migrate config.g
sounds unlikely, what is the output if you run the gcode
M98 P"config.g"
@bearer it reports some errors:
![0_1605874708756_18f4831c-e02f-4985-bcd1-f63603745d58-image.png](Uploading 100%)
Im trying to SSH to the raspi, but default user pi, passed raspberry is not working, has it been changed?
Please try uploading picture again, or better, copy/paste the text.
As for ssh, no, its still the default pi / raspberry for the images i have tried at least.
@bearer I uloaded the config.g file using the interface. Something is going wrong there because Im receiving errors. I fixed most of them, but for example Im getting:
M307: error bad model parametersBut this is the same config I was using and printing with with my previous duet3/octoprint.
What is the meaning of this error?
The only M307 commands I have in my config.g is:
M307 H0 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
M307 H1 B0 S1.00 ; disable bang-bang mode for heater 1 and set PWM limit
M307 H2 B0 S1.00 ; disable bang-bang mode for heater 2 and set PWM limitAnd all heaters were working ok.
Hard to say without seeing the config file tbh.
But if you can fix the errors you're clearly editing the correct file no?
@bearer
; Configuration file for Duet 3 (firmware version 3) ORIGINAL
;; General preferences
; M550 P"Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
; M552 S0 disable network; Drives
M569 P0.0 S0 D2 ; physical drive 0.0 goes forwards X Se invirtieron los cables tambien. Se agrego D3 para stealhtchop3
M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards Y Ultimo cambio: de S0 a S1. Se agrego D3 para stealhtchop3
M569 P0.2 S1 D2 ; physical drive 0.2 goes forwards
M569 P0.3 S1 D2 ; physical drive 0.3 goes reverse
M569 P0.4 S0 D2 ; physical drive 0.4 goes forwards
M569 P0.5 S1 D2 ; physical drive 0.5 goes backwardsM584 X0.0 Y0.1 Z0.2:0.3 E0.4:0.5 ; set drive mapping
M350 X16 Y16 Z32 E16:16 I1 ; configure microstepping with interpolation
; M92 X160.32 Y160.32 Z3200.00:3200.00 E827.22 set steps per mm
M92 X80.16 Y80.16 Z3200.00 E428.25:428.25 ; set steps per mm
M566 X900.00 Y900.00 Z300.00 E450:450 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z240.00:240.00 E2400.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z20.00:20.00 E500.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z900:900 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X400 Y350 Z400 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z2 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"^!io3.in" H5 F120 T18000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y28.5 Z0.245 ; set Z probe trigger value, offset and trigger height
; M557 X25:310 Y27:312 S57:57 define mesh grid for beta 3
M557 X50:340 Y29:329 S82:30 ; define mesh beta4; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
;M307 H0 B0 D30 S1.00 ; enable PID para camara, deadtime en 30 segundos
;M140 H0 ; map heated bed to heater 0
M141 H0 ; map chamber to heater 0
M143 H0 S130 ; set temperature limit for heater 0 to 130C
M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
M308 S2 P"temp2" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
;M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
;M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; define tool 0
M563 P1 D1 H2 ; define tool 1
G10 P1 X-61 Y0 Z-2.05 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M915 X Y S1 R0 F0 ; sensroless sensitivity 1 for beta 4 and 2 beta3; movments without homing
M564 H0; Miscellaneous
M207 S6 R0.2 F1800 ;firmware retraction
M83 ; relative extrusion
M950 S0 C"0.out9" ; servo "0" in pin out9
M280 P0 S92 ; move servo to rest position
M376 H30 ; cancell mesh levelling at 30 mm
M143 S450 ; set max temp to 450 degrees for T0
M143 H2 S450 ; set max temp to 450 for T1
M950 J0 C"^io8.in" ; Definition of emervengy stop pin
M581 P0 R0 T0 ; Assigment of the emergency stop
M950 P5 C"out3" ; assign gpio port 5 to out3 for buzzer. control win M42 P5 SX range 0 to 1
;T0 ; select first toolI had to comment that last T0 line, it was complaining about not being able to select tool...
@Tinchus said in migrate config.g:
M92 X80.16 Y80.16 Z3200.00 E428.25:428.25 ; set steps per mmthere is no point going for x32 interpolation on the z axis
x16 is more than fine.even without interpolation you are at 0.01mm per step
Do you also have a config-override.g present with M307 commands in it?
You can an M501 command at the end of config.g, which loads config-override.g, perhaps it's from an older version though?
Are you able to edit the config.g now? or are you still having problems with that?
Can you tell us what point you're currently at?
@Phaedrux yes, I found these lines in config-override:
M307 H0 A26.3 C284.7 D3.5 S1.00 V23.9 B0
M307 H1 A657.9 C255.6 D5.8 S0.95 V23.9 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0I guess they were created after automatic tunning of heaters
Im able to edit config.g directly from the duet web control.
