    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.2k
    • Vetiundefined
      Veti @shatty
      @shatty
      yes calibrate the z probe.
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
      then do a mesh bed leveling and look at the bed. (post a picture)
      then calibrate your e steps
      https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
      then pid tune your bed and hotend.
      https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
      then print a benchy and asses.
      shattyundefined Vetiundefined 3 Replies Last reply Reply Quote 0
      • shattyundefined
        shatty @Veti
        This post is deleted!
        • shattyundefined
          shatty
          All the steppers are quiet except the 2 Zs. Normal?
          • shattyundefined
            shatty @Veti
            You want me to print a replica of my ass? LOL
            • Vetiundefined
              Veti @shatty
              @shatty
              funny typo i mean assess.
              what exactly do you mean by quiet?
              stand still noise?
              https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
              shattyundefined 1 Reply Last reply Reply Quote 0
              • shattyundefined
                shatty @Veti
                @Veti
                When the Z's are going up and down during the mesh test, they are louder than others
                • Vetiundefined
                  Veti @shatty
                  @shatty
                  yes, z movement with a leadscrew is noisier than other movements.
                  • shattyundefined
                    shatty
                    I dunno why that corner is so off
                    • shattyundefined
                      shatty @Veti
                      @Veti Hows the bed leveling?
                      • Vetiundefined
                        Veti
                        looks good, just dont printer on the borders of the bed, continue on.
                        • shattyundefined
                          shatty
                          Getting error on bed heat....saying its not rising fast enuf...1.7c a sec. I also have the bed connected to the mosfet that came with the stock setup.
                          • shattyundefined
                            shatty @shatty
                            @shatty Should I do the auto tune?
                            • Vetiundefined
                              Veti @Veti
                              @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                              refer to the list i previously posted
                              • shattyundefined
                                shatty
                                • shattyundefined
                                  shatty @Veti
                                  @Veti
                                  Ok so I got it to start printing benchy. I couldnt do the esteps measurement because it looks like I cant with the DD extruder I have. Anyways, its extruding too much. The nozzle is pushing the extruded filament around. So how do I cut it in half. I will play around with it till its perfect. Im using PLA that came with the printer. Printing at 220 with bed at 65. I have steel nozzle and I read that I should print 5-10 degrees hotter than normal.
                                  • Vetiundefined
                                    Veti @shatty
                                    @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                                    steel nozzles are very bad for pla printing.
                                    what direct extruder have you got?
                                    • shattyundefined
                                      shatty @Veti
                                      @Veti Microswiss direct drive all metal extruder/hotend. I lowered the e-steps/mm down to 130 as recommended by Microswiss. So far so good! I will post pics of benchy when its done. Im also going to be printing carbon fiber which i picked up already. Im sure Im going to be using other materials. It came with PLA so Im using it for now
                                      https://store.micro-swiss.com/products/micro-swiss-direct-drive-extruder-for-creality-ender-5
                                      • Vetiundefined
                                        Veti
                                        i would recommend that you get a plated Copper nozzle. it can print pla and carbon fiber as well.
                                        https://www.aliexpress.com/item/4000007458595.html
                                        shattyundefined 2 Replies Last reply Reply Quote 0
                                        • shattyundefined
                                          shatty
                                          Any prebuilt filament files I can download anywhere? I might have a brass nozzle somewhere. Im not going to use PLA after this. I have PETG as well as the CF.
                                          • shattyundefined
                                            shatty @Veti
