    Confused on wiring for Ender 3 Pro Conversion
    1.8k
    • Vetiundefined
      Veti @Destruct0Dan
      @Destruct0Dan said in Confused on wiring for Ender 3 Pro Conversion:
      M308 S0 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e0temp
      you mistyped your resistance value its 98801
      Destruct0Danundefined 1 Reply Last reply Reply Quote 1
      • Destruct0Danundefined
        Destruct0Dan @Veti
        @Veti Ah thank you. I take it I need to go through the configurator again to fix that?
        • Vetiundefined
          Veti @Destruct0Dan
          @Destruct0Dan
          no on the duet web ui you can edit the file directly. go to system and click on config.g
          Destruct0Danundefined 1 Reply Last reply Reply Quote 0
            Destruct0Dan @Veti
            @Veti added the 1 to both lines that was missing it. Restarted and now to see what it says. Thank you for pointing that out. I had gone through that process a couple times and thought I entered the one like needed. Guess not.
            Now my temps are reading the way they should. Now just continue through the setup process from the config setup portion? Also, does it mention where or how to adjust for using a TH3D EZABL Pro for my Z axis?
            • Vetiundefined
              Veti @Destruct0Dan
              according to this
              https://forum.duet3d.com/topic/4671/rewire-ezabl-capacitive-npn-z-probe-kit-for-duet
              its a npn sensor
              for wiring see
              https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
                Destruct0Dan @Veti
                @Veti I'll read over those. Thank you.
                Now I am also getting this when testing the bed. Seems it's warming up pretty slow. 1 degree in about 6-8 seconds.
                • Vetiundefined
                  Veti
                  you have to pid tune your bed and heater.
                  https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                    Destruct0Dan @Veti
                    @Veti oof. Talk about crash coursing in 3dPrinting. lol
                    Now about the sensor, I already have the TH3D control box that replaces the switch itself and just plugs into the Z stop position on the controller. Is it advised to not do that anymore and just connect only by what's mentioned in what you linked?
                    • Vetiundefined
                      Veti @Destruct0Dan
                      i dont have an EZABL probe. what i believe the controll box does, is allow the 12v or 24v power required for the sensor to be used and connect them to a normal endstop because overwise they would fry the board.
                      the duet maestro endstop pin in 30V tolerant, so the sensor can be connected directly.
                      however you could also just connect the controller box, that should also work.
                        Destruct0Dan @Veti
                        @Veti So I am noticing that my HotEnd is listed as Heater 1. Should I switch my cables over to 1 instead of 0?
                        • Vetiundefined
                          Veti @Destruct0Dan
                          @Destruct0Dan
                          no that is correct
                          see your config
                            So I went back through my photos from the guide and I had originally had the thermistor connected to the wrong port. The photo is still there actually (it's used to show the stepper motor connections). The thermistor connection section does show the correct position though.
                            Sorry I confused myself there. and Glad Veti got you sorted on the heater fault.
