First Layer and Extrusion Problems
5.6k
    Frederik
    pla_unload.g pla_load.g pla_config.g Hello togehter,
    i finished my first corexy build yesterday and wanted to tune the z offset for a good first layer with your tutorial for BLtouch and independent Z leveling.
    But now i have the Problem that my z offset is way to high and i dont know where to put the new values in.
    in my config is the following line for my BLtouch:
    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
    M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch
    G31 P500 X-26 Y2 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X50:400 Y50:400 S50 ; define Mesh Grid
    After Leveling the bed with a piece of paper and setting Z=0 with G92 Z0
    then a single measurement with G30 S-1 where i get the value of x.xxx
    when i am changing the Z value, i dont get it right. or is there something i am missing ?
    The indipendent Z Leveling seems to work just Fine.
    But my High Map is a Desaster 🙂 i tried Tue BEd Level First and then a Mesh Compensation.
    The other Problem is that my Extruder seems to skip steps and is constantly feeding to less material. The E STeps are 830 for a Original Direct Drive BMG with a E3d Volcano with 0.4 Nozzle. When i am manual Extrudiong at 225° i cant go with the speed over 5 -15 mm bevor it starts making strange clicking noises.
    Where can i set the Retractions Paramters etc. ?
    I tried using the Filaments Macros with the load, unload and config files , but i dont know if it is correct .
    Reprap 3.1.1
    Duet 3 + RPI 3b+
    0.9° Pancake Stepper on the BMG
    1.8° Z Stepper
    Tried printing PLA with 215 ° Nozzle and Bed 60°
    config (1).g
    homez.g
    bed.g
    pla_config.g
    pla_load.g
    pla_unload.g
    Kindly Regards
    Frederik
    undefined 1 Reply Last reply 20 Nov 2020, 14:37 Reply Quote 0
      Frederik
      I dont know where i can change the offset ?
      Do i have to add a command after the BLTouch Lines or change the trigger height ?
      The dozuki only says to change the G31 , but how ?!?
        pipersw
        in config.g :
        G31 P500 X-26 Y2 Z2.5 <= modify the Z, increase value for reduce height of nozzle
          Frederik
          ok thanks , one moment i will try it
            Frederik
            Is the Right way to do a bed leveling:
            first G32
            then G 28
            and then adjusting for the right layer height ?
            This is my First Printer build 🙂
              Veti
              G29 S1 ; Load previously set bed map
              this should not be in the config.g
              the mesh should be loaded after you have established z=0
              so a good place is the start of your slicer g code
              for the offset see
              https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                Frederik
                when i run first a true bed level and then a bed mesh compensation i get the following heightmap:
                RepRapFirmware height map file v2 generated at 2020-11-20 14:53
                xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                0.00,340.00,0.00,370.00,-1.00,20.00,20.00,18,19
                2.000, 1.878, 1.875, 1.890, 1.685, 1.642, 1.517, 1.442, 1.358, 1.253, 1.180, 1.145, 1.135, 1.138, 1.160, 1.177, 1.250, 1.333
                1.715, 1.562, 1.735, 1.757, 1.603, 1.550, 1.423, 1.320, 1.240, 1.132, 1.075, 1.030, 1.020, 1.020, 1.048, 1.062, 1.105, 1.183
                1.683, 1.645, 1.835, 1.725, 1.558, 1.397, 1.267, 1.160, 1.070, 1.010, 0.943, 0.925, 0.910, 0.922, 0.975, 1.005, 1.022, 1.100
                1.635, 1.677, 1.760, 1.573, 1.440, 1.302, 1.163, 1.052, 0.970, 0.905, 0.847, 0.815, 0.802, 0.815, 0.855, 0.892, 0.930, 1.010
                1.603, 1.555, 1.608, 1.442, 1.285, 1.150, 1.060, 0.953, 0.833, 0.755, 0.712, 0.690, 0.685, 0.695, 0.730, 0.770, 0.818, 0.927
                1.483, 1.513, 1.510, 1.255, 1.155, 1.025, 0.943, 0.828, 0.795, 0.685, 0.597, 0.578, 0.573, 0.578, 0.613, 0.653, 0.722, 0.812
                1.440, 1.442, 1.358, 1.160, 0.998, 0.858, 0.715, 0.642, 0.648, 0.542, 0.507, 0.507, 0.510, 0.533, 0.557, 0.610, 0.675, 0.775
                1.478, 1.415, 1.267, 1.017, 0.917, 0.797, 0.743, 0.680, 0.615, 0.605, 0.432, 0.413, 0.420, 0.440, 0.455, 0.505, 0.573, 0.677
                1.355, 1.205, 1.100, 0.875, 0.770, 0.672, 0.648, 0.590, 0.523, 0.417, 0.307, 0.300, 0.312, 0.333, 0.352, 0.392, 0.455, 0.555
                1.212, 1.145, 0.953, 0.783, 0.632, 0.550, 0.560, 0.490, 0.360, 0.280, 0.203, 0.208, 0.225, 0.233, 0.238, 0.292, 0.352, 0.453
                1.112, 1.010, 0.820, 0.632, 0.493, 0.390, 0.395, 0.347, 0.243, 0.158, 0.092, 0.100, 0.127, 0.120, 0.127, 0.163, 0.215, 0.333
                1.005, 0.875, 0.705, 0.480, 0.358, 0.243, 0.212, 0.165, 0.115, 0.045, -0.010, 0.005, 0.010, 0.007, 0.012, 0.047, 0.097, 0.212
                0.913, 0.750, 0.557, 0.318, 0.233, 0.108, 0.057, -0.002, -0.062, -0.110, -0.153, -0.148, -0.132, -0.137, -0.108, -0.068, 0.005, 0.095
                0.797, 0.625, 0.425, 0.248, 0.127, -0.012, -0.097, -0.160, -0.220, -0.270, -0.283, -0.288, -0.270, -0.265, -0.227, -0.158, -0.105, -0.023
                0.698, 0.483, 0.167, 0.115, -0.005, -0.145, -0.248, -0.302, -0.368, -0.440, -0.453, -0.475, -0.470, -0.430, -0.387, -0.315, -0.265, -0.182
                0.500, 0.312, 0.070, -0.078, -0.193, -0.310, -0.408, -0.467, -0.552, -0.592, -0.575, -0.573, -0.578, -0.547, -0.495, -0.427, -0.350, -0.267
                0.358, 0.160, -0.092, -0.172, -0.295, -0.415, -0.500, -0.573, -0.642, -0.665, -0.627, -0.595, -0.637, -0.640, -0.583, -0.515, -0.438, -0.347
