    Switching from 4 Pin to 2 Pin Fan won´t work
    764
      DO NOT connect a capacitor in parallel with the fan outputs to smooth the PWM! Doing so subjects the fan mosfet to peak currents likely to exceed its rating.
      The safe way to smooth PWM is to use a flyback diode (which is already included in the Duet fan outputs, but not heater outputs) and inductor, optionally followed by a capacitor.
      It's also possible to use a 10 ohm resistor followed by a capacitor, although that will reduce the maximum fan speed a little.
      Frederikundefined 1 Reply Last reply Reply Quote 0
      • Frederikundefined
        Frederik @dc42
        @dc42 Ok, good to know.
        What would the correct way ?
        Connecting to a 2pin connector like out 7-9 ?
        What do i have to change in my configt.g ?
        Regards
        Frederik
        • Vetiundefined
          Veti
          you could try different pwm frequencies
            dc42 administrators @Frederik
            @Frederik said in Switching from 4 Pin to 2 Pin Fan won´t work:
            Regards
            Frederik
            You can connect 2-pin fans to 4-pin connectors, between the VFAN pin and the FAN- pin. Connected in this way, they behave just like the 2-pin outputs.
            Some 2-pin fans only work with PWM if you reduce the PWM frequency.
            Frederikundefined 2 Replies Last reply Reply Quote 0
            • Frederikundefined
              Frederik @dc42
              @dc42 do you mean with the oins nr 2 and 4 when i am looking at the online wiring guide ?
              • Frederikundefined
                Frederik
                i mean for example: out 6: voutlc1 and the out6 ?
                • Frederikundefined
                  Frederik @dc42
                  @dc42 i have tried both out 9 and out 6. Now Function.
                  Hotend Fan on out8 working on or off. but the other fan wont start with the same values
                  M950 F0 C"out8" Q500                                  ; create fan 0 on pin out8 and set its frequency
                  M106 P0 C"Hotend" S1 H1 T45                           ; set fan 0 name and value. Thermostatic control is turned on
                  M950 F1 C"out9" Q500                                 ; create fan 1 on pin !out4 and set its frequency
                  M106 P1 C"Bauteildüse" S1 H-1                         ; set fan 1 name and value. Thermostatic control is turned off
                  • Vetiundefined
                    Veti
                    Q500
                    try Q10
                    • Vetiundefined
                      Veti @Veti
                      @Frederik
                      I bought some 2 pin sunon fans.
                      at 500 i had the same result as you.
                      at 25000 they are somewhat adjustable.
                      Frederikundefined 1 Reply Last reply Reply Quote 1
                      • Frederikundefined
                        Frederik @Veti
                        @Veti what model are you using? Meanwhile I got it working. I connected them on the toolboard to out 2 and out1, used pwm 255 and connected to pwm out and 12v.
                        The control is for me good enough at the moment, I would guess that I'm getting ~10% steps.
                        What range did you get with 25000?
                        Thats the one I'm using:
                        • Vetiundefined
                          Veti @Frederik
                          i was able to go down to 10% with the fan still spinning.
                          • Frederikundefined
                            Frederik @Veti
                            @Veti I tested with 25000 as value.
                            My Fans don't even start to spin.
                            Only at 100%, they start running
                            but at 99 it's standing still... why these big differences from similar Fans?
                            • Vetiundefined
                              Veti
                              some fans do no like the pwm signal.
                                You can try adding B1 to give it a blip of full power for 1 second to overcome any starting resistance.
