    Little help to build rrf3
    Firmware developers
    1.1k
    • oliofundefined
      oliof
      Are you absolutely sure you installed the 2018 Q4 gcc cross-compiler from the ARM developer site as outlined in step #1? I.e., what happens if you run cd C:\Program Files (x86)\GNU Tools ARM Embedded\8 2018-q4-major\bin in your command line window?
      seraserundefined 1 Reply Last reply Reply Quote 1
        Your original post indicated that "make" was not found on the path. This file is not part of Eclipse. That's the reason for steps 3, 4 and 5 of https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md. So you can't have executed those 3 steps successfully.
        seraserundefined 1 Reply Last reply Reply Quote 0
        • seraserundefined
          seraser @oliof
          @oliof said in Little help to build rrf3:
          For sure 2018 Q4 installed.
          Maybe I need rm.exe and make.exe inside bin folder?
          Thank you @oliof
          • seraserundefined
            seraser @dc42
            @dc42 said in Little help to build rrf3:
            Point 3:Gnu Arm Eclipse is installed fine.
            Point 4:Path is done fine.
            Point 5:But no rm or make
            I cant see rm.exe or make.exe, maybe bad Gnu Arm Eclipse installation? I do it 2 times and same happened.
            • seraserundefined
              seraser
              @oliof @dc42 thank you very much.
              The problem is gnu arm eclipse is installed in program files due is 64 bits and gnu tools arm is in program files x86 due is 32 bits.
              So I copy paste bin folder from the first one to the second one and bomm, rm and make is fine and compiled fine CoreNG, yeah.
              • seraserundefined
                seraser
                Well, compiled fine CoreNg, FreeRTOS, RRFLibraries and RepRapFirmware but I cant see Duetcombined.bin, I think set duetwifi is needed but I dont Know in this moment.
                And the path to edit active motors to free ram.
                Only a little little help is needed.
                Thank you.
                  Looks like you have built the legacy Duet configuration, because I see Duet085 in the path in that output window. The build configuration you want will be called DuetNG or Duet 2.
                  • seraserundefined
                    seraser @dc42
                    Compile 2.05 branch fine but 3.2beta3.2 have errors and dont compile.
                    • oliofundefined
                      oliof
                      Try building RepRapFirmware 3.1.1 first
                      • checkout with the 3.1.1 / 3.1 tags as needed (see BuildInstructions)
                      • clean all projects
                      • make sure you have the right Build Configurations selected
                      • rebuild all projects in the right order
                      If you managed to build 3.1.1, check out the appropriate latest dev /3.02-dev branches, clean and rebuild all projects again.
                      • seraserundefined
                        seraser @oliof
                        @oliof all your instructions done with 3.1.1. but no luck errors appear with right build configurations checked in buildinstructions and clean projects before compile Reprapfirmware.impossible.JPG
                          I think you are using the wrong branch of the RRFLibraries project. Use the dev branch for RRF 3.1 and later. Likewise, use the dev branch of FreeRTOS.
                          • seraserundefined
                            seraser @dc42
                            @dc42 I use this files:
                            Changed toFreeRTOS dev branch all compiled and clean before compile Reprapfirmware and same errors.
                            This is my build configuration of all projects:
                            CoreNG SAM4E8E
                            FreeRTOS SAM4E
                            RRFLibraries SAM4E_RTOS
                            Reprapfirmware Duet2_RTOS
                            Are fine RRFLibraries and Reprapfirmware with RTOS added?
                            Thank you
                            • seraserundefined
                              seraser
                              Finally compiled latest version 3.2beta3.2 with only 5 motors active so great for me after few days, thank you @oliof and @dc42
                              • oliofundefined
                                oliof
                                Glad you could figure it out!
