delta effector tilt during print only
i have a weird issue. after tweaking all the settings. i noticed that the effector ONLY tilts during an actually print. the file was sliced using prusaslicer 2.2. i do not notice any tilting when doing a delta calibration with 6 outer and 6inner points and 9 factors. nor do i see any tilt during mesh compensation.
another thing is, when the effector tilts, i also do not noticed the carriage trolleys twisting or rotating.
second question: what does the effect of a shorter thsn expected delta radius and longer than expected delta radius have on effector motion and first layer?
this is a kossel mino with wheeled carriages. not linear rails and it printed fine on marlin but i changed to magball rods and effector setup. i used a jig to measure all the rods to be the same length and the bearing spacings are identical for all 6 segments in CAD.
@tekstyle said in delta effector tilt during print only:
9 factors
did you start with 9 or did you arrive there?
its better to start with 6, if its not accurate with 8, and 9 only to verify the rod length. -
How are you detecting or measuring the tilt?
Are you using the Smart Effector, if not then what type of Z probe are you using?
i can see an obvious tilt when it's printing. i am using a printed effector with the joints at the level of the groove mount and hot end well below it. zprobe is an optical end stop with allenkey
it could be motors missing step.
have you set the correct current? around 75% of the rated current.
here is my config.g. i believe the stock motors are rated for 1.5a. i set them to 1.275a
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 11 2020 10:57:06 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"Anycubic Kossel Mini" ; set printer name
M665 R94.19 L220 B85 H248.29 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X1.284 Y0.201 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E142.549 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1275 Y1275 Z1275 E1428 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Y via pin zstop
;M574 Z1 S1 P"null" ; configure active-high endstop for low end on Z via pin null; Z-Probe
M558 P1 C"zprobe.in" H20 F1200 T4000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y-19.17 z9.467 ; set Z probe trigger value, offset and trigger height
M557 R70 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 h0 A133.6 C714.8 D2.1 S1 B0 V12.2 ; Heater 0 model: gain 133.6, time constant 714.8, dead time 2.1, max PWM 1.00, calibration voltage 12.2, mode PID
; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A740 C220.4 D5.6 B0 S1.00 V12.2 ;Heater 1 model: gain 740.0, time constant 220.4, dead time 5.6, max PWM 1.00, calibration voltage 12.2, mode PID
; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S0 H-1 C"Parts" ; set fan 0 value. Thermostatic control is turned off
M950 F2 C"fan2" Q250 ; create fan 1 on pin fan1 and set its frequency
M106 P2 S0 H-1 C"LED" ; set fan 1 value. Thermostatic control is turned on; Tools
M307 H0 A116.7 C650.3 D1.4 S1.00 V11.5 B0
M307 H1 A370.2 C150.1 D7.3 S1.00 V11.7 B0; Miscellaneous
T0 ; select first tool;m501
i have a anycubic kossel plus and the motors current are a lot less
M906 X1000 Y1000 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
and even at that current they get hot.
so check the temperature with your fingers if they get hot.
Motors missing steps will not cause the effector to tilt. You can find causes of effector tilt described at https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Make_sure_your_build_is_accurate.
my smart effector just arrived and i have went ahead and installed it. havent figured out all the hotend and fan electronics yet but so far it looks good with the spirit level. i also swapped out the trolley with more rigid ones. been playing with delta calibration and mesh and it looks way better than the saddle height map i have been getting before. right now, i have a dome shaped height map. i have been messing with delta length using the M665 command to see what results ill get. been going as far as -3mm to +3mm and it still looks the same.did my first xyz cube and came out to be 20.6mmX x 20.3 Y 20.06mm Z. corners appear to be squared. I think the tilt might have been the inaccuracy with the printed parts. I did print new pulley trolleys and replaced the wheels with Vslots and seems to be much more rigid with nearly no slop even when I tug with my hand.
h**ps://i.ibb.co/TBTpzMs/Screenshot-20201207-232842.jpg
[link text](link url)
