    Reset during print Part 2 - Duet 3.1.1 / 3.2beta3 - Duet3+SBC
    Beta Firmware
    1.7k
    • chrishammundefined
      chrishamm administrators @Via
      @Via Yes, I think so. My printer has the GUI-less variant installed (DuetPi lite), so that probably explains why I couldn't observe this problem before.
      Duet software engineer
      Viaundefined 1 Reply Last reply Reply Quote 0
      • Viaundefined
        Via @chrishamm
        @chrishamm No luck again on standalone with 3.2.0-beta3.2, this time "AssertionFailed"
        I will have another try later with duetpi lite.
        RepRapFirmware for Duet 3 MB6HC version 3.2-beta3.2 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
        Board ID: 08DJM-956L2-G43S4-6J9FA-3S86T-1B5LD
        Used output buffers: 1 of 40 (11 max)
        Static ram: 122236
        Dynamic ram: 168580 of which 376 recycled
        Never used RAM 101000, free system stack 180 words
        Tasks: NETWORK(ready,165) ETHERNET(blocked,109) HEAT(blocked,293) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,358) TMC(blocked,54) MAIN(running,1111) IDLE(ready,19)
        Owned mutexes:
        Last reset 00:00:28 ago, cause: software
        Last software reset at 2020-11-19 11:11, reason: AssertionFailed, GCodes spinning, available RAM 101000, slot 0
        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00427000 BFAR 0x00000000 SP 0x2040fd54 Task MAIN
        Stack: 00000599 004886b0 00468ce5 00000000 ffffffff 20427700 2040e2a0 20427ab0 ffffffff 00000000 56a3ba63 a5a5a5a5 00468d9b 2040fda4 00000000 20423aa8 004664d5 20427aa0 00440cc3 00000000 20427aa4 20408001 2040fdb4 00000101 00469700 0046972e 61000000
        Error status: 0x00
        MCU temperature: min 37.1, current 37.8, max 38.0
        Supply voltage: min 13.0, current 13.0, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
        Driver 0: position 0, standstill, reads 9148, writes 14 timeouts 0, SG min/max 0/0
        Driver 1: position 0, standstill, reads 9149, writes 14 timeouts 0, SG min/max 0/0
        Driver 2: position 0, standstill, reads 9151, writes 14 timeouts 0, SG min/max 0/0
        Driver 3: position 0, standstill, reads 9152, writes 14 timeouts 0, SG min/max 0/0
        Driver 4: position 0, standstill, reads 9153, writes 14 timeouts 0, SG min/max 0/0
        Driver 5: position 0, standstill, reads 9157, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2020-11-19 11:12:08
        Slowest loop: 6.68ms; fastest: 0.21ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 1.2ms, write time 0.0ms, max retries 0
        === MainDDARing ===
        Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 11.39ms; fastest: 0.03ms
        HTTP sessions: 1 of 8
        - Ethernet -
        State: active
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 113, send timeouts 113, longest wait 0ms for type 0, free CAN buffers 47
          @Via , I will look into this later today.
          • Viaundefined
            Via @dc42
            @dc42 Many thanks.
            Is it worth trying with DuetPi Lite? Was going to try earlier but work got in the way 🙄
              dc42 administrators @Via
              @Via said in Reset during print Part 2 - Duet 3.1.1 / 3.2beta3 - Duet3+SBC:
              @dc42 Many thanks.
              I doubt it. The assertion failure looks like it was caused either by memory corruption, or possibly by a power brownout. I guess a hardware problem is also a possibility.
              Can you set up a macro that runs the file in simulation mode within a loop, to see if you can provoke the failure that way?
              Viaundefined 2 Replies Last reply Reply Quote 0
              • Viaundefined
                Via @dc42
                @dc42 I've ran the file as a normal simulation which completes fine.
                Trying to do a macro to loop it but my gcode knowledge is terrible and keep freezing the board 😞 can you point me in right direction?
                Was thinking this (I know never ending loops are bad in themselves but was just going to let it run until I reset it) but looks like it is just buffering all the M24s in one go how would I go about waiting for it to finish one before starting the next?
                M37 S1
                M23 "[PLA] CFFFP_Top - ReRender - zero temps.gcode"
                while true
                	M24
                • Viaundefined
                  Via @dc42
                  @dc42 Stopped overthinking it and just added the M37/M23/M24 to the end of gcode which is looping properly now.
                  Has done ~130 loops with no issues in simulation.