My actual state is kind of bad. Im getting many different errors, it is a mess actually. Im updating all software from scratch to be sure there is nothing corrupt.
My question is: my config.g file was working ok with duet3+octoprint. I was printing with on problems.
The config.g file I trying to use with duet web control is the same file, I uploaded it from the interface, why Im having these problems?This is what I did:
.- my duet came with an SD card, that is the one Im using.
.- I updated the firmware to 3.1.1 using the windows USB connection method
.- I connected the ribbon cable.
.- Then I ran the sudo aptget update instructions I found in duet website tutorial, no errors reported.
Is this OK? do I need to update DWC too?For example, my Z motors are not moving at all with the DWC, there was no problem with them using the same config.g and octoprint
Ideas? -
Can you please send M122 in the gcode console and post the results?
I suggest getting a fresh image of DuetPi from here and reflashing your Pi SD card.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_DuetPi
Then doing a sudo apt update sudo apt upgrade
@Phaedrux Im super confused. I downloaded the new raspi image, I did the upgrades (they are launched in the we interface at the first boot, nice!)
After reboot I uploaded my config files.
1.- problem: I noticed there is no ssh connection available
2.- I tried to do a homeing: HOME ALLI get this error:
Error: G0/G1: insufficient axes homedMy homeall.g was working ok before:
; homeall.g
; called to home all axes
M280 P0 S92
T0 P0; Calibration of motor currents etc
G91
G1 H2 Z0.02 F500
G4 P150
G1 H2 X0.02 F2000
G4 P150
G1 H2 Y0.02 F2000
G4 P150M400
M913 X60 Y60 ; drop motor current to 60%
M400; HOME X/Y
G1 H1 Y-400 X-400 F10000 ;
G1 Y175 X175 F5000 ;
M400
G1 H1 Y-400 F10000
G1 Y175G1 H1 X-400 F10000
G1 X175
M400G90 ; absolute positioning
M400
M913 X100 Y100 ; drop motor current to 100%
M400; Z HOMING
; G1 X175 Y175 F5000 go to first bed probe point and home Z for beta3
G1 X135 Y100 F5000 ; for beta4
G30Home X and Y reports the same error. The files were also working ok.
the files:
; homex.g
; called to home the X axis
;M280 P0 S92
G91
G1 H2 Z0.02 F500
G4 P150
G1 H2 X0.02 F2000
G4 P150
G1 H2 Y0.02 F2000
G4 P150
G1 X50 F5000
M400
M913 X60 Y60
G1 H1 X-400 F10000
G90
M913 X100 Y100
G1 X175 F4000
M400M280 P0 S92
T0 P0G91
G1 H2 Z0.02 F500
G4 P150
G1 H2 X0.02 F2000
G4 P150
G1 H2 Y0.02 F2000
G4 P150
M400
G1 Y50 F5000
M400
M913 X60 Y60
G1 H1 Y-400 F10000
G90
M913 X100 Y100
G1 Y175 F4000
M400The M122 reports this:
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956L2-G43S4-6JTD2-3SJ6J-1A6GG
Used output buffers: 1 of 40 (10 max)
Static ram: 154604
Dynamic ram: 162568 of which 68 recycled
Exception stack ram used: 412
Never used ram: 75564
Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1460) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:07:48 ago, cause: power up
Last software reset at 2020-11-20 19:38, reason: User, spinning module LinuxInterface, available RAM 75160 bytes (slot 2)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 34.3, current 39.6, max 39.7
Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: standstill, reads 10286, writes 22 timeouts 0, SG min/max 0/92
Driver 1: standstill, reads 10287, writes 22 timeouts 0, SG min/max 0/90
Driver 2: standstill, reads 10289, writes 20 timeouts 0, SG min/max 0/1023
Driver 3: standstill, reads 10290, writes 20 timeouts 0, SG min/max 0/1023
Driver 4: standstill, reads 10295, writes 15 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 10296, writes 15 timeouts 0, SG min/max 0/0
Date/time: 2020-11-21 00:31:26
Slowest loop: 4.03ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 374, MaxWait: 98508ms
=== MainDDARing ===
Scheduled moves: 13, completed moves: 13, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 0 -1 -1 -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.82ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 1785, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 17ms ago
RX/TX seq numbers: 14410/14411
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Full transfers per second: 25.35
Thanks in advance
- Ethernet -
When connected to the DWC, the system tab on the left side is used to show you your config and homing files. Is that where you are editing your files?
Your homing files isn't quite right for corexy.
; HOME X/Y
G1 Y175 X175 F5000 ;This section will home both x and y but will stop both axis when either one hits. So the second move at least one of the axis will not yet be homed.
