    Duet3 config Frustration
    86
    3.5k
    • Vetiundefined
      Veti @BlueDust
      @BlueDust said in Duet3 config Frustration:
      As I had to buy a new BLTouch, I received a v 3.1. is the wiring the same for both versions?
      yes. it should work.
      one user had to enable 3.3v logic.
      BlueDustundefined 1 Reply Last reply Reply Quote 1
      • BlueDustundefined
        BlueDust @Veti
        @Veti
        Does that mean they used the 3.3v instead of the 5v?
        Fun, that 3 letter word with "u" in the middle.
          Phaedrux Moderator @BlueDust
          @BlueDust I wouldn't read too much into it. That particular case could have been any number of things.
          However, if you find you're having troubles here is the relevant doc from antclabs on how to switch between.
          https://www.antclabs.com/logic
          BlueDustundefined 1 Reply Last reply Reply Quote 0
          • BlueDustundefined
            BlueDust @Phaedrux
            @Phaedrux
            AntLabs says the BLTouch 3.1 is 5v, and don't want to confuse myself any more on this if I don't have to. I was just curious as I remember older BLTouches needed resistors or something to make them work on the Duet boards. The documentation on Antlabs website in relation to Duet seems old and trying to keep this simple as it was on the Duet2Eth as I use a BLTouch 2.2. They seem to change things up often and I don't mind making a mistake and fixing it, but don't want to break anything and have to buy a new one for something dumb I did (like not reading the instructions).
            3Pin: Brown (GND), Red (+5V)
            Orange (control signal)
            2Pin: Black (GND) White (Zmin)
            https://5020dafe-17d8-4c4c-bf3b-914a8fdd5140.filesusr.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
            As always. Thanks for the help!
              Duet3 is 5v tolerant so you shouldn't need to change anything on either the duet or BLTouch. It's been that way for a long time now. Should be plug and play.
              • BlueDustundefined
                BlueDust @Phaedrux
                @Phaedrux
                Is the GPIO Port # referring to the io#.in? Where the number would match where the BLTouch is plugged in?
                M280 P0 S80 ; set 80deg servo position on GPIO port 0
                Thanks
                BlueDustundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                • BlueDustundefined
                  BlueDust @BlueDust
                  @Phaedrux
                  I read something on one of the Z Probe M commands and it made me think it was a heater.
                  Self test works now...
                    @Phaedrux
                    Thanks
                    M280 P0 refers to the M950 S0
                    The pin name refers to the servo control pin and the probe signal input pins.
                    Did you get it figured out?
                    • BlueDustundefined
                      BlueDust @Phaedrux
                      @Phaedrux
                      Yes, I think I figured it out as I can now home the printer, and BLTouch is working. But found another issue, this time with my PanelDue. I am trying to find the max/min places for each tool using the PanelDue and it's not working.
                      My PanelDue is only updating temp/axis location after reset (of the PanelDue), but appears to stop after I start moving the motors (homing right now). I am guessing it is interference... Controlling the printer always works. Updating current info on the screen is the only thing that stops working.
                      PanelDue is on 3.2, and Duet3 is on 3.1.
                      Thanks!
                        Stick with 1.24 on the Panel for now. Will work better when the Duet is also on 3.2.
                        • BlueDustundefined
                          BlueDust @Phaedrux
                          @Phaedrux
                          OK thanks!
                          Any idea when RepRap 3.2 will be released? I am only looking for a guess.
                          Sometime this month?
                          • BlueDustundefined
                            BlueDust
                            I just wanted to see this new printer print. And guess what, it's printing. But the part fan isn't turning on automatically. I have to turn it on manually. This must be that F setting on the tool I was playing with before but have no idea how to set it... As I can manually turn the fan on, and it turns on, on the correct tool from DWC... I am not sure what to do to fix this at the moment.
                            • BlueDustundefined
                              BlueDust
                              Tool part cooling fan is swapped. That is the problem. Where do I make that change?
                                dc42 administrators @BlueDust
                                Post your config.g file [again] and we'll tell you.
                                • BlueDustundefined
                                  BlueDust @dc42
                                  So I think I fixed it, as it appears to be working right now... Will not know until I print something with the 2nd tool...
                                  Is this is my current gcode.
                                  Looking at this...
                                  M563 P0 S"LeftExtruder" D0 H1 F0:1
                                  Does the 0 and 1 match up with the Pn parameter under the fans? If it does, I am having a hard time understanding what goes to what between the different Gcode commands, as the letters do not match from one to the other. If it's not obvious, I haven't figured out the logic and not able to easily make the connections to different settings in RepRap 3 yet...
                                  M950 F0 C"out5" Q500
                                  M106 P0 S0 H-1
                                  M950 F1 C"out8" Q500
                                  M106 P1 S1 H1 T40
                                  M950 F2 C"out4" Q500
                                  M106 P2 S0 H-1
                                  M950 F3 C"out7" Q500
                                  M106 P3 S1 H0 T40
                                  M563 P1 S"RightExtruder" D1 H0 F2:3
                                  G10 P1 X0 U0 Y0 Z0
                                  G10 P1 R0 S0
                                  G10 P0 X0 U0 Y0 Z0
                                  G10 P0 R0 S0
                                    The F parameter in M563 matches up with the F parameter in M950 and the P parameter in M106.
                                    • BlueDustundefined
                                      BlueDust @dc42
                                      Thank you!
                                      • BlueDustundefined
                                        BlueDust
                                        If I would like to have independent Z motors on a IDEX Cortesian printer for auto bed tramming, would DUET 3 EXPANSION BOARD 3HC, be the correct expansion board to get, or is there another, possibly better option? Is there anything else I would need to make it work?
                                          How many of the 6 internal drivers are you using?
                                          The 3HC expansion would probably be the best way to add more drivers, unless you wanted to use tool board for the print head and free up a driver that way.
                                          • BlueDustundefined
                                            BlueDust @Phaedrux
                                            @Phaedrux
                                            I am using all 6.
                                            Left Extruder
                                            Right Extruder
                                            X Axis
                                            U Axis
                                            Y Axis
                                            Z Axis (two motors tied into one driver).
