnet
                            M569 P2 S0 ; physical drive 2 goes backwards
                            M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
                            M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                            M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                            M84 S30 ; Set idle timeout
                            M208 X10 Y36 Z0 S1 ; set axis minima
                            M208 X310 Y336 Z320 S0 ; set axis maxima
                            M574 X1 S3 ; configure sensorless endstop for low end on X
                            M574 Y1 S3 ; configure sensorless endstop for low end on Y
                            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                            M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-26 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                            M557 X36:290 Y46:290 S48 ; define mesh grid
                            M143 H0 S90 ; set temperature limit for heater 0 to 90C
                              May want to increase your max speed and decrease your acceleration.
                              Try
                              M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                              M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
                              It sounds like it's detecting a stall immediately, possibly due to the high acceleration.
                              Doing this calculation for minimum stall speed would help as well so we know how fast it needs to be going to stall, but not so fast that it stalls prematurely.
                              Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
                              • Kwad3dundefined
                                Kwad3d @Phaedrux
                                @Phaedrux Im confused by the equation.
                                What is sqrt? and this is in algebraic format correct. So I would calculate full steps x rated current x actual current (A) and calculate sqrt x2 then x pi x rated holding (B). then divide a with b right?
                                I have never had any luck with stall guard in general. Is there a way to turn it off but have senseless homing like on a prusa? Since this is on a coreXY that I will want to print at speeds above 100mm/s It could become a problem could it not?
                                  Yes, that's exactly what you're doing now. You don't have to use both. You can use either or.
                                  It would help me to know what your motor model is. Do you know the rated current? If it's detecting a stall already at M913 80% perhaps your M906 current in config.g is set too low.
                                  If you tell me the rated current and whether they are 0.9 or 1.8 degree motors I can calculate the value using my spread sheet.
                                  No, no problem at all. Your max speed was limited to 100mm/s in your config.g and I suggested increasing it to 200mm/s, but you could raise that even more if you want.
                                  • Kwad3dundefined
                                    Kwad3d @Phaedrux
                                    @Phaedrux there LDO brand motors on X and Y at 0.9 deg. Model 42STh47 1684MAC Standard size motor. no other information about the motors was provided by the retailer of the machine and I could not find the required info on the LDO site.
                                      Do they look like this?
                                      https://www.printedsolid.com/products/ldo-nema-17-motor-ldo-42sth47-1684mac
                                      If so, 1.68a rated.
                                      If that's the case, then the current you have set in M906 in your config.g is quite low at 800ma. Try changing that to 1400 instead.
                                      Now your homing file might work better with M913 X70
                                      • Kwad3dundefined
                                        Kwad3d @Phaedrux
                                        @Phaedrux Yes. the # number on the end is different on mine but I think that's a batch number or something
                                        • Kwad3dundefined
                                          Kwad3d @Phaedrux
                                          @Phaedrux WIll that help with the stall issue or can I disable it
                                          • Kwad3dundefined
                                            Kwad3d @Phaedrux
                                            @Phaedrux Does this look ok for my Homex file? I changed the current for x and y already
                                            M400
                                            M400
                                            M400
