    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti
      G1 X-1.3000000000000007 Y1 F6000 ; go to first bed probe point and home Z
      replace that with
      G1 X50 Y50 F600
      when exactly does it try to move past the endstops?
      during the first move?
      shattyundefined 1 Reply Last reply Reply Quote 0
      • shattyundefined
        shatty @Veti
        @Veti Yes. I tried that setting and no good. Its random in which direction it goes to home and it just slams at the end of each axis.
        • shattyundefined
          shatty
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
          G91 ; relative positioning
          G1 H1 X-355 Y-355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-355 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X50 Y50 F600 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          M550 P"E5Plus" ; set printer name
          M551 P"xxxx" ; set password
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P2 S0 ; physical drive 2 goes backwards
          M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
          M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X350 Y350 Z400 S0 ; set axis maxima
          M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
          M557 X15:190 Y15:190 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M143 H0 S110 ; set temperature limit for heater 0 to 110C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S280 ; 280 deg max on hot end
          M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
          • Vetiundefined
            Veti @shatty
            @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
            i have never heard of this happening.
            let me get this straight.
            you home your printer. it moves to the right?
            you restart the printer it moves to the left?
            post the output of M119 when no endstop is pressed.
            post the output of M119 when only the enstop for the x axis is pressed
            • shattyundefined
              shatty @Veti
              @Veti
              When I turn it on, nothing moves unless i press the home button. There is no telling which direction it will go if i center the extruder in the middle of the area. Where am I supposed to set the hotend before I turn on the printer?
              • Vetiundefined
                Veti @shatty
                @shatty
                please test the stepper motor direction using this
                https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Checking_connected_stepper_motors
                report for x y and z
                • shattyundefined
                  shatty
                  Heres a video of what it does....
                  https://drive.google.com/file/d/1IeBbFe_YLu9XSz0GbuNmigxwDfcq57Ay/view?usp=sharing
                  • Vetiundefined
                    Veti
                    please do the testing from the webui to rule out a bad touch screen connection.
                    • Vetiundefined
                      Veti
                      btw what is that strange sound at the start of the homing?
                      • shattyundefined
                        shatty @Veti
                        @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                        TS is fine.
                        Anyways....hitting any positive value will move each toward the endstop switch...The Z is not right..Looks like they are fighting each other
                        Vetiundefined 2 Replies Last reply Reply Quote 0
                        • shattyundefined
                          shatty @Veti
                          The Z axis motors are fighting each other.
                          • Vetiundefined
                            Veti @shatty
                            that would indicate that your motors are turning in the wrong direction.
                            • shattyundefined
                              shatty @Veti
                              @Veti
                              OK Let me fix that.
                              • Vetiundefined
                                Veti @shatty
                                that means on of your motors is wired in the opposite direction
                                • Vetiundefined
                                  Veti @shatty
                                  TS is fine.
                                  i beg to differ. The bad command 55 at the end is an indication.
                                  • shattyundefined
                                    shatty @Veti
                                    @Veti Thats because I hit stop
                                    Not the motors are moving away from endstops with hitting the positive values. Z still fighting each other. They are in series config because there are 2 on 1 driver
                                    • shattyundefined
                                      shatty
                                      Paneldue5i is connected with ribbon cable only. How can it be wrong?
                                      • Vetiundefined
                                        Veti @shatty
                                        that mean you have to reverse the wiring of one of your stepper motors
                                        • shattyundefined
                                          shatty @Veti
                                          @Veti
                                          OK. TY. Hopefully I can gain progress now.
                                          • shattyundefined
                                            shatty @shatty
                                            @shatty
                                            Z wired right. Only thing is...small little problem....THE WIRE IS CUT!!! THRU 3 OF THE 4 WIRES ON ONE OF THE Z STEPPERS!!!!!
