    Help me get connected to my Duet2Wifi
    6.0k
    • Kwad3dundefined
      Kwad3d @Phaedrux
      @Phaedrux
      M550 P"SK GO" ; set printer name
      M669 K1 ; select CoreXY mode
      M551 P"SK GO" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
      M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M84 S30 ; Set idle timeout
      M208 X10 Y36 Z0 S1 ; set axis minima
      M208 X310 Y336 Z320 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y1 S3 ; configure sensorless endstop for low end on Y
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-26 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X36:290 Y46:290 S48 ; define mesh grid
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
        May want to increase your max speed and decrease your acceleration.
        Try
        M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
        It sounds like it's detecting a stall immediately, possibly due to the high acceleration.
        Doing this calculation for minimum stall speed would help as well so we know how fast it needs to be going to stall, but not so fast that it stalls prematurely.
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Minimum_recommended_speed_for_stall_detection
        Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
        Kwad3dundefined 1 Reply Last reply Reply Quote 0
        • Kwad3dundefined
          Kwad3d @Phaedrux
          @Phaedrux Im confused by the equation.
          What is sqrt? and this is in algebraic format correct. So I would calculate full steps x rated current x actual current (A) and calculate sqrt x2 then x pi x rated holding (B). then divide a with b right?
          I have never had any luck with stall guard in general. Is there a way to turn it off but have senseless homing like on a prusa? Since this is on a coreXY that I will want to print at speeds above 100mm/s It could become a problem could it not?
            Phaedrux Moderator @Kwad3d
            @Kwad3d said in Help me get connected to my Duet2Wifi:
            Yes, that's exactly what you're doing now. You don't have to use both. You can use either or.
            It would help me to know what your motor model is. Do you know the rated current? If it's detecting a stall already at M913 80% perhaps your M906 current in config.g is set too low.
            If you tell me the rated current and whether they are 0.9 or 1.8 degree motors I can calculate the value using my spread sheet.
            No, no problem at all. Your max speed was limited to 100mm/s in your config.g and I suggested increasing it to 200mm/s, but you could raise that even more if you want.
            • Kwad3dundefined
              Kwad3d @Phaedrux
              @Phaedrux there LDO brand motors on X and Y at 0.9 deg. Model 42STh47 1684MAC Standard size motor. no other information about the motors was provided by the retailer of the machine and I could not find the required info on the LDO site.
                Do they look like this?
                https://www.printedsolid.com/products/ldo-nema-17-motor-ldo-42sth47-1684mac
                If so, 1.68a rated.
                If that's the case, then the current you have set in M906 in your config.g is quite low at 800ma. Try changing that to 1400 instead.
                Now your homing file might work better with M913 X70
                Kwad3dundefined 3 Replies Last reply Reply Quote 0
                • Kwad3dundefined
                  Kwad3d @Phaedrux
                  @Phaedrux Yes. the # number on the end is different on mine but I think that's a batch number or something
                  • Kwad3dundefined
                    Kwad3d @Phaedrux
                    @Phaedrux WIll that help with the stall issue or can I disable it
                    • Kwad3dundefined
                      Kwad3d @Phaedrux
                      @Phaedrux Does this look ok for my Homex file? I changed the current for x and y already
                      M400
                      M913 X70 Y70 ; drop motor current to 70%
                      M400 G91; relative positioning
                      G1 H2 Z10 F12000 ; lift Z relative to current position
                      G1 H1 X-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass)
                      G90 ; absolute positioning
                      M400
                      M913 X100 Y100 ; return current to 100%
                      M400
                        So at this point you should have
                        M906 X1400 Y1400 etc etc
                        That homing file looks ok, does it work?
                        • Kwad3dundefined
                          Kwad3d @Phaedrux
                          @Phaedrux No same stuff. Bed lowers but the X axis remains motionless and the X location changes to 0. I need to disable the stall detection. I have been printing a long time and that feature will ruin more prints than it will potentially save.
                          I also had my travel speed set to 300mm/s on the coreXy. So do I need to up my limit to 300 right. Don't have any reason to go beyond that.
