    First Layer and Extrusion Problems
    5.6k
    • Vetiundefined
      Veti @Frederik
      @Frederik said in First Layer and Extrusion Problems:
      what would i have to change in my config.g to use a capazitive sensor with 3 wires ?
      see
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
      or
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_PNP_output_normally_open_inductive_or_capacitive_sensor
      Frederikundefined 1 Reply Last reply Reply Quote 0
      • Frederikundefined
        Frederik @Veti
        @Veti Thank you.
        Do you have an idea why I can't get optical switches to work? the LED on the sensor work and trigger, but the duet doesn't recognize it
        • Frederikundefined
          Frederik @A Former User
          @CaLviNx WOW, 8 operationl Printers ? Thats amazing. Do you make a living out of printing ?
          Ok, good to know, i was thinking about getting one for testing purposes.
          • Vetiundefined
            Veti @Frederik
            maybe you switched signal and ground. how did you connect it. the lerdge endstop work fine in my delta.
            btw only black objects will really block the light.
            • Frederikundefined
              Frederik @Veti
              @Veti i connect ground to G, V to 5V, and S to the io.in.
              the led on the switch is on but i doesnt trigger in the software
              • Vetiundefined
                Veti
                the lerdge endstops are meant for 3.3v but should also work in 5v mode
                post the changes you did in the config
                • Frederikundefined
                  Frederik @Veti
                  @Veti i used this config:
                  M574 X2 S1 P"!io1.in"                                 ; configure active-high endstop for high end on X via pin !io1.in
                  M574 Y1 S1 P"!io0.in"                                 ; configure active-high endstop for low end on Y via pin !io0.in
                  Should i connect with the additional resistors like it is mentioned in the dozuki
                  3.3V-compatible optical endstop
                  Connect Gnd to Gnd, Vcc of the opto sensor to 3V3, and the output of the opto sensor to STP/IN. Opto sensors usually have active high outputs, so use S1 in the M574 command.
                  Note: opto endstops made to the Generation 7 design are often claimed to be 3.3V-compatible, but in fact the design is marginal with a 5V supply and frequently doesn't work at all on 3.3V. Here are some workarounds:
                  - This design normally works with a 3.3V supply if you replace the 180 ohm opto switch series resistor resistor by 100 ohms. Tip: if your opto endswitch uses surface mount resistors, instead of removing the 180 ohm resistor it is easier to solder a 200 or 220 ohm resistor on top of it, so that the two resistors are connected in parallel. Make sure you pick the correct resistor to replace or solder another on top of! There is often also a load resistor, value 1K or higher.
                  - If you are using Duet 3 then you can use the 5V pin on the IO_ connector to provide power to the opto endstop instead of using 3.3V power.
                  - If you are using a Duet WiFi/Ethernet hardware rev 1.04 or later or a Duet Maestro, these boards can tolerate 5V on the endstop inputs. So you can provide them with a 5V supply instead (leaving the centre pin of the endstop connector not connected) and connect the outputs of your endstops directly to the STP/IN pins of the endstop connectors.
                  • Vetiundefined
                    Veti
                    i run the endstops fine on my delta without resistors. the lerdge endstops are actually designed for 3.3v because the lerdge board run on 3.3v
                    check with m119 if you can trigger them.
                    • Frederikundefined
                      Frederik @Veti
                      @Veti no, it doesent work
                      i just found a seconnd pair of endstop switches for a ramps board
                      • Vetiundefined
                        Veti
                        maybe a bad crimp in the cable?
                        • Frederikundefined
                          Frederik @Veti
                          @Veti the led on the switch is on , but it doesent trigger
                          • Vetiundefined
                            Veti @Frederik
                            @Frederik
                            it could be a bad crimp in the signal wire
                            • Vetiundefined
                              Veti @Frederik
                              @Frederik
                              the advantage of the lerdge endstops is they light up when they are triggered. the ramps endstops light up when they are not
                              Frederikundefined 2 Replies Last reply Reply Quote 0
                              • Frederikundefined
                                Frederik @Veti
                                @Veti one moment , i will check it a second time
                                • Frederikundefined
                                  Frederik @Veti
                                  @Veti you were right 😉 I tested it with the original cable and it triggers .....yeah...thank you
                                  now both the ramps and lerdge are functioning
                                  • alexstayundefined
                                    alexstay
                                    This post is deleted!
