    PanelDueFirmware 3.2.3 released
    PanelDue
    699
    • cgcaferundefined
      cgcafer
      My on screen keyboard problem solved, many thanks.
      I will waiting V2 board 5" LCD solution
      • BoAundefined
        BoA
        Not sure why, but after I upgraded paneldue, printer has strange pauses during prints. For about a 3-4 seconds it stops, and then resumes printing. Duet 3 MB6HC 3.2-beta3.2
        I had no issues like that with same duet firmware and paneldue 3.2.2
        • oliofundefined
          oliof @BoA
          @BoA and to confirm, the pauses cease as soon as you disconnect the PanelDue?
          BoAundefined 1 Reply Last reply Reply Quote 0
          • BoAundefined
            BoA @oliof
            @oliof What Do You mean by "disconnect"? I have pauses just in the middle of the print without touching paneldue. Only variable seems to be upgrading paneldue firmware.
            • oliofundefined
              oliof
              I meant unplugging it to see whether it's just the configuration for a paneldue or the paneldue sending commands.
              • wilrikerundefined
                wilriker @oliof
                @oliof It is even simpler than that: selecting the Setup tab will stop PanelDueFirmware from sending any commands (except while initializating).
                @BoA Can you confirm that the same GCode prints fine when run without the PanelDue, i.e. either cable disconnected, panel on Setup tab or Aux channel disabled via M575?
                Manuel
                My Tool Collection
                • BoAundefined
                  BoA
                  OK. This seems to be coincidence. Printer pauses for a few seconds in random places even without panel connected.
                  • worekarolisundefined
                    worekarolis
                    Can't figure out why none of v3 firmwares are working on Version 2 PanelDue 7. Chip says that it is ATSAM3S4B. But after flashing does not boot. Last version that works is v1.24
                    • wilrikerundefined
                      wilriker @worekarolis
                      @worekarolis I am currently looking into this. I have an assumption I was not able to verify/falsify yet.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker
                        I have now released PanelDueFirmware 3.2.4 that is mainly intended to fix the issues with v2 boards.
                        Manuel
                        My Tool Collection