                  • Viaundefined
                    Via
                    Simulation loop ran for 4 1/2 hours (~380 loops) with no issues.
                    Ripped 24V PSU out of another printer today and unplugged heaters and fans so just steppers and sensors plugged in and done another test print, again this did not complete.
                    This time M122 back to Memory Protection Fault
                    Used output buffers: 2 of 40 (11 max)
                    Static ram: 122236
                    Never used RAM 101000, free system stack 200 words
                    Tasks: NETWORK(ready,161) ETHERNET(blocked,109) HEAT(blocked,297) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1111) IDLE(ready,19)
                    Owned mutexes:
                    Last reset 00:00:20 ago, cause: software
                    Last software reset at 2020-11-21 19:46, reason: MemoryProtectionFault mmarValid daccViol, Platform spinning, available RAM 101000, slot 1
                    Software reset code 0x4160 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x00038100 SP 0x2040aa78 Task TMC
                    Stack: 00000001 2040a928 00000000 00410210 00000000 00469d0f 00415682 21000000 427a0001 3c800001 00000000 3d000001 00000000 00000000 37533333 43d697a0 00000000 41dde946 43fa0000 44a80000 2040ff38 00469d0f 00000000 40078000 20400020 00415681 0000001e
                    Error status: 0x00
                    MCU temperature: min 39.2, current 39.9, max 40.0
                    Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: position 0, standstill, reads 35967, writes 14 timeouts 0, SG min/max 0/0
                    Driver 1: position 0, standstill, reads 35968, writes 14 timeouts 0, SG min/max 0/0
                    Driver 2: position 0, standstill, reads 35969, writes 14 timeouts 0, SG min/max 0/0
                    Driver 3: position 0, standstill, reads 35970, writes 14 timeouts 0, SG min/max 0/0
                    Driver 4: position 0, standstill, reads 35971, writes 14 timeouts 0, SG min/max 0/0
                    Driver 5: position 0, standstill, reads 35975, writes 11 timeouts 0, SG min/max 0/0
                    Date/time: 2020-11-21 19:46:54
                    Slowest loop: 6.26ms; fastest: 0.15ms
                    === Storage ===
                    SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 5.46ms; fastest: 0.03ms
                    - Ethernet -
                    State: active
                    === CAN ===
                    Messages sent 82, send timeouts 82, longest wait 0ms for type 0, free CAN buffers 46
                      @Via thanks, I will look into that data later.
                        @Via, please post the config.g file that you were using with 3.2beta3.2 when that assertion failure occurred.
                        Do you have any filament monitors configured? [Edit: from your M122 report i think that you do not.]
                        • Viaundefined
                          Via
                          @dc42 Thank you.
                          Config attached, not been changed from assertation failure (or from 3.1.1). No filament monitors.
                          config.g
                          • Viaundefined
                            Via
                            @dc42 any update on this?
                              I wasn't able to pin this down, except to say that it looks like random memory failure or corruption. Please upgrade to 3.4beta4. If it happens again, please post the print file and config.g if you haven't already (I'm using a tablet, so I can't tell), also daemon.g if you are using it.
                              • Viaundefined
                                Via @dc42
                                @dc42 Failed again on beta4 (M122 at bottom) they are posted already but will group together here.
                                config.g
                                [PLA] CFFFP_Top - ReRender - zero temps (1).gcode
                                full sys directory: https://www.viaraix.net/duet3-sys.zip
                                RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                                Static ram: 123212
                                Dynamic ram: 168584 of which 704 recycled
                                Never used RAM 99692, free system stack 188 words
                                Tasks: NETWORK(ready,169) ETHERNET(blocked,110) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,358) TMC(blocked,54) MAIN(running,1113) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 00:00:19 ago, cause: software
                                Last software reset at 2020-11-27 11:41, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 99692, slot 2
                                Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0044a804 BFAR 0x00000000 SP 0x204100c8 Task MAIN
                                Stack: 00000002 ffffffff 00434a29 20410308 000002bc 00469483 0046a3c8 610f0000 2042565c 004691bf 2042565c 00000000 000002bb 0000000a 2042565c 204256c8 00000000 00000001 00000000 00468e53 204256c8 00000000 204256c8 004691bf 00000000 00000000 20425540
                                Error status: 0x00
                                MCU temperature: min 39.0, current 39.4, max 39.9
                                Driver 0: position 0, standstill, reads 32774, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: position 0, standstill, reads 32775, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: position 0, standstill, reads 32776, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 32777, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 32779, writes 14 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 32782, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-11-27 11:41:21
                                Slowest loop: 6.06ms; fastest: 0.15ms
                                === Storage ===
                                SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 17.56ms; fastest: 0.03ms
                                - Ethernet -
                                State: active
                                === CAN ===
                                Messages queued 79, send timeouts 177, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
                                  Thanks for your new report. I am fairly certain that the memory protection fault was caused by a hardware error, because there is no way that the instruction at that address should fault, nor any way that the faulting address should be zero. So I suggest we swap your board. Who did you purchase it from?