Use something like this instead for corexy
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_homeall_g_file
G91 ; relative mode G1 H1 X-240 Y-240 F3000 ; coarse home X or Y G1 H1 X-240 ; coarse home X G1 H1 Y-240 ; coarse home Y G1 X4 Y4 F600 ; move away from the endstops G1 H1 X-10 ; fine home X G1 H1 Y-10 ; fine home Y ''' Z homing section follows'''
@Phaedrux
I did foloowed those instructions:
"On a CoreXY printer, the whole move will be terminated when the first homing switch is triggered. Therefore, to do simultaneous XY homing, your homeall.g file needs to first home X and Y together, then home them separately. " My homeall.g is the same, I just changed the number:; HOME X/Y
G1 H1 Y-400 X-400 F10000 ; Home at the same time as the instructions says
G1 Y175 X175 F5000 ; Dont remember why but I added this just to move the carriage to the "center"
M400; this is not necessary I guess
G1 H1 Y-400 F10000 ; and from here it is as instructed
G1 Y175
G1 H1 X-400 F10000
G1 X175
M400But this is not the problem, question and problems remains: this config works OK when I use it on the duet as stand alone or with octiprint. What Im doing wrong that nothing is working ok with the DWC? All my tool change routines also don't work at all. The servo is not being activated, or it actives and moves to a position and immediately returns to the old position all by itself while the printer is doing nothing.A faulty board can be the reason for this? (I guess no, because as I said, in stand alone or with octoprint it is working ok)
Z motors don't work for example. I tried switching back to the duet+octoprint just to discard hardware issues, and the Z motors work okMore info: if I do a manual tool change, To > T1 the head should move to a position, activate servo to position 47 (lowers the tool).
When I try to do that, the servo moves, then by itself goes back to original position and then the board resets. These are the messages I see in console when that happens:11/21/2020, 7:46:08 AM Warning: Controller has been reset
11/21/2020, 7:46:08 AM Connection to Duet established
11/21/2020, 7:46:08 AM Warning: Lost connection to Duet (Board is not available (no header)) -
I found many solutions to my problems, I post my findings, it might be useful for somebody:
.- The ribbon cable used for the SPI connection, it handles high frequency signals, and it is a source os strong "noise". My servo motor is passing just on top of the ribbon cable, and the noise was getting into this cable and making my servo to have this "ghost" movements. I shielded the cable and the problem is gone. This was not happening with the USB connection so the source of the noise comes from the ribbon cable. I will test and watched more closely this flat cable, probably I will shield it too just in caso in order to not get noise in other cables.
.- The Z motors not working: the same exact config I was using with DUET3 connected by USB to raspberry is not working with duet3 connected through SPI to raspberry and using DWC. I guess the problem is with DWC, because I changed my original config to this:
350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation. Changed Z to 16 from 32
; M92 X160.32 Y160.32 Z3200 E827.22 set steps per mm
M92 X80.16 Y80.16 Z1600 E428.25:428.25 ; set steps per mm changed Z from 3200 to 1600
M203 X18000.00 Y18000.00 Z340.00 E2400.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z20 E500.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z900 E1000:1000 I30Notice that I removed the Z configuration. Correct or not, the original configuration was working, on the same duet board, so the problem must bu DWC?
I hope it helps somebody. I will keep solving issues
; HOME X/Y
G1 Y175 X175 F5000 ; Dont remember why but I added this just to move the carriage to the "center"The first move will only ever home one of the axis, therefore, the following move will provoke the error message because at least one of those axis are not yet homed.
That's why in the example the following two moves home the axis individually again to ensure that whichever one was missed gets homed.
It really sounds like the config you're looking at isn't the same as what the duet is executing.
How are you viewing and editing these files? When you make a change does it actually take effect?
@Phaedrux Just to be sure Im ONLY using the duet web interface for editing. And believe it or not... the conf I posted above is working now perfectly.
I have one not related question: I'm trying to create my own combination of colors for the interface (since I have some color distinctions problems jajaja.... where do I find the CSS file, the ones located at boot/www seems not to be the ones being used -
boot/www
/opt/dsf/sd/www but they should be minimized and less than usefull?
https://github.com/Duet3D/DuetWebControl might be more apropriate
@bearer You I should rebuild the DWC from scratch? Im a little afraid of doing that after having to do such a work to have my config running.
The sd card that came with the board seems to have a 3.2 version of the DWC because I can see that have plugins wich in theory are not suppose to be in 3.1.1 version. After I did a sudo apt updete/upgrade, the DWC seems to be downgraded, but plugins were still working, but everything was very unstable (for example after doing a homing the status remained in "busy" for ever": Installing a fresh duetpi image and doing the upgrade seems to work much better)
So in your opinion I can upgrade manually the DWC ? I can see wich version ti is the one available in that github -
What version of DWC does it report in the interface itself?
@Phaedrux Duet Web Control 3.1.1
