    Switching from 4 Pin to 2 Pin Fan won´t work
    752
    • Vetiundefined
      Veti @Frederik
      @Frederik
      some fans do not work with pwm at all.
      for sunon fans example see the note here about the capacitor
      https://de.aliexpress.com/item/4000355235931.html
      Frederikundefined 2 Replies Last reply Reply Quote 0
      • Frederikundefined
        Frederik @Veti
        @Veti #oh, thanks. I didn´t know that. Mine is a 24V Version. But i think that makes no difference.
        What value should i use ?
        • Frederikundefined
          Frederik @Veti
          @Veti 25V 100uf ?
          • Vetiundefined
            Veti
            i do not have such a fan, so i never had to do it.
            i just came across it when shopping for a fan.
            Frederikundefined 1 Reply Last reply Reply Quote 0
            • Frederikundefined
              Frederik @Veti
              @Veti i was shopping for fans a lot in the last week. But i never saw an Information like that 🙂
                A Former User
                You'd probably want to use a 35V or 50V rating, the picture does show 100uF- You may get some degree of control, but I wouldn't expect magic.
                  DO NOT connect a capacitor in parallel with the fan outputs to smooth the PWM! Doing so subjects the fan mosfet to peak currents likely to exceed its rating.
                  The safe way to smooth PWM is to use a flyback diode (which is already included in the Duet fan outputs, but not heater outputs) and inductor, optionally followed by a capacitor.
                  It's also possible to use a 10 ohm resistor followed by a capacitor, although that will reduce the maximum fan speed a little.
                  • Frederikundefined
                    Frederik @dc42
                    @dc42 Ok, good to know.
                    What would the correct way ?
                    Connecting to a 2pin connector like out 7-9 ?
                    What do i have to change in my configt.g ?
                    Regards
                    Frederik
                    • Vetiundefined
                      Veti
                      you could try different pwm frequencies
                        dc42 administrators @Frederik
                        @Frederik said in Switching from 4 Pin to 2 Pin Fan won´t work:
                        Regards
                        Frederik
                        You can connect 2-pin fans to 4-pin connectors, between the VFAN pin and the FAN- pin. Connected in this way, they behave just like the 2-pin outputs.
                        Some 2-pin fans only work with PWM if you reduce the PWM frequency.
                        • Frederikundefined
                          Frederik @dc42
                          @dc42 do you mean with the oins nr 2 and 4 when i am looking at the online wiring guide ?
                          • Frederikundefined
                            Frederik
                            i mean for example: out 6: voutlc1 and the out6 ?
                            • Frederikundefined
                              Frederik @dc42
                              @dc42 i have tried both out 9 and out 6. Now Function.
                              Hotend Fan on out8 working on or off. but the other fan wont start with the same values
                              M950 F0 C"out8" Q500                                  ; create fan 0 on pin out8 and set its frequency
                              M106 P0 C"Hotend" S1 H1 T45                           ; set fan 0 name and value. Thermostatic control is turned on
                              M950 F1 C"out9" Q500                                 ; create fan 1 on pin !out4 and set its frequency
                              M106 P1 C"Bauteildüse" S1 H-1                         ; set fan 1 name and value. Thermostatic control is turned off
                              • Vetiundefined
                                Veti
                                Q500
                                try Q10
                                • Vetiundefined
                                  Veti @Veti
                                  @Frederik
                                  I bought some 2 pin sunon fans.
                                  at 500 i had the same result as you.
                                  at 25000 they are somewhat adjustable.
                                  Frederikundefined 1 Reply Last reply Reply Quote 1
                                  • Frederikundefined
                                    Frederik @Veti
                                    @Veti what model are you using? Meanwhile I got it working. I connected them on the toolboard to out 2 and out1, used pwm 255 and connected to pwm out and 12v.
                                    The control is for me good enough at the moment, I would guess that I'm getting ~10% steps.
                                    What range did you get with 25000?
                                    Thats the one I'm using:
                                    • Vetiundefined
                                      Veti @Frederik
                                      i was able to go down to 10% with the fan still spinning.
                                      • Frederikundefined
                                        Frederik @Veti
                                        @Veti I tested with 25000 as value.
                                        My Fans don't even start to spin.
                                        Only at 100%, they start running
                                        but at 99 it's standing still... why these big differences from similar Fans?
                                        • Vetiundefined
                                          Veti
                                          some fans do no like the pwm signal.
                                            You can try adding B1 to give it a blip of full power for 1 second to overcome any starting resistance.