                                  • Viaundefined
                                    Via @dc42
                                    @dc42 thanks for your time looking into this. Purchase was from E3D but I have just gone over the 6 months now (purchased 13th May), will you be able to authorise warranty replacement as reported prior?
                                      Yes I approve a warranty replacement.
                                      • Viaundefined
                                        Via @dc42
                                        @dc42 Thank you, will get in touch with E3D. Many thanks for your help.
                                          @Via, two more things to try:
                                          1. Try the new binary at https://www.dropbox.com/sh/tehhdvunh0pgr7q/AADgJ4Qj7W18MYaRRNNDdhpwa?dl=0, although I think it likely that it won't make any difference.
                                          2. Your MCU temperature may be a little high, depending on how accurate the 39.4C reading is. 40C is well within limits, but the actual temperature could be higher. Please try powering up the board when it is cold and immediately run M122 to check the temperature reading. That will allow you to calibrate the MCU temperature sensor. See https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature.
                                          • Viaundefined
                                            Via @dc42
                                            @dc42 MCU was over reading by ~2C so adjusted to compensate and showing ~35C now.
                                            Installed new firmware and...
                                            30/11/2020, 13:26:02	Finished printing file 0:/gcodes/[PLA] CFFFP_Top - ReRender - zero temps.gcode, print time was 1h 41m
                                            So looked promising so without changing anything I reran print to make sure it was not a fluke and sure enough it was 😞 ...
                                            RepRapFirmware for Duet 3 MB6HC version 3.2-beta4+4 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
                                            Used output buffers: 1 of 40 (12 max)
                                            Static ram: 123212
                                            Never used RAM 99692, free system stack 122 words
                                            Tasks: NETWORK(ready,165) ETHERNET(blocked,105) HEAT(blocked,297) CanReceiv(blocked,947) CanSender(blocked,352) CanClock(blocked,349) TMC(blocked,20) MAIN(running,1113) IDLE(ready,19)
                                            Owned mutexes:
                                            Last reset 00:12:51 ago, cause: software
                                            Last software reset at 2020-11-30 14:18, reason: MemoryProtectionFault mmarValid daccViol, Move spinning, available RAM 99692, slot 1
                                            Software reset code 0x4164 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427004 BFAR 0xb6d799a8 SP 0x2045ff58 Task MAIN
                                            Stack: 00000060 000000c0 00000091 96969694 00000001 00468c29 00469614 8100000e 00455a21 0045f237 00000000 2040e064 a5000001 008e0d8e 2040e064 a5000001 00000000 00000001 204281fc 00469d17 0000a5c7 204103b4 2042820c 204281f0 204281fc 20428370 00000000
                                            Error status: 0x00
                                            MCU temperature: min 34.2, current 34.3, max 36.3
                                            12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                                            Driver 0: position -3200, standstill, reads 61020, writes 17 timeouts 0, SG min/max 0/156
                                            Driver 1: position -800, standstill, reads 61021, writes 17 timeouts 0, SG min/max 0/319
                                            Driver 2: position 2000, standstill, reads 61022, writes 17 timeouts 0, SG min/max 0/184
                                            Driver 3: position 0, standstill, reads 61024, writes 17 timeouts 0, SG min/max 0/182
                                            Driver 4: position 0, standstill, reads 61027, writes 14 timeouts 0, SG min/max 0/0
                                            Driver 5: position 0, standstill, reads 61031, writes 11 timeouts 0, SG min/max 0/0
                                            Date/time: 2020-11-30 14:31:40
                                            Slowest loop: 12.11ms; fastest: 0.21ms
                                            === Storage ===
                                            SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                                            FreeDm 375 (min 372), maxWait 727688ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            Scheduled moves 13, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === Network ===
                                            Slowest loop: 12.92ms; fastest: 0.03ms
                                            - Ethernet -
                                            State: active
                                            === CAN ===
                                            Messages queued 3089, send timeouts 6944, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
