    First Layer and Extrusion Problems
    5.8k
    • fcwiltundefined
      fcwilt @Frederik
      @Frederik said in First Layer and Extrusion Problems:
      is it possible to create a homez.g file where it automatically probes the bed on three points and enable compensation ?
      Yes.
      But let's get some terminology straight - bed leveling is not homing.
      Bed leveling does what the term suggests - it tries to level the bed.
      Homing is the process of determining that an axis has moved to some known position "telling" the firmware where the hardware actually is.
      Generally you need to:
      • home Z using G28 Z
      • level the bed using G32 and a correctly created bed.g file
      • set the Z=0 datum using a single G30 and the correct position for the probe point
      • load the height map (if you have created one) using G29 S1
      • fcwiltundefined
        fcwilt @Veti
        @Veti said in First Layer and Extrusion Problems:
        @fcwilt said in First Layer and Extrusion Problems:
        How can we be sure the pitch is 8mm?
        i cant, but there is a very high chance that isnt a M8 metric lead screw.
        Agreed given the 8mm is a common value.
        • Vetiundefined
          Veti @fcwilt
          @fcwilt
          but you are right.
          @Frederik there are several things you have been asked that you have not given an answer to.
          • Frederikundefined
            Frederik @fcwilt
            @fcwilt you are right it was a wrong setting from yesterday. its a normal tr8 4 stop with 8 Lead Spindle
            • Frederikundefined
              Frederik
              i had to test your tips one after the other.... now my z offset is working as it should.
              • Frederikundefined
                Frederik
                my bed.g File at the Moment:
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
                ;Probe 3-point
                G30 P0 X330 Y240 Z-9999 ; Front Left
                G30 P1 X150 Y0 Z-9999 ; Middle Back
                G30 P2 X0 Y248 Z-9999 S3 ; Front Right and compensate 3mm
                • Frederikundefined
                  Frederik
                  and this my actual homez.g File:
                  ; homez.g
                  ; called to home the Z axis
                  G91 ; relative positioning
                  G90 ; absolute positioning
                  G1 X200 Y200 F6000 ; go to first probe point
                  G30 ; home Z
                  • Vetiundefined
                    Veti
                    so run a G32 and then G29 and post the new picture.
                    • fcwiltundefined
                      fcwilt @Frederik
                      ; homez.g
                      G30 ; home Z
                      You can at this point add:
                      G32
                      G1 X200 Y200 F6000
                      G30
                      The reason for the last two lines is the bed leveling can change your Z=0 datum it needs to be set again - just to be safe.
                      If you wish to probe at the actual center of the bed you will need to adjust the G1 X and Y values to compensate for the probe X and Y offsets.
                      To insure that I always move to the same point with I need to do a G30 I have a macro file "centerprobe.g" that contains this:
                      G90        ; absolute
                      G1 Z5 F1200        ; move to probing height
                      G1 X{-sensors.probes[0].offsets[0]}, Y{-sensors.probes[0].offsets[1]}, F6000 ; move to bed center for probing
                      The second G1 command takes advantage of the v3 firmware to access the probe X and Y offset values.
                      BUT the way my printer is setup the Z axis is already homed whenever I execute this macro so the G1 Z5 command will work.
                      Frederikundefined 1 Reply Last reply Reply Quote 0
                      • Frederikundefined
                        Frederik @fcwilt
                        @fcwilt ok, i will add these commands
                        • fcwiltundefined
                          fcwilt @Frederik
                          @Frederik
                          I was editing while you were posting - please check to see if you saw all of what meant to post.
                          • Frederikundefined
                            Frederik
                            i am back,
                            i editet my Files, generatet the macro file centerprobe.g
                            and insert the additonal G32 in my homez.g
                            the x and y position is now with the probe offsets the center of my build area.
                            ; homez.g
                            G32
                            G1 X165 Y187 F6000 ; go to first probe point
                            G30 ; home Z by True bed leveling 3 points in bed.g
                            • fcwiltundefined
                              fcwilt @Frederik
                              Given you are new to this I should have mentioned that to use the "centerprobe.g" macro you need to put M98 P"centerprobe.g" into your code whenever you want to move the probe to the center of the bed.
                              So instead of the G1 command preceeding the G30 you would have M98 P"centerprobe.g" BUT you will need to comment out the G1 line in "centerprobe.g" that tries to move on the Z axis since that line assumes Z is already homed.
                              • Frederikundefined
                                Frederik
                                ok thank you, i try it and post the results in a moment
                                • Vetiundefined
                                  Veti
                                  you should really keep your bed.g and homing files as simple as possible.
                                  then use a macro to combine the actions.
                                    A Former User
                                    Given that it's a core-xy which normally homes one axis after the other (normally x then y) after x homes you can tell x to place the nozzle to the centre of the bed and then home y and again tell y to go to the centre of the bed no extra files or code required then home z can be executed as normal from the centre of the bed
                                      A Former User
                                      ; bed.g
                                      G28                         ; Home all
                                      G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
                                      G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
                                      G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
                                      G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
                                      G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
                                      G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
                                      G91                         ; Switch to relative positioning moves
                                      G1 H2 Z5 F8000              ; Drop the Z axis (the bed) by 5mm relative to its current position
                                      G90                         ; Revert back to absolute positioning moves
                                      G1 X160 Y155 F8000          ; Position the nozzle at the centre of the bed
                                      G30                         ; Probe and set the height as probed
                                      G29 S1 P"heightmap.csv"     ; Load the height map
                                      This is an operational bed.g file for a core-xy with x3 z axis lead screws
                                      • Frederikundefined
                                        Frederik @A Former User
                                        @CaLviNx THank you 🙂 i will have a look and adjust mine accordingly
                                        • fcwiltundefined
                                          fcwilt @A Former User
                                          @CaLviNx said in First Layer and Extrusion Problems:
                                          That is assuming you don't care if the probe is at the center of the bed.
                                          Because I want to probe the center of the bed I created the macro I mentioned which does the math required.
                                            A Former User @fcwilt
                                            That is assuming that you DO care that the probe IS at the centre of the bed because you have already told x and y to put the nozzle/probe to the centre of the bed ready for z to home using the probe, this way NO extra macro is required, making it nice and simple.
