    First Layer and Extrusion Problems
    5.9k
    • Frederikundefined
      Frederik @A Former User
      @CaLviNx Ok, i will test this in the morning.
      I have 2 Linear Rails on z ( left + right in the middle ). The Leadscrews are ~ 6 cm in front of them
        A Former User @Frederik
        @Frederik said in First Layer and Extrusion Problems:
        A very strange (to me anyway) arrangement for linear rails, in that you would expect 3 rails with three lead screws.
        But if it works then happy days. Personally I always have x3 rails/lead screws and have the bed frame with a degree of articulation to allow the levelling to operate as it should, once you get it setup the levelling gives you great prints
        Frederikundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          @CaLviNx said in First Layer and Extrusion Problems:
          G30 P0 X2 Y-2 Z-99999 ; Probe near the front left lead-screw
          G30 P1 X152 Y278 Z-99999 ; Probe near the rear lead screw
          G30 P2 X290 Y-2 Z-99999 S3 ; Probe near the front right lead-screw
          M671 X425:200:-25 Y240:-25:240 S1 ; leadscrews at front left, rear middle and front right
          how are these points near the leadscrews?
          • Frederikundefined
            @CaLviNx That´s how this kit is designed. Eventually, I will change it to a kinematic mount without the 2 Linear Rails like the HevOrt. At the moment I have a battle with my E3d Volcano... it is constantly clogging and I don´t know what
            I´m doing wrong... trying to print PLA with ~ 205 ° Nozzle and 60° Bed.
            • Frederikundefined
              Frederik @Veti
              @Veti i have this settings:
              M671 X425:200:-25 Y240:-25:240 S3 - position of Spindles with drives 2.3.4
              and this are the spot i´m probing:
              G30 P0 X330 Y250 Z-99999 ; Probe near the front left lead-screw
              G30 P1 X165 Y0 Z-99999 ; Probe near the rear lead screw
              G30 P2 X0 Y250 Z-99999 S3 ; Probe near the front right lead-screw
              • Vetiundefined
                Veti
                is 0,0 not the bottom left of your printbed?
                • Frederikundefined
                  Frederik @Veti
                  @Veti x0,y0 ls in my case the right, rear corner
                  • Frederikundefined
                    Frederik
                    I could only mount the Endstop on the left side of my carriage and the Y Endstop is at the back
                    • Vetiundefined
                      Veti @Frederik
                      thats going to be very confusing.
                      certainly because of that you got the offset of your probe wrong.
                      Frederikundefined 2 Replies Last reply Reply Quote 0
                      • Frederikundefined
                        Frederik @Veti
                        @Veti should i change it ?
                        • Frederikundefined
                          Frederik @Veti
                          @Veti this is my actual drive mapping and endstop config:
                          M569 P0.0 S0                                          ; physical drive 0.0 goes backwards
                          M569 P0.1 S0                                          ; physical drive 0.1 goes backwards
                          M569 P0.2 S0                                          ; physical drive 0.2 goes backwards
                          M569 P0.3 S0										  ; physical drive 0.3 goes backwards
                          M569 P0.4 S0										  ; physical drive 0.4 goes backwards
                          M569 P0.5 S1                                          ; physical drive 0.5 goes forwards
                          M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5                      ; set drive mapping```
                          ;Endstops
                          M574 X2 S1 P"!io1.in"                                 ; configure active-high endstop for high end on X via pin !io1.in
                          M574 Y1 S1 P"!io0.in"                                 ; configure active-high endstop for low end on Y via pin !io0.in
                          M574 Z2 S2                                            ; configure Z-probe endstop for low end on Z
                          • Vetiundefined
                            Veti
                            can you set 0,0 in your slicer to be top right? i just checked in prusaslicer and 0,0 is bottom left
                            • Frederikundefined
                              Frederik @Veti
                              @Veti i have to look. i used cura 4.8.0 at the moment. I didn´t want to spend money on simplyfy 3d bevor the new version 5 is released. Hopefully soon 🙂
                              • Frederikundefined
                                Frederik @Veti
                                @Veti yes, its possible. you can set high or low endstop positions in advanced printer setttings
                                • Vetiundefined
                                  Veti @Frederik
                                  @Frederik
                                  my recommendation is to not do it. why do you think that is better?
                                  • Frederikundefined
                                    Frederik
                                    what could be the cause of this message :
                                    G28 Z
                                    Error: Z probe already triggered at start of probing move
                                    Error: Homing failed
                                    i got this message on every 4th or 5th try to home z.
                                    its a genuine bltouch
                                    • Vetiundefined
                                      Veti
                                      that sounds like a wiring probem
                                      • Frederikundefined
                                        Frederik @Veti
                                        @Veti i tought, perhaps its the standard and would be better for compatibility or troubleshoooting reasons...
                                        • Vetiundefined
                                          Veti @Frederik
                                          @Frederik
                                          no the standard is 0,0 is bottom left.
                                          • Frederikundefined
                                            Frederik @Veti
                                            @Veti ok , one moment i will check it with my multimeter... could it be a bad crimp ?