                0.265, 0.068, -0.240, -0.307, -0.420, -0.557, -0.640, -0.690, -0.735, -0.715, -0.660, -0.653, -0.730, -0.743, -0.698, -0.627, -0.542, -0.432
                0.105, -0.070, -0.250, -0.320, -0.557, -0.677, -0.762, -0.797, -0.802, -0.773, -0.743, -0.795, -0.852, -0.833, -0.752, -0.670, -0.625, -0.517
                  Frederik
                  That is the orresponding height map picture from my DWC
                    Veti
                    post the output of 3 consecutive G32.
                    most likely your motor order is wrong
                      Frederik
                      1.G32
                      Leadjustments made: -2.618 -0.246 -0.521, points used 3, (mean, deviation) before (-0.997, 0.862) after (0.000, 0.000)
                      2.G32
                      Leadscrew adjustments made: -0.054 1.112 0.200, points used 3, (mean, deviation) before (0.399, 0.459) after (-0.000, 0.000)
                      3.G32
                      Leadscrew adjustments made: 0.044 0.756 -0.011, points used 3, (mean, deviation) before (0.228, 0.321) after (0.000, 0.000)
                      undefined 1 Reply Last reply 20 Nov 2020, 14:49 Reply Quote 0
                        Frederik
                        i´ve checked the cabling.
                        left front spindle is connected to driver 2
                        back center spindle to driver 3
                        right front spindle to driver 4
                          fcwilt @Frederik
                          Do you lead screws really have pitch of 1.25?
                          Regards bed.g:
                          I'm not sure what having two P parameters is going to do to your bed leveling.
                          Why did you add the second P1.25?
                          undefined 1 Reply Last reply 20 Nov 2020, 14:48 Reply Quote 0
                            Veti @fcwilt
                            @fcwilt said in First Layer and Extrusion Problems:
                            he has z400. where did you see 1.25 leadscrew?
                            M92 X160.00 Y160.00 Z400.00 E830.00 ; set steps per mm
                            undefined 1 Reply Last reply 20 Nov 2020, 14:50 Reply Quote 0
                              Veti @Frederik
                              @Frederik said in First Layer and Extrusion Problems:
                              1.G32
                              2.G32
                              3.G32
                              that seems to be converging. can you run a g29 now and post the picture
                                fcwilt @Veti
                                @Veti said in First Layer and Extrusion Problems:
                                See his bed.g file.
                                He has two P parameters for each G30. Not sure if that is messing things up or not.
                                undefined 1 Reply Last reply 20 Nov 2020, 14:54 Reply Quote 0
                                  Veti @fcwilt
                                  @fcwilt
                                  good catch.
                                  yes the second P1.25 parameter should be removed. this is not a valid parameter for G30
                                  your pitch is 8mm btw.
                                  undefined 1 Reply Last reply 20 Nov 2020, 14:58 Reply Quote 0
                                    fcwilt @Veti
                                    How can we be sure the pitch is 8mm? The config values might be wrong. Maybe the comment in bed.g is correct?
                                    Clarification is needed from the OP.
                                    undefined undefined 2 Replies Last reply 20 Nov 2020, 15:06 Reply Quote 0
                                      Frederik
                                      ok ,i have changed it.
                                      is it possible to create a homez.g file where it automatically probes the bed on three points and enable compensation ?
                                      perhaps like :
                                      ; homez.g
                                      ; called to home the Z axis
                                      ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
                                      G91 ; relative positioning
                                      G90 ; absolute positioning
                                      G1 X240 Y220 F6000 ; go to first probe point
                                      G32 ; home Z by True bed leveling 3 points in bed.g
                                      or do i have to include the three positions like
                                      G30 P0 X330 Y240 Z-9999 ; Front Left
                                      G30 P1 X150 Y0 Z-9999 ; Middle Back
                                      G30 P2 X0 Y248 Z-9999 S3 ; Front Right and compensate 3mm
                                      undefined undefined 2 Replies Last reply 20 Nov 2020, 15:02 Reply Quote 0
                                        Veti @Frederik
                                        @Frederik
                                        create a macro that calls G28 and G32
                                          Veti @fcwilt
                                          i cant, but there is a very high chance that isnt a M8 metric lead screw.
                                          undefined 1 Reply Last reply 20 Nov 2020, 15:09 Reply Quote 0
                                          4 out of 121