                            But you don't even have an m915 in your config.g to enable stall detection.
                            Once it thinks it's homed can you jog the axis around like normal?
                            Try reducing the speed of the homing move to 6000
                            • Kwad3dundefined
                              Kwad3d @Phaedrux
                              @Kwad3d I never got enough information to solve the equation myself. If stall detection is off then what if preventing the homing procedure. Seems to me it is on and I would rather have it turned off. There has never been a print saved by senseless homing in my shop but I have had several failures so I turn it off on printers like my prusa. Yes after it thinks its homed it moves. just will not move beyond the zero position set by the homing move.
                                A Former User @Kwad3d
                                if you don't have m915 in your config its not on and you don't need to disable it, its off by default.
                                • Kwad3dundefined
                                  Kwad3d @A Former User
                                  Ok im making a serious recommendation for the Duet team... order a SKR with some 2209 or other drivers capable of senseless homing and see how simple it is to set up. Only took a few minutes. I have been on this all day. How do I get the axis to just grind into the home position? I know the spot I want to be in in-between there and where im at now.
                                    A Former User
                                    The length of your homing moves? Motor current? Friction? Assumptions?
                                    Paste your homing file(s)?
                                      It's not preventing it, it's just detecting a stall immediately and saying you are homed. False positive.
                                      Please post your config.g again along with your homing files. Let's see what's up.
                                      I hate to break it to you pal, but the problem isn't the duet, the firmware, or the drivers. The forum isn't flooded with people unable to configure sensorless homing.
                                      So let's put our thinking hats on and figure out what's going on. With a bit of patience you've made it this far, and we got farther faster when you weren't being crusty. 😉
                                        why is that a goal?
                                        but G1 H2 X-320.5 F10000 should do it.
                                        G1 H1 X-320.5 F10000 as you had it like will move to the endstop and stop.
                                        To see the difference in H1 and H2 paramterer https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                                        .. core xy .. 🤦
                                        • Kwad3dundefined
                                          @bearer Ok. Im on a coreXY so im a little confused by the documentation on H2. Im getting the impression that that is for a single motor move but I have a tandem motor set up for X and Y. Am I overthinking it and just try the H2 instead?
                                            H2 works a bit different on a CoreXY. Normally it just ignores endstop status and allows a requested move to work, but in a delta and corexy it also targets a single motor move.
                                            What bearer is saying I think, is that if you want to ram the print head into an axis, using H2 to ignore the homed state and execute the move would give you that.
                                            Anyway, back to actually tuning your homing moves...
                                            Did you ever try this to see what combination of motor current and feed rate works?
                                            Example
                                            M913 X30
                                            G1 H1 X-300 F10000
                                            M913 X40
                                            G1 H1 X-300 F10000
                                            Also, just to eliminate the mechanical side, is this a new printer build or one that was working previously?
                                            Since it's detecting a stall, is it a false positive, or is there actually some binding on the XY motion?
                                            If you detect the belts from the motors are you able to move the print head around smoothly and freely?
                                            With the belts attached, are you able to slowly move the head around with mostly equal resistance in all direction?
                                            If the mechanics are all clear, then we're left with two parameters to tune for sensorless homing to work, motor current and feed rate.
                                            Motor current will depend on your motor specs, we think the rated current is 1700 and 80% of that for normal usage is 1400.
                                            Then we need to find the lowest percentage reduction of that which still allows for normal movement. So start at M913 X10 and then try to jog the axis (don't try a homing move at that point. You can send G92 X100 to force the x axis as homed btw to allow you to jog it normally.) If it doesn't move, up it to M913 X20 and repeat. When the motor reliably moves you've found the right motor current percentage for sensorless homing.
                                            Next would be finding the right feed rate.
                                            If it's still stalling all the time, then we need to dig a bit deeper and would ask that you post your config.g, your homing files, the results of M122, and of sending M98 P"config.g". Also some more details about the printer. We're not in the room with you, so we only know the details you provide.
