    First Layer and Extrusion Problems
    5.6k
    • Vetiundefined
      Veti
      so run a G32 and then G29 and post the new picture.
      • fcwiltundefined
        fcwilt @Frederik
        @Frederik said in First Layer and Extrusion Problems:
        and this my actual homez.g File:
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool v3.1.7 on Wed Nov 18 2020 18:04:17 GMT+0100 (Mitteleuropäische Normalzeit)
        G91 ; relative positioning
        G90 ; absolute positioning
        G1 X200 Y200 F6000 ; go to first probe point
        G30 ; home Z
        You can at this point add:
        G32
        G1 X200 Y200 F6000
        G30
        The reason for the last two lines is the bed leveling can change your Z=0 datum it needs to be set again - just to be safe.
        If you wish to probe at the actual center of the bed you will need to adjust the G1 X and Y values to compensate for the probe X and Y offsets.
        To insure that I always move to the same point with I need to do a G30 I have a macro file "centerprobe.g" that contains this:
        G90        ; absolute
        G1 Z5 F1200        ; move to probing height
        G1 X{-sensors.probes[0].offsets[0]}, Y{-sensors.probes[0].offsets[1]}, F6000 ; move to bed center for probing
        The second G1 command takes advantage of the v3 firmware to access the probe X and Y offset values.
        BUT the way my printer is setup the Z axis is already homed whenever I execute this macro so the G1 Z5 command will work.
        Frederikundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik @fcwilt
          @fcwilt ok, i will add these commands
          • fcwiltundefined
            fcwilt @Frederik
            @Frederik
            I was editing while you were posting - please check to see if you saw all of what meant to post.
            • Frederikundefined
              Frederik
              i am back,
              i editet my Files, generatet the macro file centerprobe.g
              and insert the additonal G32 in my homez.g
              the x and y position is now with the probe offsets the center of my build area.
              ; homez.g
              G32
              G1 X165 Y187 F6000 ; go to first probe point
              G30 ; home Z by True bed leveling 3 points in bed.g
              • fcwiltundefined
                fcwilt @Frederik
                Given you are new to this I should have mentioned that to use the "centerprobe.g" macro you need to put M98 P"centerprobe.g" into your code whenever you want to move the probe to the center of the bed.
                So instead of the G1 command preceeding the G30 you would have M98 P"centerprobe.g" BUT you will need to comment out the G1 line in "centerprobe.g" that tries to move on the Z axis since that line assumes Z is already homed.
                • Frederikundefined
                  Frederik
                  ok thank you, i try it and post the results in a moment
                  • Vetiundefined
                    Veti
                    you should really keep your bed.g and homing files as simple as possible.
                    then use a macro to combine the actions.
                      A Former User
                      Given that it's a core-xy which normally homes one axis after the other (normally x then y) after x homes you can tell x to place the nozzle to the centre of the bed and then home y and again tell y to go to the centre of the bed no extra files or code required then home z can be executed as normal from the centre of the bed
                        A Former User
                        ; bed.g
                        G28                         ; Home all
                        G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw
                        G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw
                        G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw
                        G30 P0 X2 Y-2 Z-99999       ; Probe near the front left lead-screw (Second Pass)
                        G30 P1 X152 Y278 Z-99999    ; Probe near the rear lead screw (Second Pass)
                        G30 P2 X290 Y-2 Z-99999 S3  ; Probe near the front right lead-screw (Second Pass)
                        G91                         ; Switch to relative positioning moves
                        G1 H2 Z5 F8000              ; Drop the Z axis (the bed) by 5mm relative to its current position
                        G90                         ; Revert back to absolute positioning moves
                        G1 X160 Y155 F8000          ; Position the nozzle at the centre of the bed
                        G30                         ; Probe and set the height as probed
                        G29 S1 P"heightmap.csv"     ; Load the height map
                        This is an operational bed.g file for a core-xy with x3 z axis lead screws
                        • Frederikundefined
                          Frederik @A Former User
                          @CaLviNx THank you 🙂 i will have a look and adjust mine accordingly
                          • fcwiltundefined
                            fcwilt @A Former User
                            @CaLviNx said in First Layer and Extrusion Problems:
                            That is assuming you don't care if the probe is at the center of the bed.
                            Because I want to probe the center of the bed I created the macro I mentioned which does the math required.
                              A Former User @fcwilt
                              @fcwilt said in First Layer and Extrusion Problems:
                              That is assuming that you DO care that the probe IS at the centre of the bed because you have already told x and y to put the nozzle/probe to the centre of the bed ready for z to home using the probe, this way NO extra macro is required, making it nice and simple.
                              • fcwiltundefined
                                Except you are not probing the center of the bed which I consider essential.
                                  @fcwilt
                                  who said you are not probing the centre of the bed?
                                  • fcwiltundefined
                                    @fcwilt
                                    Your example stated that you were positioning the nozzle at the center of the bed, not the probe.
                                      @fcwilt
                                      With the nozzle you usually have a probe yes? So you place the nozzle/probe at the "centre" ready to probe
                                      I incorrectly assumed that you would manage make that mental connection between nozzle and or probe on your own, apologies for my incorrect assumption
                                      • fcwiltundefined
                                        With most probes it will not be possible to place both the nozzle and the probe at the center of the bed at the same time.
                                        Your example stated you were positioning the nozzle at the center of the bed.
                                        At the position, with most probes, you are not going to be probing the center of the bed.
                                          @fcwilt
                                          My probe offset is Y0, X-7 on a 500x500mm bed that as near as dammit the centre, centre enough that I wouldn't be pedantic enough to worry about it, and anyway it was just a "generic" term "nozzle" my home.x, home.y & bed.g are suitably adjusted to pedantically place the probe to the bed centre.... with most probes you ARE going to be probing the centre, it is just that the NOZZLE wont be in the centre.
                                          And the key word is "most" precision piezo springs to mind......
                                          • fcwiltundefined
                                            You posted an example that stated "nozzle". I therefore assumed you meant "nozzle".
                                            I cannot read your mind and can only go by what you posted.
                                            When trying to help a beginner learn how to do things I think it best to be clear in what you are telling them to do.
                                            Telling them to center the nozzle when you mean probe is not my idea of being clear.
                                            Frederikundefined A Former User? 2 Replies Last reply Reply Quote 0
